POV-Ray : Newsgroups : povray.binaries.images : QUESTION: Bump not showing? Server Time
17 Jun 2026 02:17:24 EDT (-0400)
  QUESTION: Bump not showing? (Message 41 to 50 of 91)
Subject: Re: QUESTION: Bump not showing?
Date: 26 Jul 2017 08:20:56
Message: <59788928$1@news.povray.org>
On 7/26/2017 12:55 PM, Thomas de Groot wrote:
> On 26-7-2017 13:45, Bald Eagle wrote:
>> Thomas de Groot <tho### [at] degrootorg> wrote:
>>> On 26-7-2017 2:01, Sven Littkowski wrote:
>>>> Latest Scene Code, Latest Bump, Latest Result
>>>> (still no bumps)
>>> I didn't change anything to your code and used the bump map provided,
>>> and this is what I get: bumps *are* visible!
>>> Thomas
>> This whole thing really reminds me of:
http://1.bp.blogspot.com/-IFTXBJQc0UU/VIHkNM5jKkI/AAAAAAAA2F8/yyWnsQBHmO4/s1600/gah1.jpg
>> Since it's from the 80's, maybe Yadgar will join this thread  ;)   :D
> Close Encounters of the Third(?) Kind? :-)
That's what I was thinking.
I thought that they would be earlier than the 80's.
Regards
Date: 26 Jul 2017 10:00:01
Message: <web.59789ff89f453b97c437ac910@news.povray.org>
Close.  "The Greatest American Hero"
(With Robert Culp from I Spy (!) :O )
Yes, but only slightly. 1977
Date: 26 Jul 2017 10:44:32
Message: <5978aad0$1@news.povray.org>
Whoosh! That went completely over my head. Not only have I never heard
of the movie. The image looked like a neon tube mounted in an old
fashioned lampshade.
Regards
Date: 26 Jul 2017 10:47:23
Message: <5978ab7b$1@news.povray.org>
Am 26.07.2017 um 16:44 schrieb Stephen:
Given the state-of-the-art special effects back then, maybe it /was/ a
neon tube mounted in an old fashioned lampshade after all ;)
Date: 26 Jul 2017 11:42:35
Message: <5978b86b@news.povray.org>
>>> (still no bumps)
> Not entirely true ;-)
> I added:
> global_settings {
>   assumed_gamma 1.0
> which was demanded by your kolors.inc (and for obvious reasons when
> using version 3.7) and I provided a uniform red colour texture for the
> balloon (as an image_map).
I am not understanding this. I added the assumed gamma (but kept the
texture as it is), and still nothing of the bump shows! I really want to
use an images as texture. Please try my scene with the assumed gama, and
post the resulting image.
I am attaching the scene code, the bump image, and the resulting scene
image.
#version 3.7;
#include "kolors.inc"
#include "finish.inc"
#include "textures.inc"
#declare MyRadiosity = off;
//#declare MyBackground = "SL_Space_Scene_003"; // Wormhole /
SL_Space_Scene_003 /
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
   normal on
 assumed_gamma 1.0
 subsurface        {}
 adc_bailout       0.0039
 ambient_light     rgb < 0.000, 0.000, 0.000 >
 assumed_gamma     1.000
 irid_wavelength   rgb < 0.250, 0.180, 0.140 >
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
#declare LightDiameter =     10000.0;
#declare LightDistanceX =  -500000.0; // X = Left - Right
#declare LightDistanceY =  1000000.0; // Y = Up - Down
#declare LightDistanceZ =  -100000.0; // Z = Front - Back
#declare LightRotate =          36.0;
#declare MyLight =             0.125;
camera
 location < -000.0, 400.0, -500.0 >
 look_at < 0.0, -200.0, 0.0 >
 right 1.77*x
light_source
 < 2500.0, 2500.0, 500.0 > //< 2500.0, 2500.0, 5000.0 >
 rgb < 0.72265625, 0.8046875, 0.80859375 > *1.5 // bright!?
