POV-Ray : Newsgroups : povray.binaries.images : Agate pattern has a preferred, along z orientation. Server Time
16 Feb 2026 11:13:01 EST (-0500)
  Agate pattern has a preferred, along z orientation. (Message 1 to 1 of 1)
Subject: Agate pattern has a preferred, along z orientation.
Date: 6 May 2020 08:49:34
Message: <5eb2b25e@news.povray.org>
Another surprise to me. The agate pattern has a preferred z
direction(1). Said another way, it works best (always?) projected onto
an x,y plane (a +-z plane object in POV-Ray).
I think it won't much show up - so long as pattern, transform and object
modifiers manipulations are nearly symmetrical in x,y,z. However, I'm
not completely sure, there are too many options, combinations...
I'm sure it shows. Now knowing about it, I used the 'feature' in the
attached image.
#declare Fn00 = function { pattern {
     agate
     warp { turbulence 0.04 octaves 5 omega 0.41 lambda 6 }
     octaves 4    // 6
     omega   0.13 // 0.5
     lambda  1.33 // 2.0
     noise_generator 2
     frequency 0.5
     poly_wave 0.2
     scale 1/3
     rotate x*90
The first turbulence in the warp turbulence list is symmetrical in
magnitude and effect, but also of the sort to show the z treatment by
agate. The agate pattern has been oriented for a y up view and
displacement of the y plane object.
Note! The warp{} block around the initial turbulence is necessary.
Otherwise the trailing octaves, omega and lambda are applied to it. See
documentation on bare turbulence vs warp{} wrapped. Mostly, wrap
turbulence with warp {} to ensure turbulence ordering - and option
associations.
Bill P.
(1) - At the core it grabs only the z point from 3d space and 'mixes' it
with a turbulence value so as to change the value distribution to be U
shaped; to be heavy toward zero and one.
Download 'isooffsetya_hmm.png' (1137 KB)
Preview of image 'isooffsetya_hmm.png'
