On 29.07.2017 03:02, Thomas de Groot wrote:
> On 29-7-2017 1:17, Sven Littkowski wrote:
>> Please use my balloon texture for the outside, and let us know, if you
>> still get bumps.
> Has /this/ image been your balloon texture all along? Then, I am /not/
> surprised that you do not see any bumps: the image is completely black! ;
> Thomas
Hi, the problem was been solved already, but big thanks anyhow.
We found what was wrong, in fact it was a seldomly stupid error: I
forgot to change the QUALITY from 6 to a better level (using 10 now). :-)
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
The devil is in the detail :-)
On 7/29/2017 12:12 AM, Sven Littkowski wrote:
> On 27.07.2017 05:34, Stephen wrote:
>> >Has anyone collect Sven's code? I don't fancy going through the thread
>> >to piece it all together. And I've not been following it closely.
> #version 3.7;
> #include "kolors.inc"
Thanks but since you found the problem it is not needed now. :-)
Don't be embarrassed about the quality setting. These things happen.
Regards
Kenneth, here is the texture file, latest version.
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings - balloon texture.png' (1217 KB)
Preview of image 'space - launcher - balloon - type 001 - moon runnings - balloon texture.png'
Unfortunately, what I'm seeing is *almost* a completely black image, and with a
*completely* white alpha-channel. I checked it out in Photoshop.
I made some screen shots of what I'm seeing, and will post them in the IMAGES
section...
> section...
This is the images section, Kenneth. ;)
This is what I get after using "Edge Enhance" 8 times.
Regards
Download 'image3.png' (3663 KB)
Preview of image 'image3.png'
This image is way too dark! I used IC to clear it up by tone mapping
(Exponent 1 changed to 3)
btw, IC is: http://www.lilysoft.org/IC/ic_index.htm which is a perfect
little program I can recommend. No need for sophisticated programs when
doing simple image corrections.
Sorry, I didn't post the resulting image. Here it is.
Download 'balloon texture-1.jpg' (842 KB)
Preview of image 'balloon texture-1.jpg'
IC is a good image editor. Written by Ive, if I remember correctly.
Regards
> Okay, everyone: I herewith declare myself as a big fool!
> I use POV-Ray for soooo many years, since around 1990 or so, and can you
> believe it I just oversaw all the time of posting here, that I used:
> QUALITY = 6
> And did not even think about checking for the Q setting!!!!!
> SHAME ON ME! I wasted so much of your all valuable time! But at least,
> one more time the POV-Ray community has proven its great pioneer-alike
> spirit! I owe you all my big thanks!
I've had a hard time "debugging" a scene in the past, when I did the same thing.
I'd really like to see some mechanism - image file metadata or something else,
for tagging an image with certain critical data - it would help keep a handle on
things like this.
Maybe we just need a tiny little FAQ/checklist for debugging scenes - not
because I'm Captain Obvious - but because sometimes we read-through errors,
overlook things, or just plain old forget to check the very simplest of things.
Did you place the object IN the scene after #declaring it?
Do you have a light source?
A camera?
I play with "advanced" scenes all the time, but I still find myself from time to
time struggling with the very simplest of all elements of the SDL file and
command syntax. A reminder checklist is always helpful and always there,
whether anyone is online or not.
Glad to see you found your mistake, Sven. I hope you develop this into a very
nice scene :)
