POV-Ray : Newsgroups : povray.binaries.images : N (Captain Nemo) revisited Server Time
25 Apr 2024 04:12:40 EDT (-0400)
  N (Captain Nemo) revisited (Message 11 to 20 of 35)
Subject: Re: N (Captain Nemo) revisited
Date: 20 Mar 2018 15:00:00
Message: <web.5ab159edb126f8c91b6c6b3a0@news.povray.org>
I see you've made everyone's scowl more intense in the update :)
Interesting to look at the vegetation - both very realistic, but I actually
think I prefer the original in this regard.
Date: 20 Mar 2018 18:30:00
Message: <web.5ab18a5ab126f8c95cafe28e0@news.povray.org>
> It is an old memory from my own childhood in fact.
And then, after watching Thomas and the gang at play, Jules Verne used the event
as the inspiration to write _20,000 Leagues Under The Sea_ - in 1870.
:D   :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D
Date: 21 Mar 2018 03:32:04
Message: <5ab20a74$1@news.povray.org>
Entirely correct! And published in.... exactly. ;-)
Date: 21 Mar 2018 03:36:35
Message: <5ab20b83$1@news.povray.org>
On 20-3-2018 16:12, Norbert Kern wrote:
> Well done Thomas,
Thanks you indeed Norbert.
> but by changing the camera point of view, most of the nice birds disappeared...
> What I want to know is how you did your grass and plants - really nice.
The fault is DrJohn's macro but I deemed the loss minor to the gain of a
more realistic scene. I could change the flight of the birds of course.
Incidentally, those were built in Moray using blobs.
The plants are meshes I converted from Poser while the flowers were
provided by PlantStudio.
Date: 21 Mar 2018 03:40:04
Message: <5ab20c54$1@news.povray.org>
The scowl was already there in the original and I don't like it. I can
do better. Probably will be smoothed out in the next version
Somehow I have to agree with you. Maybe something I can mend too...
Date: 21 Mar 2018 06:52:08
Message: <5ab23958$1@news.povray.org>
Am 3/20/2018 um 8:43 schrieb Thomas de Groot:
> Once in a while, I like to revisit an older scene and remodel it to
> current standards and my changing insights and skills. I did this lately
> with my entry to the TC-RTC back in 2008: "N". I still want to change
> some elements but the comparison over ten years of using POV-Ray are
> notable. Left, is the entry of 2008; right, the new version.
Sorry, but overall I do prefer the original.
The new version seems quite over-saturated, especially the vegetation,
the bricks and the wheel.
While the new camera view is nice it has the unfortunate side effect
that two birds of the flock are very close to the top border and this
hurts the composition.
And a general note to everybody who's posting images to theses
newsgroups: please make sure your JPEG image contains a ICC profile.
Since about 2 months Firefox and Thunderbird have full color management
enabled by default. Chrome and Opera do the same since quite a while,
only IE and Edge don't - but who uses them anyway?
Every contemporary mid-range monitor has a wider color gamut than sRGB,
the one I use even wider than Adobe RGB - and I can assure you, the
difference is NOT subtle.
When I want to make sure to view an image as intended I have to do a few
additional steps and as I'm lazy I usually don't care. As color
management only kicks in for images with ICC profiles I have to save the
image to my local disk and check *if* it contains a profile and if not
use my own image viewer that correctly assumes for images without
profile to be in sRGB and transforms them correctly to my viewing device
profile.
-Ive
Date: 21 Mar 2018 07:30:31
Message: <5ab24257$1@news.povray.org>
How do I do that? Does it apply to PovRay generated png's?
Regards
Date: 21 Mar 2018 08:11:50
Message: <5ab24c06@news.povray.org>
>> lately with my entry to the TC-RTC back in 2008: "N". I still want to
>> change some elements but the comparison over ten years of using
>> POV-Ray are notable. Left, is the entry of 2008; right, the new version.
I agree for the vegetation, maybe the wheel, not really for the bricks.
However, my question would be: where does over-saturation come from?
It is strange. The original is - imo - strongly under-saturated.
Yes. You are perfectly right. Another reason to revisit the birds.
> profile.
Hmmm... I don't know how to achieve that...
Date: 21 Mar 2018 08:23:43
Message: <5ab24ecf$1@news.povray.org>
It looks better in most respects.  I see 3 areas that seem
over-corrected, though:
The corrosion on the plaque is overdone.  It's not that it's
unrealistic, but that the text is mostly illegible.
The vegetation, while in isolation it looks better than the original, is
distracting from the composition (for that very reason).
The new skin tones look overly saturated, although they are better than
in the original.
Date: 21 Mar 2018 09:07:48
Message: <5ab25924$1@news.povray.org>
Am 3/21/2018 um 13:11 schrieb Thomas de Groot:
Gamma! In the ancient time of MegaPOV and its unawareness of gamma
handling you as the user had to tweak scene colors and lighting to
compensate for the resulting inconsistency. Now with proper gamma
handling but some of these *tweaks* making it over results in
over-saturation and slightly hue shifts - as to be expected.
Yes, I agree - saturation is certainly also a matter of taste -
personally I can live with under-saturation better than with
over-saturation.
Contemporary versions of Photoshop and Lightroom do this auto-magical,
older version if you told them to do so and I'm under the assumption
this is also true for other software like Gimp or Paintshop. I do not
use the latter so maybe I'm wrong?
-Ive
