![](/i/fill.gif) |
For some strange reason, it seems I am unable to change the location of
the two colors inside my pigment_maps ("MyHull" texture and "MyInterior"
texture, both at the top of the code), even when changing the numeric
values. Strange.
Can anyone of you test and find out, if you encounter the same problem?
#declare MyHullOutsideBottom = texture
pigment { color rgbt < 0.8039216, 0.5882353, 0.29411765, 0.00 > }
// 1.0, 0.0, 0.0
#declare MyHullOutsideTop = texture
pigment { color rgbt < 0.4039216, 0.1882353, 0.09411765, 0.75 > }
#declare MyHull = texture
gradient y
texture_map
[ 0.00 MyHullOutsideBottom ] // Hull Bronze_Metal /**/
[ 0.45 MyHullOutsideBottom ] // Hull
/* [ 0.25 MyHullOutsideTop ] // Lower Deck Window Stripe
[ 0.28 MyHullOutsideTop ] // Lower Deck Window Stripe
[ 0.28 MyHullOutsideBottom ] // Cupola Base
[ 0.35 MyHullOutsideBottom ] // Cupola Base
[ 0.35 MyHullOutsideTop ] // Cupola
[ 0.42 MyHullOutsideTop ] // Cupola
[ 0.42 MyHullOutsideBottom ] // Cupola Railing
[ 0.52 MyHullOutsideBottom ] // Cupola Railing
*/ [ 0.45 MyHullOutsideTop ] // Cupola
[ 1.00 MyHullOutsideTop ] // Cupola
translate < 0.0, -4.8812, 0.0 >
scale -1.0*(4.8812*2.85)
#declare MyHullInsideBottom = texture
pigment { color rgb < 0.7843137, 0.654902, 0.4156863 > }
#declare MyHullInsideTop = texture
#declare MyInterior = texture
gradient y
texture_map
[ 0.00 MyHullInsideBottom ] // Hull Bronze_Metal /**/
[ 0.45 MyHullInsideBottom ] // Hull
/* [ 0.25 MyHullInsideTop ] // Lower Deck Window Stripe
[ 0.28 MyHullInsideTop ] // Lower Deck Window Stripe
[ 0.28 MyHullInsideBottom ] // Cupola Base
[ 0.35 MyHullInsideBottom ] // Cupola Base
[ 0.35 MyHullInsideTop ] // Cupola
[ 0.42 MyHullInsideTop ] // Cupola
[ 0.42 MyHullInsideBottom ] // Cupola Railing
[ 0.52 MyHullInsideBottom ] // Cupola Railing
*/ [ 0.45 MyHullInsideTop ] // Cupola
[ 1.00 MyHullInsideTop ] // Cupola
camera
/*ultra_wide_angle*/ //angle 20
location < -25.0 , 0.0 , 0.0 >
//right x*image_width/image_height // not needed for v3.8
look_at < 0.0 , 0.0 , 0.0 >
light_source
< -500.0, 100.0, 500.0 >
color 1.0 * 1.3//< 1.0, 0.62353, 0.46667 >*2
#declare HomeBasic = blob
threshold 0.35
sphere { < 0.0, 0.0, 0.0 > 26.00 1.85 scale < 1.01, 0.25, 1.01 > } //
9.7624 meter tall (-4.8812 m to 4.8812 m) and exactly 19 meter usable
inside radius (38 meter diameter)
cylinder { < 0.0, 0.0, 0.0 > < 19.0, 0.0, 0.0 > 4.5 0.85 rotate < 0.0,
000.0, 0.0 > }
120.0, 0.0 > }
240.0, 0.0 > }
#declare HomeExact = difference
object { HomeBasic }
cylinder { < 20.0, 0.0, 0.0 > < 25.0, 0.0, 0.0 > 5.0 rotate < 0.0,
000.0, 0.0 > }
120.0, 0.0 > }
240.0, 0.0 > }
#declare HomeNegative = difference
box { < -25.0, -10.0, -25.0 > < 25.0, 10.0, 25.0 > }
