POV-Ray : Newsgroups : povray.binaries.images : Behavior change in #default reflection Server Time
16 Feb 2026 15:49:58 EST (-0500)
  Behavior change in #default reflection (Message 1 to 1 of 1)
Subject: Behavior change in #default reflection
Date: 12 Apr 2019 21:35:32
Message: <5cb13ce4@news.povray.org>
This is *not* a bug report, but a heads up.  In POV-Ray 3.7, if you set
reflection and Fresnel on in a #default statement, then later reset the
#default reflection to zero, you could get away with not turning off
Fresnel.  POV-Ray 3.8 won't forgive you for that.
The following scene illustrates such a situation.  Image
reflection38-by37.jpg was rendered with POV 3.7.0 and
reflection38-by38.jpg was rendered with POV 3.8.0-alpha.10064268.  In
each image, the sphere on the left was instantiated after just
reflection { 0 }, and the sphere on the right was instantiated after
reflection { 0 fresnel off }.
--------------------[BEGIN CODE]--------------------
#version 3.7;
global_settings { assumed_gamma 1 max_trace_level 10 }
camera
{ location <0, 1.5, -10>
   look_at y
   angle 30
light_source
{ <-1, 2, -1> * 10000, rgb <1.2, 1.0, 0.9>
   parallel point_at 0
sky_sphere
{ pigment
   { gradient y
     color_map { [0 rgb <0.15, 0.3, 0.6>] [1 rgb <0.05, 0.1, 0.2>] }
#default // for wood texture only
{ finish
   { reflection { 0 0.2 fresnel } conserve_energy
     ambient rgb <0.1, 0.2, 0.4>
#include "woods.inc"
plane
{ y, 0
   texture { T_Wood12 }
   interior { ior 1.47 }
#macro GoldSphere()
   sphere
   { y, 1
     pigment { rgb <0.97, 0.74, 0.33> }
     finish
     { reflection { 1 metallic }
       diffuse 0
       ambient 0
       specular albedo 1 metallic
       roughness 0.0001
// Reset the default reflection (sufficient for POV 3.7):
#default { finish { reflection { 0 } } }
object { GoldSphere() translate -1.2 * x }
// Reset the default reflection (necessary for POV 3.8):
#default { finish { reflection { 0 fresnel off } } }
object { GoldSphere() translate 1.2 * x }
---------------------[END CODE]---------------------
OS: openSUSE Leap 15.0 (GNU/Linux)
Download 'reflection38-by37.jpg' (29 KB) Download 'reflection38-by38.jpg' (27 KB)
Preview of image 'reflection38-by37.jpg'
Preview of image 'reflection38-by38.jpg'
