3. CONVERTING THE HI-RES 3D FILES INTO THE POV-RAY FORMAT
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
4. CREATING GROUND TEXTURES AND ATMOSPHERE
http://www.avg.com
5. MARS AREAS IN POV-RAY
http://www.avg.com
6. MARS BASE TYPES
http://www.avg.com
7. MARS BASE INFRASTRUCTURE
http://www.avg.com
8. MARS BASES
http://www.avg.com
Sven Littkowski <I### [at] SvenLittkowskiname> wrote:
> Intended as group project.
> Who wants to join?
I would probably be able to make sporadic contributions.
I think you'd need to decide on an infrastructure / global scene architecture.
Perhaps if you could describe / tabulate how many surface meshes there are, the
first thing to do might be to determine how best to tessellate them onto a
[pseudo-]sphere.
Then work out how to implement view frustum and back-face culling, so that only
the minimum amount of data needs to be loaded, parsed, and rendered.
Do you want to have multiple small static scenes?
Model the whole planet, but show only parts visible to the camera?
Do an animated fly-through?
I think that it would be an interesting long-term project to see how it would be
best to code such a large structure, and how to handle the data structures and
parsing of different detail levels in the scene.
Also, it would be interesting to see the development of an efficient workflow.
Perhaps Google Earth and other projects that already perform a similar function
would be good to study and learn from.
I would say that this might be applicable to
6. Defining base types (underground, craters, free buildings).
http://jcgt.org/published/0004/02/02/
has link to C++ code
architecture.
are, the
a
> [pseudo-]sphere.
that only
it would be
structures and
workflow.
function
Welcome aboard, Bald Eagle! Let's talk within this sub group about
everything.
Entire planet? No, too much data. Better to concentrate on a few
locations. no camera could capture the entire planet from within one
scene showing a base.
http://www.avg.com
> everything.
http://www.taumuon.co.uk/category/pov-ray
I was sort of thinking along the lines of
https://www.gamedev.net/articles/programming/general-and-gameplay-programming/introduction-to-octrees-r3529/
so that only the parts of the scene that would be visible to the camera would be
loaded (mesh include files) and rendered.
Perhaps a method of selecting an include file based on camera altitude could be
implemented (use a different file extension for different resolutions...)
That way you could have a single master scene file to write (and debug), and
everything could be stored in the same directory, and zipped.
I'd say that a POV-base ought to look like the POV-Ray logo :) There ought to
be small(er) initial and "temporary" intermediate structures (abandoned?) that
were used upon landing to receive building supplies and house workers while the
main base was being built.
Weather conditions on the surface would dictate the engineering of the structure
- probably a highly flattened dome, or a small entrance with the bulk of the
base being sub-surface.
My apologies - a lot of problems occurred in my life, I had to deal with
them. I still want to continue with this project, of course. :-)
http://www.avg.com
