POV-Ray : Newsgroups : povray.binaries.images : Having a try at light distributions Server Time
28 Mar 2024 08:30:42 EDT (-0400)
  Having a try at light distributions (Message 1 to 10 of 14)
Subject: Having a try at light distributions
Date: 13 May 2019 07:30:00
Message: <web.5cd95526b9d0796c51138a9b0@news.povray.org>
Hello everyone!
I am trying to introduce photometric data files of luminaires (i.e. IESNA .ies
or EULUMDAT .ldt) in Povray to get "correct" lighting distributions. This
currently works by combining
(1) a point light source
(2) a sphere with radius 0.01 and spherical mapping of an image map (.png with
the alpha channel used for transparency) which represents the lighting
distribution for different angles.
However, for large coordinates (e.g. 1e+6), I get unwanted black spots in a
regular pattern (see attached image on the left).
Jasper
Download 'lum.jpg' (93 KB)
Preview of image 'lum.jpg'
Subject: Re: Having a try at light distributions
Date: 13 May 2019 14:00:06
Message: <web.5cd9afd734505b1d3c1c78400@news.povray.org>
"Jasper" <nomail@nomail> wrote:
> Hello everyone!
> Jasper
OK, this doesn't have anything to do with radiosity - so I agree on floating
point precision issues as cause...
Norbert
Date: 13 May 2019 16:32:46
Message: <5cd9d46e$1@news.povray.org>
Le 19-05-13 à 07:29, Jasper a écrit :
> Hello everyone!
> Jasper
You may try using a larger sphere when the scale of the scene get larger
than about 1e+4. It may reduce the rounding errors to some extent.
The best thing to do is to limit the size of the scene to be less than
1e+5 if at all possible.
Build your scene around the origin. Don't be afraid of negative numbers.
Date: 15 May 2019 10:04:13
Message: <5cdc1c5d$1@news.povray.org>
On 5/13/19 7:29 AM, Jasper wrote:
> Hello everyone!
> Jasper
Hmm, I have to say I'm curious about the regularity of those black
spots. The numerical issues I've hit are usually noisier - or completely
black/invisible/something when a hard numerical limit is hit.
Any chance I could get a smallish test case posted to one of the scene
file groups? I'll stick it in my POVRay_Issues directory and at least
take a quick look if not now a deep one.
Bill P.
Date: 15 May 2019 10:11:01
Message: <5cdc1df5$1@news.povray.org>
> Norbert
Is this still true for you with recent v38 releases?
I'd captured the case(s) you posted a couple years back - my notes say
in 2016. I wasn't able to run what you posted directly on my little
machine, but a cut down scene was fixed when I tested a v3.71 branch
March 17, of 2017.
Bill P.
Date: 15 May 2019 15:35:52
Message: <5cdc6a18$1@news.povray.org>
>> floating
>> Norbert
> March 17, of 2017.
> Bill P.
The version don't matter when you hit the FPU's limits.
Don't forget that in computing the illumination, there are a few
squaring and square roots involved. This typically demand twice the
number of bits of the input value if you want to avoid loss of precision.
When you square a 64 bits floating point value, you need 128 bits to
accurately represent the result.
Date: 17 May 2019 05:29:40
Message: <5cde7f04$1@news.povray.org>
>>> floating
>>> Norbert
>> March 17, of 2017.
>> Bill P.
True. However, the reason I was digging into Norbert's particular
radiosity normals issue is that I intended to open up a github issue for
it so we didn't lose track of it.
My view is that unlike other places in POV-Ray where we hit numerical
issues, really tiny normals should just be treated as zero normals / no
normals - or perhaps be normalized somehow so they don't cause issues.
Probably good too if 'bad' normal scalings can be detected and the user
warned before they get ignored - but that's probably hard to the point
of being practically impossible.
In any case I didn't think his situation should be causing artifacts
like we were seeing in the output image.
The scaled very tiny normals were causing issues with Norbert's original
renders in 2016. When I looked at the issue in 2017 to create a github
issue, it looked like the issue had been fixed. The complication was the
original scenes as posted - I think even one smaller one posted later -
were too costly for my little machine. So, I evaluated behavior on
something I thought similar hoping to use it as the scene for the issue.
I might have gotten something wrong. I might have done something which
caused the issue to be there in (v??? don't remember) and gone in the
3.71 version I was testing against.
If Norbert still sees black spots with his original scenes using a
current v3.8, the issue still exists and I think we should open a github
issue for it. It's on my list again to try and run one of his originally
posted scenes again with v38 - but I'm in the middle of several other
projects and that won't happen for some time.
Suppose I'm hoping for a quick - "Oh, it works OK now" - answer/status
from Norbert to save some time! :-)
Bill P.
Date: 23 May 2019 05:38:50
Message: <5ce66a2a@news.povray.org>
> Bill P.
I ran Norbert's cut down scene last night - it wasn't mine as I
remembered. It looks to me this morning, as my notes indicate it did to
me back in 2017, as if this particular radiosity normals issue is fixed.
If others see a radiosity issue I don't, please speak up.
Image is attached. Using heavy AA as the black speckles show worse in
v37 that way. Top is the current v37 result. The bottom the v38 result
at commit 74b3ebe.
Bill P.
Download '02feb2016radiositynrmlsissue37to38.png' (1248 KB)
Preview of image '02feb2016radiositynrmlsissue37to38.png'
Date: 23 May 2019 14:35:07
Message: <web.5ce6e6bd34505b1d3c1c78400@news.povray.org>
> at commit 74b3ebe.
> Bill P.
Since you are asking directly - my problems were solved after this special IRTC
round by deleting small normals at the normal section - what else....
No, it wasn't that easy, but anyway...
Since then I deleted small normals, when black spots occured. Of course I'm
curious of the root cause, but my focus is more on the result...
But here I'm curious...
Norbert
Date: 24 May 2019 08:39:09
Message: <5ce7e5ed$1@news.povray.org>
If the normals are so small at the scene scale they cannot be seen, it
makes sense compute resource wise to remove them no matter. In a strange
way, seeing the black artifacts was an indication texture normals too
small existed and we no longer have this in v38.
Still, I think POV-Ray should handle/filter such normals as people
sometimes are using a texture/material others coded and it shouldn't
completely break when used at a different scale(1).
I don't myself know what changed in the code post v37. Maybe something
got fixed with the static code analysis Christoph runs and reviews now
and again. I don't remember a specific commit for such an issue, but my
memory is less good these days. I too might have been busy with real
life when the change happened.
It is possible to do a binary search of commit versions to localized the
commit(s) which fixed the issue for your scene. I've done this sort of
work especially for performance issues. However, it's a very time
consuming process always. A process worse on *nix systems like mine
where we must work around sequences of commits in the history which
don't compile. I have no plans to look for what got fixed - given it
looks to be fixed.
That said, if you see black spot artifacts due normals in a recent v38
release, a sample scene would be appreciated.
Bill P.
(1) Drifting... With published materials/textures I think it would be
helpful to later users to know the original scale where the texture was
developed and applied. "M_RustyIron12. Applied at 1x scale to objects in
a 100x,100y,100z range centered at the origin. Camera distance to object
with texture was roughly 350." Other stuff? Suppose most of us assume
development in a -1,1 box at the origin and normal-ish camera set up
after which we fish around for what looks good.