object { HomeExact }
#declare MyInteriorWalls = difference
// cylinder { < 0.0, 4.8812, 0.0 > < 0.0, 4.9812, 0.0 > 05.0 pigment
{ color rgb < 0.5098039, 0.3137255, 0.2156863 > } } // Ceiling -
5.0812 m above main deck
cylinder { < 0.0, -1.30, 0.0 > < 0.0, -1.20, 0.0 > 24.0 pigment { color
rgb < 0.5098039, 0.3137255, 0.2156863 > } } // Main Deck - usable
diameter: exactly 19 meters/units - deck thickness: 0.1 meters/units
cylinder { < 0.0, -4.30, 0.0 > < 0.0, -4.20, 0.0 > 10.0 pigment { color
rgb < 0.5098039, 0.3137255, 0.2156863 > } } // Bottom Deck - usable
diameter: exactly 19 meters/units - ceiling height: exactly 3 meters /units
union
box { < 10.0, -4.2, -0.05 > < 25.0, -1.3, 0.05 > rotate < 0.0, 000.0,
0.0 > }
box { < 10.0, -4.2, -0.05 > < 25.0, -1.3, 0.05 > rotate < 0.0, 030.0,
0.0 > }
box { < 10.0, -4.2, -0.05 > < 25.0, -1.3, 0.05 > rotate < 0.0, 060.0,
0.0 > }
box { < 10.0, -4.2, -0.05 > < 25.0, -1.3, 0.05 > rotate < 0.0, 090.0,
0.0 > }
box { < 10.0, -4.2, -0.05 > < 25.0, -1.3, 0.05 > rotate < 0.0, 120.0,
0.0 > }
box { < 10.0, -4.2, -0.05 > < 25.0, -1.3, 0.05 > rotate < 0.0, 150.0,
0.0 > }
box { < 10.0, -4.2, -0.05 > < 25.0, -1.3, 0.05 > rotate < 0.0, 180.0,
0.0 > }
box { < 10.0, -4.2, -0.05 > < 25.0, -1.3, 0.05 > rotate < 0.0, 210.0,
0.0 > }
box { < 10.0, -4.2, -0.05 > < 25.0, -1.3, 0.05 > rotate < 0.0, 240.0,
0.0 > }
box { < 10.0, -4.2, -0.05 > < 25.0, -1.3, 0.05 > rotate < 0.0, 270.0,
0.0 > }
box { < 10.0, -4.2, -0.05 > < 25.0, -1.3, 0.05 > rotate < 0.0, 300.0,
0.0 > }
box { < 10.0, -4.2, -0.05 > < 25.0, -1.3, 0.05 > rotate < 0.0, 330.0,
0.0 > }
texture { MyHullInsideBottom }
rotate < 0.0, 15.0, 0.0 >
object { HomeNegative }
#declare HomeHollow = difference
object { HomeExact texture { MyHull } }
object { HomeExact scale < 0.999,0.996,0.999 > texture { MyInterior }
/*pigment { color rgbt < 0.8039216, 0.5882353, 0.29411765, 0.00 > }*/ }
#declare HomeWithInterior = union
object { HomeHollow }
object { MyInteriorWalls }
#declare LightsOrangeRings = union
torus { 2.475 0.025 rotate < 0.0, 0.0, 90.0 > translate < 20.0, 0.0,
0.0 > rotate < 0.0, 000.0, 0.0 > }
0.0 > rotate < 0.0, 120.0, 0.0 > }
0.0 > rotate < 0.0, 240.0, 0.0 > }
pigment { color rgb < 0.8784314, 0.2, 0.003921569 > }
finish { emission 1.0 }
#declare HomeLights = union
object { HomeWithInterior }
object { LightsOrangeRings }
light_source
< 0.0, 5.5, 0.0 >
color rgb 0.2
// cylinder { < 0.0, -1.3, 0.0 > < 0.0, -1.19, 0.0 > 19.0 pigment {
color rgb < 0.145098, 0.1921569, 0.05882353 > } } // measuring deck
diameter (do not use)
object { HomeLights scale 0.8 translate < 0.0, 0.0, 0.0 > rotate < 0.0,
000.0, 0.0 >}
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
![](/i/fill.gif) |
