Stephen <mca### [at] aolcom> wrote:
> On 7/26/2017 12:55 PM, Thomas de Groot wrote:
> > Close Encounters of the Third(?) Kind? :-)
Close. "The Greatest American Hero"
(With Robert Culp from I Spy (!) :O )
> That's what I was thinking.
> I thought that they would be earlier than the 80's.
Yes, but only slightly. 1977
Whoosh! That went completely over my head. Not only have I never heard
of the movie. The image looked like a neon tube mounted in an old
fashioned lampshade.
Regards
Am 26.07.2017 um 16:44 schrieb Stephen:
Given the state-of-the-art special effects back then, maybe it /was/ a
neon tube mounted in an old fashioned lampshade after all ;)
On 26.07.2017 07:28, Thomas de Groot wrote:
> On 26-7-2017 13:20, Thomas de Groot wrote:
>> On 26-7-2017 2:01, Sven Littkowski wrote:
>>> Latest Scene Code, Latest Bump, Latest Result
>>> (still no bumps)
>> I didn't change anything to your code and used the bump map provided,
>> and this is what I get: bumps *are* visible!
> Not entirely true ;-)
> I added:
> global_settings {
> assumed_gamma 1.0
> which was demanded by your kolors.inc (and for obvious reasons when
> using version 3.7) and I provided a uniform red colour texture for the
> balloon (as an image_map).
I am not understanding this. I added the assumed gamma (but kept the
texture as it is), and still nothing of the bump shows! I really want to
use an images as texture. Please try my scene with the assumed gama, and
post the resulting image.
I am attaching the scene code, the bump image, and the resulting scene
image.
#version 3.7;
#include "kolors.inc"
#include "finish.inc"
#include "textures.inc"
#declare MyRadiosity = off;
//#declare MyBackground = "SL_Space_Scene_003"; // Wormhole /
SL_Space_Scene_003 /
global_settings
#if(MyRadiosity)
radiosity
media on
pretrace_start 0.08
pretrace_end 0.001
count 400
error_bound 0.75
recursion_limit 1
normal on
assumed_gamma 1.0
subsurface {}
adc_bailout 0.0039
ambient_light rgb < 0.000, 0.000, 0.000 >
assumed_gamma 1.000
irid_wavelength rgb < 0.250, 0.180, 0.140 >
max_trace_level 5
number_of_waves 10
noise_generator 3
charset ascii
#declare LightDiameter = 10000.0;
#declare LightDistanceX = -500000.0; // X = Left - Right
#declare LightDistanceY = 1000000.0; // Y = Up - Down
#declare LightDistanceZ = -100000.0; // Z = Front - Back
#declare LightRotate = 36.0;
#declare MyLight = 0.125;
camera
location < -000.0, 400.0, -500.0 >
look_at < 0.0, -200.0, 0.0 >
right 1.77*x
light_source
< 2500.0, 2500.0, 500.0 > //< 2500.0, 2500.0, 5000.0 >
rgb < 0.72265625, 0.8046875, 0.80859375 > *1.5 // bright!?
