POV-Ray : Newsgroups : povray.binaries.images : Roughness override and specular albedo: is this deliberate? Server Time
12 Jul 2025 15:11:01 EDT (-0400)
  Roughness override and specular albedo: is this deliberate? (Message 1 to 1 of 1)
Subject: Roughness override and specular albedo: is this deliberate?
Date: 13 Oct 2019 23:25:29
Message: <5da3eaa9@news.povray.org>
When you override roughness in a declared finish that has specular
albedo, the specular is not recalculated for the new roughness.  To get
proper results, you have to restate the specular albedo.  Here is an
example:
----------[BEGIN CODE EXCERPT]----------
#declare SMOOTH = 0.0005;
#declare ROUGH = 0.02;
#declare BUMP_SIZE = 0.2;
#declare MICROSCALE = 0.0001;
#declare f_Gloss = finish
{ fresnel
   reflection { 0 1 fresnel } conserve_energy
   specular albedo 1 roughness SMOOTH
   ambient 0 diffuse 0
#declare t_Glass = texture
{ pigment { rgbf 1 }
   finish { f_Gloss }
#declare t_Frost1 = texture
   finish { f_Gloss roughness ROUGH }
   normal { bumps BUMP_SIZE scale MICROSCALE }
#declare t_Frost2 = texture
   finish { f_Gloss roughness ROUGH specular albedo 1 }
-----------[END CODE EXCERPT]-----------
The second row of images uses the textures as declared above; the first
row uses the finishes modified to not use finish-level Fresnel.  I will
post the complete scene files in p.binaries.scene-files.
The leftmost image of each row uses t_Glass, with the unmodified finish.
  The center image uses t_Frost1, which has roughness increased, which
results in a grossly overly strong highlight.  The rightmost image uses
t_Frost2, which restates the specular albedo.
Download 'roughness_override-pbi.jpg' (94 KB)
Preview of image 'roughness_override-pbi.jpg'
