"Norbert Kern" <nor### [at] t-onlinede> wrote:
> probably you overcame the texture fit problem.
> If not I can recommend proximity pattern by using an ambient occlusion render
> together with the usage of Rune's illusion code. This method is fast and very
> precise for small details.
That's a beautiful image.
I'm a big fan of Rune's illusion.inc code. If I understand your method
correctly, it means generating an ambient occlusion render first (in whichever
way you want to go about that--a grayscale image, with the entire scene and
object using a temporary white pigment?) Then, using illusion.inc to
'camera-project' that AO render back onto the object's real texture, as an
additional overlay.
If I'm correct about the method, then the grayscale AO render first needs to be
taken into, say, Photoshop, to create an alpha-channel mask (using the *same*
image for that but inverted, to create transparency for the white parts of the
image.) *Then* it's overlayed onto the object, so that the real texture can show
through--except where the AO render has darker areas.
Correct so far? (I hope I'm making sense.) Or does your method use an actual
'proximity pattern' as well, in some way?
To Thomas: Nice work with your trials and experiments. I still haven't played
around with the proximity pattern code yet; real-life chores keep getting in the
way. Very irritating :-/
> additional overlay.
Thanks Kenneth.
I have used AO myself in other contexts but I never used (yet)
illusion.inc; the ToDo list is getting too long. ;-)
If your description of the method is correct, the draw back would be
that you have to produce a new transparency map for every new camera
setting or transformation to the object. This is not the case with the
DF3 method.
> additional overlay.
The AO render uses good radiosity settings, no background, a simple texture and
an emissive sphere like that:
sphere {
0, 10000
pigment {color rgb 1}
finish {emission 1.2 diffuse 0}
#declare T2 =
material {
finish {ambient 0 diffuse 0.8}
interior {ior 1}
No transparency is used.
Rune's Illusion code is used to create a pigment pattern with perfect fit for a
texture map:
//______________________________________________________________________________
// illusion
#declare illusion_image = "AO render.png" ///////////////////////
#declare illusion_scale = 10;
#declare illusion_samples = 50;
#declare illusion_location = <50,0,-201.5>; // camera location
#declare illusion_angle = 46; // camera angle
#declare illusion_look_at = <0,0,0>; // camera look at
#ifndef (illusion_location) #declare illusion_location = <0,0,0>; #end
#ifndef (illusion_right) #declare illusion_right =
image_width/image_height*x; #end
#ifndef (illusion_up) #declare illusion_up = y; #end
#ifndef (illusion_direction) #declare illusion_direction = z; #end
#ifndef (illusion_sky) #declare illusion_sky = y; #end
#ifndef (illusion_angle) #declare illusion_angle = degrees (atan2
(vlength (illusion_right)/2/vlength (illusion_direction),1))*2; #end
#ifndef (illusion_look_at) #declare illusion_look_at =
illusion_location+illusion_direction; #end
#ifndef (illusion_image) #debug "\n\n--> you must specify
'illusion_image'!\n\n" #end
#declare illusion_format = strlwr (substr (illusion_image,strlen
(illusion_image)-3,4))
#if (strcmp (illusion_format,".png") != 0 & strcmp (illusion_format,".tga") !=
0)
#debug concat (
"\n\n--> extension of illusion_image: ",
strlwr (substr (illusion_image, strlen (illusion_image)-3,4)),
"\n--> illusion_image must be a .png or .tga file!\n\n"
// CREATE THE IMAGE MAP USED IN THE ILLUSION
#ifdef (illusion_image_function)
#undef illusion_image_function
#declare illusion_image_function =
function {
#if (strcmp (illusion_format,".png") = 0)
pigment {image_map {png illusion_image gamma 2.2 once} translate
-0.5}
#else
pigment {image_map {tga illusion_image gamma 2.2 once} translate
-0.5}
// CREATE THE RAW ILLUSION ALIGNED ALONG Z AXIS
#declare illusion_raw =
average
pigment_map {
[1 function {illusion_image_function (x/z,y/z,z).red}
color_map {[0 rgb 0][1 rgb <4,0,0>]}]
[1 function {illusion_image_function (x/z,y/z,z).green}
color_map {[0 rgb 0][1 rgb <0,4,0>]}]
[1 function {illusion_image_function (x/z,y/z,z).blue}
color_map {[0 rgb 0][1 rgb <0,0,4>]}]
[1 function {illusion_image_function (x/z,y/z,z).transmit}
color_map {[0 rgb 0][1 transmit 4]}]
// ALIGNMENT CALCULATIONS
#declare illusion_t = illusion_location;
#declare illusion_z = vnormalize (illusion_look_at-illusion_location);
#declare illusion_x = vnormalize (vcross (illusion_sky, illusion_z))*tan
(radians (illusion_angle/2))*2;