area_light x*100,z*100,5,5 circular orient
area_illumination
light_source
< -50.0, 50.0, 0.0 >
rgb < 0.3, 0.4, 0.8 > *1.1
#declare MyLight = light_source
< -1000.0, 1000.0, 1000.0 >
rgb < 0.72265625, 0.8046875, 0.80859375 > *0.25
// spotlight
// point_at < 0.0, 25.0, 100.0 >
// falloff 100.0
// radius 10.0
// fade_distance 50.0
// fade_power 4
union
object { MyLight rotate < 0.0, 000.0, 0.0 > }
object { MyLight rotate < 0.0, 036.0, 0.0 > }
object { MyLight rotate < 0.0, 072.0, 0.0 > }
object { MyLight rotate < 0.0, 108.0, 0.0 > }
object { MyLight rotate < 0.0, 144.0, 0.0 > }
object { MyLight rotate < 0.0, 180.0, 0.0 > }
object { MyLight rotate < 0.0, 216.0, 0.0 > }
object { MyLight rotate < 0.0, 252.0, 0.0 > }
object { MyLight rotate < 0.0, 288.0, 0.0 > }
object { MyLight rotate < 0.0, 324.0, 0.0 > }
translate < -1000.0, 0000.0, -1000.0 >
#declare MyRadius = 200.0;
#declare PositiveBump = normal
bump_map
png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher - Balloon -
Type 001 - Moon Runnings - Balloon BumpMap.png"
translate -0.5
rotate < 90.0, 0.0, 0.0 >
scale MyRadius*2
bump_size 0.02
#declare NegativeBump = normal
bump_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher -
Balloon - Type 001 - Moon Runnings - Balloon BumpMap.png" map_type 0
interpolate 2 }
translate -0.5
scale -MyRadius*2
bump_size 0.04
#declare MyOuterBalloonFinish = finish
// reflection 0.00
crand 0.10
#declare MyInnerBalloonFinish = finish
brilliance 1.50
phong albedo 0.05
metallic 0.00
ambient 0.00
emission 0.00
reflection 0.50
#declare MyOuterBalloonTexture = texture
pigment
image_map
Type 001 - Moon Runnings - Balloon Texture.png"
gamma 1
map_type 0
interpolate 2
once
translate -0.5
scale MyRadius*2
normal
gradient y
normal_map
[ 0.175 PositiveBump ]
[ 0.175 NegativeBump ]
scale < 1.0, 1.5*MyRadius, 1.0 >
finish { MyOuterBalloonFinish }
#declare MyInnerBalloonTexture = texture
pigment { color rgb < 0.7686275, 0.7607843, 0.7333333 > }
normal
gradient y
normal_map
scale <1,1.5*MyRadius,1>
finish { MyInnerBalloonFinish }
#declare UpperBalloonShape = torus // Balloon Radius: 175 m /
Launcher Radius: 10 m
95.0, 105.0
scale < 1.0, 0.5, 1.0 >
#declare LowerBalloonShape = difference
sphere { < 0.0, 0.0, 0.0 > MyRadius }
cylinder { < 0.0, 0.0, 0.0 > < 0.0, 175.001, 0.0 > MyRadius+0.001 }
scale < 1.0, 1.5, 1.0 >
#declare MyBalloonHullOutside = union
object { UpperBalloonShape }
object { LowerBalloonShape }
texture { MyOuterBalloonTexture }
#declare MyBalloonHull = difference
object { MyBalloonHullOutside hollow }
cylinder // Launcher Openings
< 0.0, -((MyRadius*1.5)+0.001), 0.0 > < 0.0, (MyRadius+0.001), 0.0 > 3.5
texture { MyInnerBalloonTexture }
#declare Launcher = difference
union
#declare MyLength = 10.0;
#declare MyHeight = 0.0;
#declare MyTop = 35.0;
cylinder { < 0.0, -((MyRadius*1.5)+30.0), 0.0 > < 0.0, MyTop, 0.0 >
3.5 }
box { < MyLength, -MyHeight, -0.1 > < -MyLength, MyTop, 0.1 > rotate <
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
cylinder { < 0.0, -((MyRadius*1.5)+30.001), 0.0 > < 0.0, MyTop+0.001,
0.0 > 3.3 }
pigment { color rgb 1.0 }
#declare DoublePositionLight = union
union
cylinder { < 0.0, 0.0, 2.5 > < 10.0, 0.0, 2.5 > 0.20 }
cylinder { < 0.0, 0.0, -2.5 > < 10.0, 0.0, -2.5 > 0.20 }
pigment { color rgb < 0.05, 0.05, 0.05 > }
union
sphere { < 10.0, 0.0, 2.5 > 0.35 }
sphere { < 10.0, 0.0, -2.5 > 0.35 }
pigment { color rgbf < 1.0, 0.0, 0.0, 0.5 > }
finish { ambient rgb < 0.3, 0.1, 0.1 > }
union
light_source
< 10.0, 0.0, 2.5 >
rgb < 0.7, 0.0, 0.0 > *10.0
fade_distance 50.0
