POV-Ray : Newsgroups : povray.binaries.images : Moire patterns when trying to create isosurface sphere Server Time
12 May 2024 12:40:18 EDT (-0400)
  Moire patterns when trying to create isosurface sphere (Message 1 to 10 of 26)
Subject: Moire patterns when trying to create isosurface sphere
Date: 3 Jan 2019 00:30:01
Message: <web.5c2d9dae5e758c193008c61f0@news.povray.org>
The sphere should be solid right up to the edge but I get "Moire Patterns"
instead
Download 'moire problem.png' (39 KB)
Preview of image 'moire problem.png'
Subject: Re: Moire patterns when trying to create isosurface sphere
Date: 3 Jan 2019 01:05:01
Message: <web.5c2da53746f01a8179416a1f0@news.povray.org>
> instead
Hi there,
I don't know what those lines are but they do not look like moire patterns to
me. I could be wrong, of course, but maybe considering other possibilities might
help you troubleshoot your problem.
Dave Blandston
Date: 3 Jan 2019 01:20:00
Message: <web.5c2da94246f01a813008c61f0@news.povray.org>
> > instead
> Hi there,
> Regards,
> Dave Blandston
This is the same image file just using a different anti-aliasing (method 3)
always shows up at the edge of the illuminated part of the sphere. Thanks for
the quick response.
Download 'moire problem.png' (62 KB)
Date: 3 Jan 2019 01:45:00
Message: <web.5c2daeea46f01a8179416a1f0@news.povray.org>
> the quick response.
Yep, those are moire patterns for sure! I will have to defer to the experts from
this point on...
Dave Blandston
Date: 4 Jan 2019 18:55:00
Message: <web.5c2ff1e346f01a8148892b50@news.povray.org>
with 'polarity on'
Download 'compatt.png' (39 KB)
Preview of image 'compatt.png'
Date: 4 Jan 2019 23:05:00
Message: <web.5c302cb046f01a8179416a1f0@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> with 'polarity on'
Glad you found a solution!
Dave Blandston
Date: 5 Jan 2019 15:25:00
Message: <web.5c31118446f01a8148892b50@news.povray.org>
cheers Dave.  too late, it seems, to be of use to COMPATT.
regards, jr.
Date: 6 Jan 2019 13:10:00
Message: <web.5c32438746f01a81cd98345b0@news.povray.org>
> with 'polarity on'
What's that? I must have missed a new feature(?) somehow...
Date: 6 Jan 2019 13:45:00
Message: <web.5c324c5646f01a8148892b50@news.povray.org>
hi,
> > with 'polarity on'
looks like you did.  :-)  the last paragraph in section "3.5.1.1.6 Isosurface"
in the 3.8 docs reads:
By default, the inside of an isosurface is defined as the set of all points
inside the contained_by shape where the function values are below the threshold.
New in version 3.8 this can be changed via the polarity keyword. Specifying a
positive setting or on will instead cause function values above the threshold to
be considered inside. Specifying a negative setting or off will give the default
behavior.
regards, jr.
Date: 6 Jan 2019 17:50:00
Message: <web.5c3284ff46f01a81cd98345b0@news.povray.org>
> hi,
> > > with 'polarity on'
> in the 3.8 docs reads: ...
Thanks! Yep, it's new to me. (And I was wondering where those moire patterns
were coming from-- thinking that the planet was just a simple sphere object, not
an isosurface.)
