![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Normals appear to have an inherent directional bias independent of
pattern. To eliminate as a variable any bias in a built-in pattern, I
used an explicit normal function. The two images should be mirror
images of each other, but they are not. The bias shows in all versions
from 3.5 to 3.8.
----------[BEGIN CODE]----------
// +KFF2
#version max (3.5, min (3.8, version));
light_source { <(frame_number = 2? 1: -1), 1, -1.4> * 1000, rgb 1 }
camera
{ location -6 * z
right x
angle 30
box
{ 0, 3
pigment { rgb <1, 0.5, 0.5> }
normal
{ function
{ max
( select (x - 1, 1, select (x - 2, 0, 1)),
select (y - 1, 1, select (y - 2, 0, 1))
accuracy 0.1
translate <-1.5, -1.5, 0>
-----------[END CODE]-----------
Download 'normal_bias1.png' (2 KB)
Download 'normal_bias2.png' (2 KB)
Preview of image 'normal_bias1.png'
![normal_bias1.png](/povray.binaries.images/attachment/%3C5ff4a6cc%241%40news.povray.org%3E/normal_bias1.png?ttop=443824&toff=400&preview=1)
Preview of image 'normal_bias2.png'
![normal_bias2.png](/povray.binaries.images/attachment/%3C5ff4a6cc%241%40news.povray.org%3E/normal_bias2.png?ttop=443824&toff=400&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> pattern.
This is something I noticed and discussed some privately with Bald Eagle
while working on the quilted et al normal only patterns.
The method used for creating the normal from scalar function/pattern
values uses samples (4) and the sampling has a directional bias. This
bias does not necessarily exist with true normal perturbation. "Normal
perturbation based upon scalar value functions and patterns have a
directional bias."
A similar sampling method is used to create isosurface normals but there
- usually - the code runs at the surface intersection and due the local
"shape" values the simpler 3 delta sampling mostly works(1).
(1)- There are still possible issues. If the function/shape is set up
with a constant or near constant value range on one side or the
transition through the local 0 value root. Where the three axis
gradients are significantly different or all nearly the same is another.
If you run f_normal at a local change in value direction off the surface
- the sphere origin being an example - you tend to get the a form of the
sampling bias as the normal.
Aside: I have planned a new special pattern called "access" for pulling
out both the raw and perturbed surface normals (perhaps more) so I can
look at what is happening with scalar value calculated normal
perturbation in more detail.
Aside: Related to above I already change povr's aoi pattern to return a
full -1 to +1 range of values relative to the incoming rays. This lets
me set up different colors for positive and negative map values so I can
see by rendered color where perturbed normal inversions happen - where
the bump value is large enough to flip the primary direction relative
the incoming ray.
Aside: As you know, the magnitude of the perturbation values play a roll
too with whether or not raw normals invert in part or in total when
perturbed.
Aside: A reason povr is dropping scalar value based normal perturbation
methods where a custom normal perturbation method exists is that, in
addition to being more flexible, it's much easier to control / prevent
normal perturbation inversions. This is a move away from v3.5 onward
normal updates toward how earlier version of POV-Ray worked.
... There are many details with normal handling I still don't
understand. Warps and those empty code hooks being one bit ...
Bill P.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It's been a while that I coded C and C++ but in general I consider
myself a fair programmer (> 10 years professional experience) and would
like to help, cause I need PovRay to live and improve ...but the 3D math
is something my brain cannot handle well.
Not sure what to do here. I think I can easily get into C++ again, but
such a large and math-heavy project like Povray sure will require some
time to actually understand and being able to make meaningful patches.
Any suggestions what to do if I want to help?
> Bill P.
Hajo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Hajo
Hi Hajo,
10+ years professional programming certainly makes you more of a real
programmer than me. :-) I've used POV-Ray a long time, but have only
been digging into the source deeply since early 2016 (<4 years). And C++
I'm still very much learning.
As to how to contribute, I'm unsure. :-) Some thoughts.
The official v3.7-stable and v3.8 master (development) branches as they
exist on github are without active programmer support. See:
https://github.com/POV-Ray/povray
Of late the Debian and macOS folks have taken it on themselves to patch
/ change things in their space for POV-Ray v3.7.0.8 updates. There has
not since Feb 19, 2019 been an official "POV-Ray team" release or
pre-release.
A good candidate for this would be familiar with Windows,
Linux/Unix/macOS environments - and git/github. Also with various
compilers and build systems in addition to C++. Ultimately, whether
anyone new is given github update authority would be up to Chris Cason.
On the linux/Unix/macOS side of things especially, several here offer
releases for branches of one sort or another. Each branch I see as
particularly focused. My povr effort is one of these and it breaks
compatibility in more of a 'POV-Ray 4.0' way than do most others. Povr
is also Linux/Unix based only. I don't use Windows day to day and I do
not understand code development in the Windows environment.
Creating your own branches to play with existing options or to dig into
some particular bug a way to start learning the code base. This a way to
to start smaller - it's how I started out.
If you might be interested in a stand alone tool for POV-Ray, one area
where the linux/Unix/macOS side of things in lacking is there is no
native PoseRay equivalent. Further PoseRay source code is not openly
available for fixes/updates as far as I know even if one is OK running
under wine, say.
There is too the stalled Moray development - Chris Cason is the owner of
that software.
Bill P.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, that is something that concerns me since a while. Years ago I had
made a decision to stick with PovRay instead of switching to Blender and
worked to create a library of models that will use in my sci-fi scenes.
Now it seems that I have made a bad decision. Blender with the Cycles
Renderer delivers stunning real looking images. The old Blender renderer
didn't seem to match PovRay but Cycles does and even surpasses.
But I don't want to give up yet.
I don't qualify here. I tried to build povray with MinGW under Windows
and couldn't make it. Compiling under Linux worked pretty well instead.
