POV-Ray : Newsgroups : povray.binaries.images : Operation timed out? Server Time
16 Mar 2026 15:07:32 EDT (-0400)
  Operation timed out? (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Operation timed out?
Date: 10 Aug 2020 06:50:00
Message: <web.5f3125c248fcdfd64d00143e0@news.povray.org>
hi,
=?UTF-8?Q?J=c3=b6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmxde> wrote:
> On 10.08.20 00:14, Jörg "Yadgar" Bleimann wrote:
> Did not work either - no terrain relief visible in the scene!
have never seen an "Operation timed out" error, and searching the (installed)
documentation gave no clue.  it would be useful to hear from people who know the
code, in which circumstances/situations that error can happen.
regards, jr.
Date: 10 Aug 2020 07:25:00
Message: <web.5f312e1a48fcdfd61f9dae300@news.povray.org>
Is there a way to grep the source code to find out where that gets spit out, as
a starting point for backtracking?
(I'd recommend 3.6 source, as IIRC 3.7 has all the complicated, hard-to-follow
multithreading.  If it's in 3.6, and it's still a mystery, then what is learned
from studying the code can be used as a roadmap to 3.7)
Date: 10 Aug 2020 07:50:01
Message: <web.5f3133c148fcdfd64d00143e0@news.povray.org>
hi,
sure.  something like
  $ find /path/to/povray/src -type f -exec grep -Hn 'search term' {} \;
('-H' to make 'grep' report the file name, '-n' for line number; add '-i' to
make the search case insensitive)
meanwhile I found two relevant threads in the newsgroups:
<http://news.povray.org/povray.general/thread/%3C52dcd2b3$1@news.povray.org%3E/>
<http://news.povray.org/povray.general/thread/%3C56a2bec2%241%40news.povray.org%3E/>
regards, jr.
Date: 10 Aug 2020 08:05:22
Message: <5f313802$1@news.povray.org>
Something is running too slow is the non helpful, short answer, I didn't
post yesterday - because it sound to me ears a little snarky despite
being accurate... :-)
Reasons could be many. Paging (using too much memory). Systems is
otherwise overloaded etc - or just slow.
If the message hasn't somewhere been assembled from parts and pieces,
it's probably a 'kTimeoutErr' using a 10 (second?) default set
indirectly by 'kDefaultTimeout'.
The only use of kTimeoutErr sits in a chunk of remaining 'c' code inside
the message passing system (source/povms/povms.c). If it is this error,
it can happen when sending a stream of data - somewhere.
If you can compile yourself, there looks to be a _DEBUG macro in the
message code which when set extends the timeout to 100 (seconds?) if
running that bit of code under a debugger. Other debugging / workarounds
would require much more twiddling.
Aside: I've been digging around again in the frontend code and looking
some at this message passing system. Error wise, all over in the 3.7
code, there is a fair bit of error handling that looks to have been left
hanging - incomplete / not fully flushed out. It would certainly be
helpful in this case to know more about the 'message' being sent on the
timeout.
Possible Workarounds:
Try it again.
Be sure your machine isn't 'at all' busy with anything else when you
kick off the animation.
If your machine supports >1 work thread use fewer or one (+wt1) and see
if you get the error.
If you're running large render block sizes, shrink them.
Use -cc so the state file work does not get done.
Use a ramdisk (or if not that a faster disk) for all input and output
files if possible.
Aside 2:
I don't much understand the message passing system code, but it looks
like most information internally is getting passed around using it. I
think the idea was to eventually be able to support rendering remotely
on a large cluster of machines with a single controlling gui/entity.
The remote capability doesn't especially interest me with povr, and I'm
carrying the question: Should I try replace it / change it / simplify
the vfe/povms stuff... Don't know. Some conceptual parts are OK - ini /
command line parsing mostly in the vfe, but then the truth is the
reality for unix/linux is this common *x parsing is quite weak and has
open bugs. One of which I recently ran down - only to find another right
behind it... Many flag / file command line parsing errors end up as ini
file not found errors... (1)
(1) - On unix/linux, if you are not running 'povr,' you are mostly not
seeing any actual command line / ini parsing errors except a catch all
thing which, IIRC, I think Jerome added at some point during v3.7
development which returns the command line with a generic message
something went wrong. Anyway, guess my mind is drifting from the
original subject - but another tangled in error reporting not being that
helpful.
Bill P.
Date: 10 Aug 2020 09:00:09
Message: <web.5f31433748fcdfd64d00143e0@news.povray.org>
hi,
after having read through the threads referenced in earlier post, I'm
almostready to add a rant of my own.  about how people who migrate to GNU/Linux
are often unaware that now they must, on occasion, don the system administrator
hat.  but I won't.  ;-)
snipped the explanatory part, for which thanks.