fade_power 4
light_source
< 10.0, 0.0, -2.5 >
rgb < 0.7, 0.0, 0.0 > *1.0
fade_distance 50.0
fade_power 4
#declare PositionLights = union
#declare MyDistance = MyRadius-0.1;
object { DoublePositionLight translate < MyDistance, 0.0, 0.0 > rotate
< 0.0, 045.0, 0.0 > }
< 0.0, 090.0, 0.0 > }
< 0.0, 135.0, 0.0 > }
< 0.0, 225.0, 0.0 > }
< 0.0, 270.0, 0.0 > }
< 0.0, 315.0, 0.0 > }
union
object { MyBalloonHull }
object { Launcher }
object { PositionLights }
background { rgb < 0.02392157, 0.03490196, 0.04627451 > }
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings.png' (172 KB)
Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png' (201 KB)
Preview of image 'space - launcher - balloon - type 001 - moon runnings.png'
Preview of image 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png'
Coming back into the cinemas. Alas they did not add the latest effects
and spaceship designs to that great movie. I've seen the original movie.
Great movie.
Still not getting any bumps, feeling very frustrated now. I want to keep
my texture image file, not replacing it with a single color.
Attached are scene code, bump image, and resulting bump-less scene
image. Are you people getting bumps the way it is?
#version 3.7;
global_settings
#if(MyRadiosity)
radiosity
media on
pretrace_start 0.08
pretrace_end 0.001
count 400
error_bound 0.75
recursion_limit 1
normal on
assumed_gamma 1.0
subsurface {}
adc_bailout 0.0039
assumed_gamma 1.000
max_trace_level 5
number_of_waves 10
noise_generator 3
charset ascii
camera
right 1.77*x
light_source
area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
bump_map
translate -0.5
scale MyRadius*2
bump_size 0.02
interpolate 2 }
translate -0.5
scale -MyRadius*2
bump_size 0.04
// reflection 0.00
crand 0.10
brilliance 1.50
phong albedo 0.05
metallic 0.00
ambient 0.00
emission 0.00
reflection 0.50
pigment
image_map
gamma 1
map_type 0
interpolate 2
once
translate -0.5
scale MyRadius*2
normal
gradient y
normal_map
normal
gradient y
normal_map
95.0, 105.0
union
3.5 }
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
0.0 > 3.3 }
union
union
union
light_source
< 10.0, 0.0, 2.5 >
fade_distance 50.0
fade_power 4
light_source
< 10.0, 0.0, -2.5 >
fade_distance 50.0
fade_power 4
union
object { Launcher }
http://www.avg.com
https://en.wikipedia.org/wiki/The_Greatest_American_Hero
Pretty sure it was lights on the bottom of a hot air balloon, which is why this
reminds me so much of it.
https://www.youtube.com/watch?v=e9Q3orQhEcA
Maybe Sven needs to add some light sources to the scene... :D
Am 26.07.2017 um 17:46 schrieb Sven Littkowski:
> Great movie.
At the moment, all seems to point at the pigment definition as the
culprit, as that's the only relevant thing we've always changed. You
should at least /try/ it with a plain pigment, to either confirm or
refute this theory.
If you can confirm it, we know that's what we have to examine further;
in that case you'll probably want to post the image map at last, so that
we can see what might be so special about it.
Otherwise we can be sure that it's a red herring, and that we have to
dig someplace else.
Am 26.07.2017 um 18:37 schrieb Bald Eagle:
You know you'll be going straight to The Hague for posting this, right?
I believe what's going on is your image map is too dark and there's no specular
highlight or phone home and load in your outer finish statement.
I'm not home to test that theory out.
> highlight or phong* in your outer finish statement.
* edited. note to self: don't talk to text these povray messages by smart phone!
