test my cloud with a sculpted mountain
Download 'mountain scene1 4.png' (99 KB)
Preview of image 'mountain scene1 4.png'
rendered from high altitude
Download 'mountain scene2 1.png' (262 KB)
Preview of image 'mountain scene2 1.png'
On 01.12.2017 02:48, And wrote:
> Sven Littkowski <I### [at] SvenLittkowskiname> wrote:
>> On 01.12.2017 01:32, And wrote:
>>> I give you some value:
>>> The size is radius, I post a picture, can find some value on it.
>> Hi, big thanks.
>> As I understand it, I need to add this media into the declaration of
>> each sun, is that correct? And if so, would the sun sphere need to be
>> hollow?
>> http://www.avg.com
> Sun...no, this is for cloud.
Olala! Thanks for telling me. Will try it out. :-) :-D
But we need to find a way, to get a glow around the two suns, too.
Is there any location, where "this" and "dens_cloud" are defined? I
feel, I am missing some previous code here. :-)
http://www.avg.com
On your last (high-attitude) cloud image, i would apply a tiny scale
attribute to your clouds. make them just a little bit flatter, maybe 10
to 20% only.
Your low-attitude cloudy-mountains image shows clouds that are not dense
enough in their center, not hiding the mountains well enough yet. I
believe, if you increase the density inside the centers, you should be
finished with the cloud coding. :-)
http://www.avg.com
> to 20% only.
Hmm really?
My approach will not allow me to rise the density much more, or it shows more
artifact. That's one of what I said the limit of the media previous. It can
simulate not so dense cloud, but more density it can't.
The two pictures that I last post is in the same cloud setting. Just change the
camera position. I want to express that my approach can simulate cloud nearing
the physical reality, not just an inconstant result.
> http://www.avg.com
> http://www.avg.com
"dens_cloud" is mine. It outputs the shape of the cloud from a function, I
usually use function to control the pattern. You can use your own density
pattern instead.
#include "functions.inc"
#declare f_test =
function(x,y,z) {
0.32*sum(i, 0, 4, pow(abs(f_noise3d(x*pow(2, i)/0.4, y*pow(2, i)/0.4, z*pow(2,
i)/0.4)), 2.5)/pow(2.0, i) )
#declare f_cloud_base =
function(x,y,z) {
0.5 - f_test(x,y,z)*3*3*z*exp(-3*z) - 0.32*3*3*z*exp(-3*z)
#declare dens_cloud =
density{
function{0.5 - 0.2*f_cloud_base(x,y,z)}
color_map{
[0 rgb 0]
[0.5 rgb 0]
[0.56 rgb 1]
[1 rgb 1]
Sunset:
this image I just assigned scattering media for the cloud. You can see the cloud
is too dark.
Even I set the extinction smaller than 1.0(this is equal emission some lights)
// cloud
box{
<-5.01, -5.01, 0>, <5.01, 5.01, 1>
hollow
material{
texture{
pigment{rgbt<0,0,0,1>}
finish{ambient 0 diffuse 0}
interior {
media{
samples 8
scattering{
3, rgb< 1.00, 0.784, 0.746 >*8.0 //8.0
extinction 0.8
density {
dens_cloud
scale 2
translate <0,0,0.4>
Download 'mountain scene2 1 sunset only scattering.png' (164 KB)
Preview of image 'mountain scene2 1 sunset only scattering.png'
> Sunset:
> is too dark.
Too dark is caused by lacking of multiple scattering, so I fill-in some light
with emission for it.
material{
texture{
interior {
media{
samples 8
emission rgb<3.73, 2.92*0.75*0.161, 2.78*0.65*0.01 >*0.15
density {
dens_cloud2
media{
samples 8
emission rgb<1.00, 0.784*0.75*0.161, 0.746*0.65*0.01 >*1.0
// notice this is
// vdot(<1.00, 0.784*0.75, 0.746*0.65>,
// <1.00, 0.161, 0.01>)
// ^^^^^^^^^^^^^^^^^^^ this is my sun color
scattering{
3, rgb< 1.00, 0.784, 0.746 >*8.0 //this is the same, not change
extinction 0.8
density {
dens_cloud
for the sunset I use rgb<1.00,0.161,0.01>*strength for my parallel light as sun
light. It is from a sunset photo, I measured the color.
Download 'mountain scene2 1 sunset.png' (181 KB)
Preview of image 'mountain scene2 1 sunset.png'
> > Sunset:
> > is too dark.
Another view:
Download 'mountain scene2 2.png' (78 KB)
Preview of image 'mountain scene2 2.png'
