POV-Ray : Newsgroups : povray.binaries.images : Stock colors and assumed_gamma 1 in POV-Ray 3.6 Server Time
12 Aug 2025 16:54:53 EDT (-0400)
  Stock colors and assumed_gamma 1 in POV-Ray 3.6 (Message 1 to 10 of 77)
Subject: Stock colors and assumed_gamma 1 in POV-Ray 3.6
Date: 11 Oct 2020 23:55:55
Message: <5f83d3cb@news.povray.org>
I have some new findings for POVers who wish to use the named colors in
colors.inc with assumed_gamma 1 in old versions of POV-Ray.
You may recall that I noted a few years ago that the named colors in
colors.inc seemed to have been determined without taking non-linear
representation into consideration.  In other words, they don't look
right with assumed_gamma 1.  So, I recommended applying srgb to these
colors, as one would do with color values from third-party software, and
ignoring the "suspicious expression" warning.  Shortly thereafter, I
discovered the srgbft keyword, which eliminates the warning on colors
that are already defined.
But while fooling around with my render rig wish list the other day, I
discovered that 3.5 and 3.6 renders of the dark grays were lighter than
3.7 and 3.8 renders!
So I wrote a scene to render some of the grays with different gamma
configurations under different POV-Ray versions, then sampled the output
images and created montages with the sampled values.  The ground plane,
sky colors, and ambient were adjusted per frame to be comparable
regardless of assumed_gamma, which is why the assumed_gamma 1 renders do
not appear much different from the others.  In each frame, the light
source is rgb 1 and diffuse was set such that the sum of diffuse and
ambient is exactly one; this ensures that a Lambertian surface facing
the light source reflects the pigment value.
The number in the center of each frame is a sample of the upper left
facet, which directly faces the light source.
My goal was to use the unregulated color (upper left frame) as a
control, and match that color using assumed_gamma 1.  The closest
results are:
   Color    Control   POV-Ray 3.6          POV-Ray 3.7
   Gray05   0.0037    Gamma 2.2 (0.0037)   sRGB (0.0040)
   Gray25   0.0497    Gamma 2.2 (0.0497)   sRGB (0.0513)
   Gray50   0.2122    Gamma 2.2 (0.2122)   Either (0.2159)
   Gray75   0.5210    Gamma 2.2 (0.5210)   sRGB (0.5210)
So, it appears that my initial recommendation holds for POV-Ray 3.7:
   #version 3.7;
   pigment { srgbft ColorFromColorsDotInc }
But for earlier versions of POV-Ray, the power function should be used:
   #version 3.6; // or #version 3.5;
   #include "math.inc"
   pigment { rgb VPow (ColorFromColorsDotInc, 2.2) }
The 3.5 renders are not shown because they sampled identical to the
corresponding 3.6 frames.  I haven't sampled 3.8 frames, but unless
someone knows differently, I have no reason to believe that changes were
made in its gamma handling.  I have not tested any versions prior to
3.5, nor have I tested any versions on an old Macintosh, which I
understand used an unconventional gamma.
An implication that I have realized is that this rendering difference is
not limited to stock colors.  *Any* color you define with rgb will look
slightly different from 3.6 to 3.7.
In doing the automated sampling, I also discovered that a 3.7 image map
loaded from a 3.5 or 3.6 rendered PNG source will look different from
the source image!  To avoid this, put gamma 2.2 into the image_map
block.  Whether this is a property of the rendering engine or just how
the PNG chunks were set up, I don't know.  At the moment, I have no
means of a proper comparison of the other supported image formats.
Download 'stock_gamma-montage1.png' (77 KB) Download 'stock_gamma-montage2.png' (77 KB) Download 'stock_gamma-montage3.png' (75 KB) Download 'stock_gamma-montage4.png' (73 KB)
Preview of image 'stock_gamma-montage1.png'
Preview of image 'stock_gamma-montage2.png'
Preview of image 'stock_gamma-montage3.png'
Preview of image 'stock_gamma-montage4.png'
Subject: Re: Stock colors and assumed_gamma 1 in POV-Ray 3.6
Date: 12 Oct 2020 19:25:00
Message: <web.5f84e4d576c60ba8dfdf9a980@news.povray.org>
Thank you very much for the detailed report. This actually quite interests me as
I had trouble with the same matter a while ago, and your insight may help me
understand what was happening there.
