POV-Ray : Newsgroups : povray.binaries.images : Gem cuts preview Server Time
27 Sep 2024 03:33:15 EDT (-0400)
  Gem cuts preview (Message 1 to 10 of 19)
Subject: Gem cuts preview
Date: 7 Dec 2017 18:02:26
Message: <5a29c882$1@news.povray.org>
I was working on a gem cuts module for the Object Collection when
Hurricane Irma struck.  The module was essentially finished, but
required testing and documentation.
Alas, I have made very little progress in the past 3 months, and while I
am in Florida, I prioritized other things.  Like finishing an online
backup (also interrupted by Irma) and catching up on YouTube.  Rather
than upload a partially tested module with incomplete documentation, or
trying to rush everything to completion in the short time I have (a sure
recipe for a broken module), I'll just leave this sneak preview.
It occurred to me there may be a non-zero probability of being able to
upload the module via my phone.  I'll try that later; however, even if I
succeed, I won't be able to post a notice to the newsgroups until I get
home Internet back.
Download 'gemcuts.jpg' (99 KB)
Preview of image 'gemcuts.jpg'
Subject: Re: Gem cuts preview
Date: 13 Dec 2017 03:55:00
Message: <web.5a30ea441b2dab2a16086ed00@news.povray.org>
> home Internet back.
Courage for the hacking... If you do manage to commit (to GIT?) from an android
phone, I would be interested to know how.
The image is promissing, but too bright:
is gamma correct?
are albedo and conserve_energy used?
are specular / mirror intensity values realistic ones?
with darker lighting and a more punctual one, caustics will contrast more.
Date: 13 Dec 2017 12:05:49
Message: <5a315ded$1@news.povray.org>
>> home Internet back.
> is gamma correct?
Maybe using textures from metals.inc. Those have insane ambient values.
Should change them to ambient 0.
Date: 21 Dec 2017 11:35:04
Message: <web.5a3be1931b2dab2a93ab27150@news.povray.org>
Once again, using someone else's computer; I hope this goes through.
If I commit, it will be through the Object Collection uploader. I'll let Le
Forgeron worry about GitHub.
> is gamma correct?
My gamma is always 1.0, and I always use conserve_energy.
I did not albedo, because I want the example to run in pre-3.7 scenes. Both
gemstones use an entirely transparent pigment, so the diffuse value is
irrelevant. For the specular value, I precalculated a base value using the
albedo formula in parstxtr.cpp, and then reduced it according to a formula I
developed to /estimate/ the Fresnel effect.
I will consider lowering the lighting and using a darker wood for the table. I
Date: 21 Dec 2017 11:40:05
Message: <web.5a3be3021b2dab2a93ab27150@news.povray.org>
> > is gamma correct?
Alain, you know me better than that!
I used very low ambient and diffuse values.  I didn't use zero, because I'm not
using blurred reflection.  (My focus for this module is the modeling, not the
textures.)
Date: 21 Dec 2017 22:54:58
Message: <5a3c8212$1@news.povray.org>
>>> is gamma correct?
> textures.)
Even without blured reflection, using ambient >0 for metals is not
realistic.
Date: 21 Dec 2017 22:58:32
Message: <5a3c82e8$1@news.povray.org>
>> is gamma correct?
I think he mean smaller area_light, using a point light, or not adding
photons{area_light} to an area_light.
Date: 27 Dec 2017 11:35:04
Message: <web.5a43cb2e1b2dab2a93ab27150@news.povray.org>
> >>> is gamma correct?
> > textures.)
> realistic.
You know, it's rather frustrating when you notice you made a mistake, but can't
respond for another 6 days.  I used radiosity in that scene; there is no
ambient, period!
I did put a diffuse of 0.035 on the metals.  I did a render last night with zero
diffuse, and there is hardly a difference in appearance.
Download 'gemcuts-cam0-diffuse0.jpg' (48 KB)
Preview of image 'gemcuts-cam0-diffuse0.jpg'
Date: 27 Dec 2017 11:40:07
Message: <web.5a43cc1f1b2dab2a93ab27150@news.povray.org>
I used no area lights in that render.
Date: 27 Dec 2017 11:50:06
Message: <web.5a43ce0e1b2dab2a93ab27150@news.povray.org>
> is gamma correct?
I played with the lighting and the environment.  Since I can't use my newsreader
right now, I will have to upload the images one at a time.
This one has dimmed lighting.
Download 'gemcuts-cam0-dimlight.jpg' (42 KB)
Preview of image 'gemcuts-cam0-dimlight.jpg'
