POV-Ray : Newsgroups : povray.binaries.images : Applying textures to a spherical heightfield section afterwards? Server Time
27 Sep 2024 17:26:06 EDT (-0400)
  Applying textures to a spherical heightfield section afterwards? (Message 1 to 10 of 17)
Subject: Applying textures to a spherical heightfield section afterwards?
Date: 11 Sep 2020 20:14:16
Message: <5f5c12d8$1@news.povray.org>
Hi(gh)!
Meanwhile, the process of generating POVEarth heightfields from ASTER
data tiles runs pretty fine... but: as currently, the texture is a part
of the generated mesh2 script, whenever I want to change the texture
itself, I have to generate a new mesh2 script - and they are 3 gigabytes
large! Is there a chance to apply the surface texture (which is a 240 x
240 pixel section from NASA's huge "Blue Marble" mosaics for each square
degree tile) after the creation of the mesh2 without using the whole
"Blue Marble" mosaic? Or, to be more precise, can I constrain an
image_map to a certain region of a sphere?
See you in Khyberspace!
Yadgar
Subject: Re: Applying textures to a spherical heightfield section afterwards?
Date: 12 Sep 2020 05:51:31
Message: <5f5c9a23$1@news.povray.org>
Le 12/09/2020 à 02:14, Jörg "Yadgar" Bleimann a écrit :
> Hi(gh)!
> Yadgar
Did you look at uv-mapping ?
script generates the mesh2 with uv-coordinates of the points, and
"later", you provide the texture/pigment as an image.
The range of uv for the script is very small (as the whole earth would
use 0-1 x 0-1 .
Date: 12 Sep 2020 07:08:06
Message: <5f5cac16$1@news.povray.org>
Hi(gh)!
> use 0-1 x 0-1 .
According to the official 3.7 tutorial, the texture/pigment statement
still has to be part of the original mesh2 definition - so that would be
no solution to my problem!
Yadgar
Date: 12 Sep 2020 09:10:09
Message: <web.5f5cc79f57afda211f9dae300@news.povray.org>
The _NAME_ of the texture does - which can be defined in the pov file that then
includes your mesh2.
Date: 12 Sep 2020 09:55:04
Message: <5f5cd338$1@news.povray.org>
See, we have smart people here !
Date: 12 Sep 2020 16:15:01
Message: <web.5f5d2bd457afda211f9dae300@news.povray.org>
The only difference between the master and the novice is that the master has
failed more times then the novice has tried. -Stephen McCranie
Oh, how this forum has witnessed my many and repeated failures...
Date: 13 Sep 2020 22:36:55
Message: <5f5ed747$1@news.povray.org>
Hi(gh)!
O.k., I tried this - with the following code in my mesh2 generator
replacing the texture_list:
// begin code
   #write (ES, concat("  uv_vectors\n",
		     "  {\n",
		     "    ",str(NumUVVectors, 1, 0),"\n"))
   #for (a, 0, ydim-1)
     #for (b, 0, xdim-1)
       #write (ES, concat("<", str(b*(1/xdim), 1, 6), ",",
str(a*(1/ydim), 1, 6), ">"))
       #if (a < ydim-1 & b < xdim-1)
	#write (ES, ",")
       #write (ES, "\n")
   #write (ES, "  }\n")
// end of code
But, depending on whether I set the #for loop limits and the #if
condition for the last vector to ydim-1, xdim-1 or ydim-2, xdim-2, I
either get "Texture index out of range" or "Expected 'numeric
  expression', } found instead". What goes wrong?
Yadgar
Date: 14 Sep 2020 12:34:24
Message: <5f5f9b90$1@news.povray.org>
Le 14/09/2020 à 04:36, Jörg "Yadgar" Bleimann a écrit :
> Hi(gh)!
>> that then
> // begin code
>              "  {\n",
How is NumUVVectors computed ? it should be xdim*ydim.
or (xdim+1)*(ydim+1) if range of #for are (0, ydim) and (0, xdim)
>   #for (a, 0, ydim-1)
>     #for (b, 0, xdim-1)
Range problem, b/xdim is never reaching 1.0, same for a/ydim.
I hate that code:
because it seems, to my eyes, ambiguous about order of operations.
Please put more ().
Date: 14 Sep 2020 13:18:16
Message: <5f5fa5d8$1@news.povray.org>
Hi(gh)!
>>    #for (a, 0, ydim-1)
>>      #for (b, 0, xdim-1)
> I hate that code:
> Please put more ().
I tried your suggestions, but still get the "out of range" error!
Yadgar
Date: 14 Sep 2020 13:40:00
Message: <web.5f5faa7857afda211f9dae300@news.povray.org>
I can say from long and painful experience that you need more (switchable)
#debug statements so that you can follow along as the code progresses.
While you're putting those in, it would likely be useful to tidy up the
calculations and maybe split long or confusing operations into multiple steps,
with comments.
You're deep into the territory of "check your assumptions" by determining "what
are the facts?".
avoid opinion, care not what the neighbors think, never mind the unguessable
― Robert Heinlein
