POV-Ray : Newsgroups : povray.binaries.images : Upgrading POV-Ray's include files #1: granites.inc --> granites21.inc Server Time
25 Jun 2026 11:24:33 EDT (-0400)
  Upgrading POV-Ray's include files #1: granites.inc --> granites21.inc (Message 44 to 53 of 123)
Subject: Re: Upgrading POV-Ray's include files #1: granites.inc -->granites21.inc
Date: 15 Apr 2021 16:15:00
Message: <web.60789e1f2b09e497d98418916e066e29@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> So, using the two *original* 1996 Daniel Mecklenburg textures from the
> "granites_original.inc" file that Thomas included in his zip files, I
> decided to run  them in v3.7 ...
I forgot to mention that the *only* minor change I made to those original
textures was to scale them smaller-- to look more like Thomas's granite.
Date: 15 Apr 2021 18:50:00
Message: <web.6078c2632b09e4971f9dae3025979125@news.povray.org>
Maybe we should implement the Cornell Box as a standard way of posting images
for comparison - to remove all of the other variables that affect the look of an
object and texture.
http://news.povray.org/povray.unofficial.patches/thread/%3C39380E82.5F30%40wanadoo.fr%3E/
(Isn't there an include file for this?)
Date: 16 Apr 2021 02:25:00
Message: <web.60792d862b09e497d98418916e066e29@news.povray.org>
> object and texture.
Yes, the 'Cornell box' scene is in SCENES/RADIOSITY (I had to hunt for it.)
I think its particular box environment might not be the best for showing the
true colors of a textured object placed inside it, only because it has
red/green/yellow walls (and the only lighting comes from the small ceiling
'radiosity' panel.) But your idea sounds useful-- perhaps a gray sphere for the
environment? Plus at least one white light_source for phong/specular highlights?
Date: 16 Apr 2021 02:45:00
Message: <web.607931dd2b09e497d98418916e066e29@news.povray.org>
Just noticed that my test scene code's two light_sources are in identical
positions-- they should be...
light_source {
  0*x
  color rgb .3
  translate <20, 40, -20>
light_source {
  0*x
  color rgb .7
  translate <-20, 40, -20>
My apologies for the error. I don't think it affects the results of the overall
experiment though. (I was curious as to why my renders showed only ONE highlight
on the objects.)
Date: 16 Apr 2021 02:46:39
Message: <607932cf@news.povray.org>
Op 15/04/2021 om 22:03 schreef Kenneth:
[snip]>
> I make no judgement as to which of the versions of 'North American Pink granite'
> has the correct 'visual' look-- I'll leave that to the granite experts ;-)
It the case of the granites I sincerely wonder if the gamma issue is an
issue at all (not to be discarded like that of course but...).
Attached is a Real World photograph of North American Pink. No scale is
provided but, in general, the largest grains in granites do not exceed
10-15mm [Bates & Jackson (1987): Glossary of Geology, 3rd Ed.].
Imo, this granite hue closely resembles the assume_gamma 1.0 render and
much less the assumed_gamma 2.2 one. However, there are innumerable
variations in hue and sizes, so who can say he is in the right and who
in the wrong? It becomes almost trivial. Except for the /scale/ of the
texture, where I strongly feel that a 'Real World correct' render should
be provided to the users.
I have come to the conclusion that granites21.inc is /based on/
granites.inc by Daniel Mecklenberg and not an exact reproduction of his
code. If we want those, we need to render the original file separately,
  with the initial conditions like Ive and you have done.
Download 'north american pink.jpg' (49 KB)
Preview of image 'north american pink.jpg'
Date: 16 Apr 2021 02:49:07
Message: <60793363$1@news.povray.org>
Op 16/04/2021 om 08:24 schreef Kenneth:
>> object and texture.
I agree with you. My 'environment' could serve but needs adjustments in
that case.
Date: 16 Apr 2021 03:40:00
Message: <web.60793e9a2b09e497d98418916e066e29@news.povray.org>
Yes, I agree. And in my personal opinion, the gamma 1.0 'look' is most likely
what was intended, more or less-- based on my trust of your own knowledge of
granites, and also the original comments by Daniel M, who seemed to know about
the subject himself. It would surprise me if he did run his textures with a
2.2-gamma and accepted the result-- because I would assume that "North American
Pink granite" is a well-known and 'standard' type of rock, agreed on by
geologists.  Not like 'political viewpoints', ha.
Date: 16 Apr 2021 04:21:36
Message: <60794910$1@news.povray.org>
Op 16-4-2021 om 09:36 schreef Kenneth:
Lol! My thoughts entirely. I assume that Daniel Mecklenburg intended his
textures to be used with an added scale closely related to the
/dimensions/ of the supporting object where a 10cm wide cube in one
scene would need a different scale than a 10m wide stone wall in another
scene. Caveat: if used in the same scene, both objects would of course
need the same scale! I would argue that, by itself, any POV-Ray texture
is "dimensionless" and needs a known support in order to be scaled
accordingly.
I assume that the name "North American Pink" is the commercial name. As
a geologist, I would call it a 'granodiorite' probably. The same goes
for the other granites textures which I have been able to trace in the
Real World.
In any case, as 'simple' users, lets be and remain creative! Also in the
rgb/srgb matter (ouch! I did it again!). We have a saying here: "buiten
de lijntjes kleuren" which translates as "colouring outside the lines
(or the boundaries)" and meaning "breaking the rules" in particular
concerning the creative process, but also applied to scientific
research. It promotes serendipity without any doubt imo.
Subject: Re: Upgrading POV-Ray's include files #1: granites.inc-->granites21.inc
Date: 16 Apr 2021 05:28:39
Message: <607958c7@news.povray.org>
Am 4/16/2021 um 10:21 schrieb Thomas de Groot:
>> likely
>> knowledge of
>> know about
>> with a
I'm can assure you that in 1996 absolutely nobody did use assumed_gamma
1.0 for reasons that are actually quite obvious even if you do not
understand them.
On the other hand my guess would be them someone with the pseudo "Code
Warrior" (and its implied reference to Mel Gibson) did not use a toy
operating system like Windows 95 which means he did use assumed_gamma
1.8 as a consequence.
>> American
> accordingly.
> Real World.
Well, my understanding was that this is not just about this particular
granite file, but about a correct way to convert in general old textures
from times were *never* assumed_gamma = 1.0 was used.
Obviously this is not the case, sorry for this misunderstanding on my
part, but frankly you should have said so in the first place and should
not have added a bunch of buzz words borrowed from color science into
your header where these words make no sense at all.
So I did completely waste my time here and it seems you did not even
bother to look at my code - as all I hear is just about comparing
images. So here is a final image from me also produced with my code but
with some more educated "guesses" to tweak one user parameter - based on
the image you did show.
My conclusion: my first thought was right, so please do not mention me
in any of your files, seriously I mean it.
No need to bother with a reply I'm outa here
so long - Ive
Subject: Re: Upgrading POV-Ray's include files #1:granites.inc-->granites21.inc
Date: 16 Apr 2021 05:31:19
Message: <60795967@news.povray.org>
oops, the image...
Download 'nap.png' (496 KB)
Preview of image 'nap.png'