#declare illusion_y = vnormalize (vcross (illusion_z, illusion_x))*tan (radians
(illusion_angle/2))*2*vlength (illusion_up)/vlength (illusion_right);
// CREATE AND ALIGN THE ILLUSION
#declare illusion =
illusion_raw
matrix <
illusion_x.x,illusion_x.y,illusion_x.z,
illusion_y.x,illusion_y.y,illusion_y.z,
illusion_z.x,illusion_z.y,illusion_z.z,
illusion_t.x,illusion_t.y,illusion_t.z
#declare f_illu = function {pigment {illusion}}
#declare T3 =
material {
pigment_pattern {
illusion_raw
matrix <
texture_map {
[0.5 copper3] // copper rust
[0.8 copper2] // copper patina
[0.9 copper2]
[1 copper1] // polished copper
interior {ior 1.6}
scale 1
Norbert
> texture and an emissive sphere like that:
> sphere {
> 0, 10000
> texture {
> #declare T2 =
> material {
> texture {
> interior {ior 1}
Yes, that make sense for the initial AO render. Thanks. Although, I'm not sure
what the reason is for interior{ior 1}.
My own 'fake AO' method-- actually just a few experiments years ago-- was to
have a similarly white object, but I also used a white plane under it, to pick
up the AO effect where the object met the plane. And a similar white outer
sphere--but used just as a background, and without radiosity(!). To create the
AO effect, I placed hundreds of point lights in a distant hemispherical pattern.
The many overlapping shadows on the object looked *similar* to a radiosity
render. But if I were to do it again, I would use your method ;-)
> for a texture map:
[snip]
Wow! I need to digest your code (your math trickery is something I need to
study; it uses techniques that I'm not too familiar with-- but that I really
need to learn and apply.) In all of my own uses of illusion.inc, I've never
actually tried 'mathematically' fitting the projected image to an object. I've
always done the opposite: choosing a pre-made digital photo image, then
constructing all the scene's geometry to 'fit' the photo details, when
'projected' onto the geometry! A very tedious procedure, I admit. Your code is
very much appreciated, as an alternative method for a different kind of use.
> DF3 method.
You're correct, if you intend to move the camera or object(s) around.
Illusion.inc is really for a pre-set static scene (more or less, which I'll
describe below.)
Basically, illusion.inc can be thought of a an old-style 'color slide
projector', placed *at* the POV-Ray scene's camera position. The projected image
fills the entire rendered frame--but you choose which objects in the scene to
apply the projected image onto. (Each object shows only that particular portion
of the full image 'texture'.) In other words, the *same* illusion.inc image is
'attached' to any/all of the objects. The visual effect of this is fundamentally
different from applying typical image_maps to the objects: The z-depth of the
individial objects doesn't matter-- the projected image itself will always
appear the same size on them, and undistorted, even on spherical objects (for
example.)
But here's a really interesting feature (the most important one, IMO): Although
the illusion.inc 'camera position' is supposed to match the scene's real
camera-- for the best undistorted image reproduction-- the scene camera CAN be
moved around (somewhat, within limits.) I've used this for some really cool
animations; the visual result is like a 3-D 'matte painting'.
A caveat: When trying to use illusion.inc for the first time, it can be a bit
confusing to understand, visually speaking. IMO, it has a few features that are
unnecessary and only 'get in the way.' I've re-written my own version, to remove
that stuff.
>> DF3 method.
> describe below.)
> example.)
I'm sure that you can use illusion.inc in animations. You would need to
run two animations. The first to generate the AO images the second to
use that in the final images. If you could create the alpha-channel mask
in PovRay. It might be possible to do it in a continuous three step
animation.
I too am a big fan of Rune's illusion.inc code.
Examples, please. :-)
Flaunt it. :-)
Regards
Gentlemen, you make it almost compulsory for me to try and use
illusion.inc :-) Time however...
Time however does not get any longer. ;-)
And speaking of illusion.inc
Rune's Particle System is worth having a look at too.
I once used it to create a Bagatelle scene years ago. I'm sure I posted
an animation to the newsgroup but cannot find it now.
Regards
Ah yes...! smoke, explosions, fountains... :-) I tested them out but did
not use them properly yet.
>> posted an animation to the newsgroup but cannot find it now.
But it's in your armoury, waiting, waiting...
Regards