 area_light x*100,z*100,5,5 circular orient
 area_illumination
light_source
 < -50.0, 50.0, 0.0 >
 rgb < 0.3, 0.4, 0.8 > *1.1
#declare MyLight = light_source
 < -1000.0, 1000.0, 1000.0 >
 rgb < 0.72265625, 0.8046875, 0.80859375 > *0.25
// spotlight
// point_at < 0.0, 25.0, 100.0 >
// falloff 100.0
// radius 10.0
// fade_distance 50.0
// fade_power 4
union
 object { MyLight rotate < 0.0, 000.0, 0.0 > }
 object { MyLight rotate < 0.0, 036.0, 0.0 > }
 object { MyLight rotate < 0.0, 072.0, 0.0 > }
 object { MyLight rotate < 0.0, 108.0, 0.0 > }
 object { MyLight rotate < 0.0, 144.0, 0.0 > }
 object { MyLight rotate < 0.0, 180.0, 0.0 > }
 object { MyLight rotate < 0.0, 216.0, 0.0 > }
 object { MyLight rotate < 0.0, 252.0, 0.0 > }
 object { MyLight rotate < 0.0, 288.0, 0.0 > }
 object { MyLight rotate < 0.0, 324.0, 0.0 > }
 translate < -1000.0, 0000.0, -1000.0 >
#declare MyRadius = 200.0;
#declare PositiveBump = normal
 bump_map
  png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher - Balloon -
Type 001 - Moon Runnings - Balloon BumpMap.png"
 translate -0.5
 rotate < 90.0, 0.0, 0.0 >
 scale MyRadius*2
 bump_size 0.02
#declare NegativeBump = normal
 bump_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher -
Balloon - Type 001 - Moon Runnings - Balloon BumpMap.png" map_type 0
interpolate 2 }
 translate -0.5
 scale -MyRadius*2
 bump_size 0.04
#declare MyOuterBalloonFinish = finish
// reflection   0.00
 crand        0.10
#declare MyInnerBalloonFinish = finish
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
#declare MyOuterBalloonTexture = texture
 pigment
  image_map
Type 001 - Moon Runnings - Balloon Texture.png"
   gamma 1
   map_type 0
   interpolate 2
   once
  translate -0.5
  scale MyRadius*2
 normal
  gradient y
  normal_map
   [ 0.175 PositiveBump ]
   [ 0.175 NegativeBump ]
  scale < 1.0, 1.5*MyRadius, 1.0 >
 finish { MyOuterBalloonFinish }
#declare MyInnerBalloonTexture = texture
 pigment { color rgb < 0.7686275,  0.7607843,  0.7333333 > }
 normal
  gradient y
  normal_map
  scale <1,1.5*MyRadius,1>
 finish { MyInnerBalloonFinish }
#declare UpperBalloonShape = torus     // Balloon Radius: 175 m /
Launcher Radius: 10 m
 95.0, 105.0
 scale < 1.0, 0.5, 1.0 >
#declare LowerBalloonShape = difference
 sphere { < 0.0, 0.0, 0.0 > MyRadius }
 cylinder { < 0.0, 0.0, 0.0 > < 0.0, 175.001, 0.0 > MyRadius+0.001 }
 scale < 1.0, 1.5, 1.0 >
#declare MyBalloonHullOutside = union
 object { UpperBalloonShape }
 object { LowerBalloonShape }
 texture { MyOuterBalloonTexture }
#declare MyBalloonHull = difference
 object { MyBalloonHullOutside hollow }
 cylinder  // Launcher Openings
  < 0.0, -((MyRadius*1.5)+0.001), 0.0 > < 0.0, (MyRadius+0.001), 0.0 > 3.5
  texture { MyInnerBalloonTexture }
#declare Launcher = difference
 union
  #declare MyLength = 10.0;
  #declare MyHeight = 0.0;
  #declare MyTop = 35.0;
  cylinder { < 0.0, -((MyRadius*1.5)+30.0), 0.0 > < 0.0, MyTop, 0.0 >
3.5 }
  box { < MyLength, -MyHeight, -0.1 > < -MyLength, MyTop, 0.1 > rotate <
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
 cylinder { < 0.0, -((MyRadius*1.5)+30.001), 0.0 > < 0.0, MyTop+0.001,
0.0 > 3.3 }
 pigment { color rgb 1.0 }
#declare DoublePositionLight = union
 union
  cylinder { < 0.0, 0.0,  2.5 > < 10.0, 0.0,  2.5 > 0.20 }
  cylinder { < 0.0, 0.0, -2.5 > < 10.0, 0.0, -2.5 > 0.20 }
  pigment { color rgb < 0.05, 0.05, 0.05 > }
 union
  sphere { < 10.0, 0.0, 2.5 > 0.35 }
  sphere { < 10.0, 0.0, -2.5 > 0.35 }
  pigment { color rgbf < 1.0, 0.0, 0.0, 0.5 > }
  finish { ambient rgb < 0.3, 0.1, 0.1 > }
 union
  light_source
   < 10.0, 0.0, 2.5 >
   rgb < 0.7, 0.0, 0.0 > *10.0
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   rgb < 0.7, 0.0, 0.0 > *1.0
   fade_distance 50.0
   fade_power 4