Pascal
> results are:
>    #version 3.7;
>    #include "math.inc"
Date: 13 Oct 2020 00:10:00
Message: <web.5f85278f76c60ba8d98418910@news.povray.org>
Funny thing: This week, I've been running tests that are very similar to yours,
solely in v3.8 (the latest development version). For my city buildings scene, I
am trying to figure out why two colors-- both evaluated using the eval_pigment()
macro-- return slightly different values, when the values should be identical.
My *current* belief is that the reason has to do with the 'srgb' gamma itself,
as opposed to gamma 2.2. SRGB has a gamma that is not a straight power law (like
2.2), but rather a sort of combination of gammas-- with both a power law segment
and a linear segment. The 'average' of those is not quite 2.2. Wikipedia has a
good article about it. My own results so far show that an SRGB color vs. a
'linear' RGB color (that has been re-transformed into a gamma 2.2 color by using
an inverse power law) produce the slightly different values. AFAIU, the
Wikipedia article gives a rather complex formula which better approximates this
'gamma inversion' of RGB to arrive at the SRGB gamma color, with a better match
between expected values.
I *think* that POV-ray version 3.6 and earlier did not make use of 'srgb' as a
gamma in any way, but rather 1.0 or 2.2, depending on the "user's preference",
ha. I used to use 2.2, but that was because of a basic 'color misunderstanding'
on my part, prior to the introduction of srgb colors. ;-)
I'm still absorbing your comments, and thinking it all through. I need to do a
visual test like yours, in v3.8.
Date: 13 Oct 2020 02:30:01
Message: <web.5f8548ed76c60ba8d98418910@news.povray.org>
[snip]
> gamma in any way, but rather 1.0 or 2.2, depending on the "user's preference"...
Sorry, I probably didn't make my point very clear.
n POV-ray versions prior to 3.7(?), and using an assumed_gamma of 1.0 for a
scene back then, the colors in 'colors.inc' (being 'linear colors') didn't look
right when used as-is-- they had a washed-out appearance, due to the
assumed_gamma of 1.0. Changing assumed_gamma to 2.2 'corrected' those colors to
be what we (I?) might expect, or so it appeared. (but disregarding the other
'internal' computational problems that this probably caused vis a vis using a
suggested assumed_gamma of 1.0)
Jump forward to v3.7xx and 3.8, with its 'proper' use of assumed_gamma 1.0 and
the introduction of the srgb color keyword for using 'gamma-corrected' color
values that do not look washed out-- for example, using srgb to change a
'linear' rgb color in colors.inc.
SO... using assumed_gamma of 2.2 in earlier POV-ray versions along with linear
color values there, but then in later versions using assumed_gamma 1.0 and with
srgb-corrected colors, the respective gamma appearance (and value) of a
particular color might be slightly off when the two schemes are compared-- due
to the slight difference in gamma-bending between srgb and 'straight' 2.2
Or so my reasoning goes ;-)
Date: 13 Oct 2020 16:25:06
Message: <web.5f860c8a76c60ba81f9dae300@news.povray.org>
Hi Kenneth - this is something that I was concerned about, tried to address, and
IIRC, did it backwards.
Maybe you can take a look, and see what you think.
http://news.povray.org/povray.text.scene-files/thread/%3Cweb.58cc101945a951b1c437ac910%40news.povray.org%3E/
Apparently there's something with the linear interpolation of the color map that
needs to be addressed as well.
I'm accumulating one of those "infinite to-do lists..."   ;)
Date: 14 Oct 2020 06:00:01
Message: <web.5f86caca76c60ba8d98418910@news.povray.org>
> address, and IIRC, did it backwards.
I'm genuinely sorry to say that I didn't take note of your color-conversion
macros at the time (March 2017.) That is some NICE work.
I just spent a couple of enjoyable and challenging hours, going through your
macros' code there, and comparing it to the Wikipedia 'conversion' formulae (at
Wikipedia's "srgb" entry). Your math looks to be spot-on-- but of course you're
better at math than I am. ;-) Thanks for the opportunity for the mathematical
'brain boost'.
And you are correct-- your two macros are *reversed* as to their respective
operations! Through no fault of your own: the Wikipedia formulae themselves are
REVERSED. Which may mean that Wikipedia's source for those formulae is also
wrong. I'm amazed that no one has yet corrected the Wikipedia article.
'Fixing' your two macros is a simple matter-- just rename RGB2SRGB(C_linear) as
SRGB2RGB(C_exponential), ha. And vice-versa.
Having done so myself, I converted rgb <.75,.75,.75> to its srgb equivalent.