> Aside 2:
that is interesting.  if instead of "large cluster" one had this capability for
the LAN.  I'm sure that many users, like me, have more than one computer on the
LAN, and it would be way cool if POV-Ray could exploit that.
regards, jr.
Date: 10 Aug 2020 13:36:26
Message: <5f31859a@news.povray.org>
Am 09.08.2020 um 00:23 schrieb Jörg "Yadgar" Bleimann:
> Hi(gh)!
> Meanwhile I got the rendering of ASTER tile terrain reliefs running once
> more - albeit only with Earth as a simple sphere, if I add realistic
> flattening, the scene remains empty except for the ocean and basic Earth
> sphere - strange!
> But when I try to render a sequence of consecutive images, such as
> +ipovearth.pov +ogeorgia_panorama-.png +w1024 +h768 +a0.3 +ki0 +kf719
> +kfi0 +kff719 (a simple camera rotation pull)
> after completing the first frame, I get:
> Operation timed out
> Operation timed out
> Render failed
> Why?
> See you in Khyberspace!
> Yadgar
I have no real idea why this happenes time and again. I expierenced it
time and again myself. In most cases restarting the rendering with +c at
the command line helps. And in this cases saving and loading radiosity
data can save some hours.
Best regards
Michael
Date: 10 Aug 2020 15:35:43
Message: <5f31a18f$1@news.povray.org>
No, that is pretty much the only answer available.
Well, really slow. Remember that this means messages take 10 seconds to
be passed from one thread to the next. Normally threads should be called
every few milliseconds. If the operating system needs ten seconds to
switch threads, something is wrong, or the receiving end is "gone",
meaning it crashed. The later is way more likely for a simple scene.
Indeed.
The code isn't remaining, it is intentionally C code, so it can be
ported really everywhere and run on a very low level, with some of the
message passing APIs around and interact with the thread management
directly. It will also work even if basically all memory is exhausted by
using some private pool. For those who want a C++ API, there is one, of
course. It sits on top of the C code.
The question is not where the message is sent, but where it should be
received. The whole POVMS code has extensive debugging support that can
be enabled by macros.
> timeout.
No, this isn't really the case. By the time you get into trouble with
the message passing, you are already in such a mess that you likely
cannot recover in a meaningful way. The most likely cause of the message
passing to stall for a simple scene is actually that the receiving side
crashed in some way, i.e. by an exception that left the message handler
in an unexpected way.
> Aside 2:
No, it is also a core of the threading functions. What it really does it
provide a separation between the frontend and the backend such that you
can actually render multiple scenes or images of a scene at the same
time. It also allows you to do this while the frontend GUI and the
backend(s) run in separate processes. It also is the code used for
render continuation (that actually works even if you switch systems in
between) and a bunch of other stuff.
Suggestion: If you don't understand some code, it is a clear indication
you should stay away from it until you do ;-)
VFE is basically a quick solution Chris Cason implemented early in the
3.7 development because something was needed for the Windows frontend.
It is by no means required. It is just a collection of stuff that is
really mostly meant for the Windows frontend, and does not work all that
well for a command line frontend. Actually, in 3.7 the command line
frontend used to be in there and would compile by enabling the main
function - I know because this feature was a major part of the
development process of 3.7.
> thing which,
Well, the code could be added. But you are right that the error handling
of INI files was not finished in time.
Thorsten
Date: 10 Aug 2020 15:36:49
Message: <5f31a1d1$1@news.povray.org>
On 09.08.2020 00:23, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
> sphere - strange!
> Operation timed out
> Operation timed out
> Render failed
It is a fatal error. And you get it from two threads.
Thorsten
Date: 11 Aug 2020 12:13:07
Message: <5f32c393$1@news.povray.org>
>> didn't post yesterday - because it sound to me ears a little snarky
>> despite being accurate... :-)
> Indeed.
>> inside the message passing system (source/povms/povms.c). If it is
>> this error, it can happen when sending a stream of data - somewhere.
>> workarounds would require much more twiddling.
>> left hanging - incomplete / not fully flushed out. It would certainly
>> be helpful in this case to know more about the 'message' being sent on
>> the timeout.
>> Aside 2:
>> I'm carrying the question: Should I try replace it / change it /
>> simplify the vfe/povms stuff... Don't know.
>> thing which,
> Thorsten
where two or more processes or threads are asking for the same resource
at the same time and each is waiting for the other to finish using that
resource.
Date: 11 Aug 2020 13:29:40
Message: <5f32d584@news.povray.org>
> resource.
No, this is not how POVMS is written. I am its author ;-)
Thorsten