#declare PositionLights = union
 #declare MyDistance = MyRadius-0.1;
 object { DoublePositionLight translate < MyDistance, 0.0, 0.0 > rotate
< 0.0, 045.0, 0.0 > }
< 0.0, 090.0, 0.0 > }
< 0.0, 135.0, 0.0 > }
< 0.0, 225.0, 0.0 > }
< 0.0, 270.0, 0.0 > }
< 0.0, 315.0, 0.0 > }
union
 object { MyBalloonHull }
 object { Launcher }
 object { PositionLights }
background { rgb < 0.02392157,  0.03490196,  0.04627451 > }
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings.png' (172 KB) Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png' (201 KB)
Preview of image 'space - launcher - balloon - type 001 - moon runnings.png'
Preview of image 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png'
Date: 26 Jul 2017 11:46:29
Message: <5978b955@news.povray.org>
Coming back into the cinemas. Alas they did not add the latest effects
and spaceship designs to that great movie. I've seen the original movie.
Great movie.
Still not getting any bumps, feeling very frustrated now. I want to keep
my texture image file, not replacing it with a single color.
Attached are scene code, bump image, and resulting bump-less scene
image. Are you people getting bumps the way it is?
#version 3.7;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
   normal on
 assumed_gamma 1.0
 subsurface        {}
 adc_bailout       0.0039
 assumed_gamma     1.000
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 right 1.77*x
light_source
 area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
 bump_map
 translate -0.5
 scale MyRadius*2
 bump_size 0.02
interpolate 2 }
 translate -0.5
 scale -MyRadius*2
 bump_size 0.04
// reflection   0.00
 crand        0.10
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
 pigment
  image_map
   gamma 1
   map_type 0
   interpolate 2
   once
  translate -0.5
  scale MyRadius*2
 normal
  gradient y
  normal_map
 normal
  gradient y
  normal_map
 95.0, 105.0
 union
3.5 }
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
0.0 > 3.3 }
 union
 union
 union
  light_source
   < 10.0, 0.0, 2.5 >
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   fade_distance 50.0
   fade_power 4
union
 object { Launcher }
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png' (201 KB) Download 'space - launcher - balloon - type 001 - moon runnings.png' (172 KB)
Date: 26 Jul 2017 12:40:00
Message: <web.5978c52e9f453b97c437ac910@news.povray.org>
https://en.wikipedia.org/wiki/The_Greatest_American_Hero
Pretty sure it was lights on the bottom of a hot air balloon, which is why this
reminds me so much of it.
https://www.youtube.com/watch?v=e9Q3orQhEcA
Maybe Sven needs to add some light sources to the scene...   :D
Date: 26 Jul 2017 15:04:30
Message: <5978e7be$1@news.povray.org>
Am 26.07.2017 um 17:46 schrieb Sven Littkowski:
> Great movie.
At the moment, all seems to point at the pigment definition as the
culprit, as that's the only relevant thing we've always changed. You
should at least /try/ it with a plain pigment, to either confirm or
refute this theory.
If you can confirm it, we know that's what we have to examine further;
in that case you'll probably want to post the image map at last, so that
we can see what might be so special about it.
Otherwise we can be sure that it's a red herring, and that we have to
dig someplace else.
Date: 26 Jul 2017 15:17:58
Message: <5978eae6$1@news.povray.org>
Am 26.07.2017 um 18:37 schrieb Bald Eagle:
You know you'll be going straight to The Hague for posting this, right?
Date: 26 Jul 2017 21:20:01
Message: <web.59793eee9f453b97e85ccd120@news.povray.org>
I believe what's going on is your image map is too dark and there's no specular
highlight or phone home and load in your outer finish statement.
I'm not home to test that theory out.