And since some years Linux is what I use in my free time.
We used git at work and I have two projects on Github but I'm definitely
not an expert there. I just use it.
Seems to be a common problem, at least one that we two are sharing. What
is the goal of Povr?
I've noticed a bug with media effects behind semi-transparent image maps
on transparent objects. Not entirely sure if it's really a bug or if my
combination of glass sheets and "holographic" displays was particularly
stupid. I'd like to fix this problem but at the same time it seems to be
something that is hard to fix cause it's not contained in one feature
but appears due to interaction of different features.
Maybe time to make a new thread in the programming group and see what
other people think. I'm all new here. And the version that I compiled
from the 3.8-master branch seems to have very few real bugs.
https://en.wikipedia.org/wiki/Path_tracing
I think this feature is what makes the Cycles renderer produce better
images than PovRay with radiosity. It's the same idea as radiosity but
more modern and advanced. But I definitely are not the one to actually
put such into PovRay, knowing virtually nothing about the code and also
about the math behind this.
Some of my PovRay works:
https://www.deviantart.com/antarasol/gallery/42758766/3D
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yep. It's good to remember efforts like Blender have paid core support
for the - less interesting/fun - day to day development stuff. It's more
common, I believe, that vital projects of some size have a small team
where some know windows, others macOS, others web development, etc.
> What is the goal of Povr?
:-) I had to think some about the question! The povr branch happened due
dead ends elsewhere with respect to what I needed. I'd say:
- Selfishly and foremost, a hobby which is fun.
- Initially, a simpler version of "POV-Ray" supporting the existing
scene language and the most common features while fixing as many
longstanding bugs (and broken features) as I can.
- Longer term, I have a list of wild ideas. If I can get to a simpler
source platform while learning enough programming, I hope to be able to
try some of the more involved ones. To be able to figure out which ideas
are good and which are junk.
> combination of glass sheets and "holographic" displays was ...
If you believe there's a bug in the current official release, the usual
place starting post would be povray.bugreports. Or, povray.beta-test, if
it a problem particular to v3.8 development. Either probably works out
and cutting the issue down to as simple a scene as possible a great
help.
Aside: I just noticed the http://news.povray.org/groups/ web page
description for beta-test wrongly refers to the POV-Ray v3.7 SMP
beta-test instead of v3.8.
I never know what to do with pointers to the latest and greatest -
whatever. Usually some good to a particular approach, but different
devils in the details. At a high level all approaches are faking real
world effects to some degree.
Yes, if you set up the modeling in more of a real world way, and you
crush the render with samples you get a very good looking render result.
You also hide numerical sin in a way not unlike how POV-Ray's AA methods
or focal blur tend to cover over problems beyond the intended aim of the
AA.
Somewhat agree. One place where I believe POV-Ray comes up short is in
handling finish highlights where radiosity, area lights and ??? are in play.
While I mostly kept a distance from the finish changes Christoph was
working on for v3.8(1), I believe the aim for many of the changes - like
always specifying an interior ior - was to better handle surface
finishes (highlights especially) in a real world way. Expect others here
know better than me the extent to which my belief is true?
(1) - Being more interested in shapes and actual surface treatments than
faked ones.
I think mostly these v3.8 finish block changes haven't been exploited to
date. If they more often were, would the highlight differences compared
to Cycles (et al) be as dramatic? I don't know for certain, but I
suspect less so.
Soapbox:
At some point what's seen as best or better - what becomes common - is
just where the crowd of users ends up / happens to be. There is value in
following; It's easier to grab detailed work of others in terms of code,
models, materials, maps and such and stick it into your larger scene (or
program or whatever). Further, it's more likely the things you grab work
- at least in the main.
Bill P.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
[snip]
That's something I like. A simpler codebase is easier to understand, and
maintain. Also should makes finding bugs easier.
>> maps on transparent objects. Not entirely sure if it's really a bug or
>> if my combination of glass sheets and "holographic" displays was ...
> and cutting the issue down to as simple a scene as possible a great help.
I'll do so once I have set up a scene file to reproduce the problem in a
simple way ... or found out that I was stupid somewhere and the fault is
mine. Right now It's too early to make an official report here.
> whatever.
20 years is not so new, but yes ... the only reason to post was cause
the Cycles renderer uses this and produces very good quality. I just
wanted to make sure we both have the same state of knowledge.
> play.
I must admit I know nothing about these changes, even that I use a 3.8
alpha version.
> suspect less so.
For sure I have not, cause I didn't even know about them. I'm still
using what is documented for 3.6/3.7
I'll try to find some documentation about the finish related changes in 3.8
I agree. But while many change to Blender, this is why I asked how I can
help. I'd hate to see PovRay die. It's been around so long and was one
of the best free 3D programs for many years.
Since the last message I have been reading some parts of the code. The
tracer core, texture handling, patterns, media. At the moment I think I
could make some changes to patterns with some level of success. Some
parts of the code, even in the patterns are very sophisticated (the
algorithms, the code is still clean to read), and I don't think I could
fix a problem there.
Now that you pointed me to the finish changes, I'll take a look into
that next.
> Bill P.
Hajo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://wiki.povray.org/content/Documentation:Tutorial_Section_1#Changes_and_New_Features_Summary
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> in 3.8
Thank you. It seems the following two were the finish related changes
mentioned earlier in the discussion ... did I miss some others?
* A new finish parameter use_alpha has been added to suppress highlights
and reflections depending on pigment transparency
* Fresnel angle-dependent attenuation can now also be applied to
highlights and the diffuse component for more physical realism
The use_alpha looks useful indeed. So far I gave highly transparent
glass very little specular highlights to avoid the problem.
I'm not sure how to make good use of the second point though?
Hajo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