Result: <0.522522,0.522522,0.522522>
Compare that to:
#declare MY_PIG = pigment{srgb .75}
#debug concat(
"\n","srgb color = <",vstr(3,eval_pigment(MY_PIG, <.2,.2,.2>),",
",0,6),">","\n")
// Result: <0.522522,0.522522,0.522522>
A perfect match. Congrats!
As I experimented with your macros, three things pointed me to the conclusion
that the macro operations were reversed:
1) Your own hint ;-)
2) My *original* <.75,.75,.75> rgb-to-srgb result was 0.880825 -- which was
clearly wrong.
3) In the (mis-named) RGB2SRGB macro, at the near-ending line of
       #local C_srgb = ...
I changed that on a whim to
       #local C_srgb = srgb ....
and the #debug result was... <.75,.75,.75> -- the same as the original color! In
other words, it was first converting the color to (rgb) 0.880825 by the formula,
then #re*-converting it back to (srgb) 0.75. So *something* was amiss somewhere!
Btw, it may not be clear that to *use* your macros, the macro call in a scene
should include  srgb (or rgb, as the case may be). Like so:
box{0,1
pigment{srgb RGB2SRGB(<.75,.75,.75>)}
If it is left out, POV-ray apparently assumes the color to be 'linear' RGB by
default.
I would humbly suggest that you make a few changes to your March 2017 post. ;-)
Date: 14 Oct 2020 08:10:00
Message: <web.5f86ea7b76c60ba8d98418910@news.povray.org>
> rename RGB2SRGB(C_linear) as SRGB2RGB(C_exponential), ha. And vice-versa.
Well, I guess the macros do need a bit more than that in their code... only to
have consistency among the names of their internal variables. Minor work.
Sorry, I didn't notice that you already gave examples of use, within the macros'
comments.
Date: 14 Oct 2020 10:50:00
Message: <web.5f870fa276c60ba8d98418910@news.povray.org>
I had some free time, so I 're-packaged' the macros for you, with all the
(minor) changes, and the switch of the macro names. All should work well, but
re-test them for any last-minute typos I may have made.
Download 'color_conversion_macros_redone.txt' (3 KB)
Date: 14 Oct 2020 12:15:01
Message: <web.5f87236d76c60ba8d98418910@news.povray.org>
> images and created montages with the sampled values...
Getting back to your original post here, about the slight discrepancies in color
values among the various versions of POV-ray:
I did some *basic* tests, solely in v3.8, using a simple pigment plus the
eval_pigment{...) macro, and I still get slight discrepancies in compared color
values. It somehow comes from the use of  srgb  vs.  rgb  in a color, AND on the
assumed_gamma of the scene.
#declare PIG_C = pigment{rgb <.75,.75,.75>} // CHANGE this from srgb to rgb
#debug concat("\n","PIGMENT_C evaluation = <",vstr(3,eval_pigment(PIG_C,
<.2,.2,.2>),", ",0,6),">","\n\n")
The various results using different assumed_gamma values:
--- With assumed_gamma 1.0:
1) using srgb: eval_pigment = <0.522522,0.522522,0.522522> // correct
2) using rgb:  eval_pigment = <0.750000,0.750000,0.750000> // correct
--- With assumed_gamma 2.2:
// 1) using srgb: eval_pigment = <0.744501,0.744501,0.744501> // ??
// 2) using rgb:  eval_pigment = <0.750000,0.750000,0.750000>
--- with assumed_gamma srgb:
// 1) using srgb: eval_pigment = <0.750000,0.750000,0.750000>
Under assumed_gamma 1.0, the evaluated values are correct. But under
assumed_gamma 2.2, the result with srgb is *slightly* off from the original
value. I have no idea why. (I would have thought that those two values would be
MUCH different, like under assumed_gamma 1.0).
Date: 14 Oct 2020 20:40:00
Message: <web.5f8799f076c60ba860e0cc3d0@news.povray.org>
The srgb keyword always returns a color that *looks* the same across all
assumed_gamma settings.  To take your example, srgb 0.75 will *look* the same
whether your scene uses assumed_gamma 1, assumed_gamma 2.2, or assumed_gamma
srgb.  But this implies that, internally, it will evaluate to different rgb
values depending on the assumed_gamma setting.
When you use assumed_gamma srgb, the scene's nonlinearity aligns with the color
definition, which is why rgb and srgb return the same value.  And since sRGB is
close to gamma 2.2, rgb and srgb return close, but not identical, values under
assumed_gamma 2.2.
