POV-Ray : Newsgroups : povray.binaries.images : Egg Server Time
27 May 2026 10:44:09 EDT (-0400)
  Egg (Message 41 to 44 of 44)
Subject: Re: Egg
Date: 3 May 2017 02:57:06
Message: <59097f42$1@news.povray.org>
On 2-5-2017 21:04, clipka wrote:
> Am 02.05.2017 um 08:51 schrieb Thomas de Groot:
>> On 2-5-2017 5:57, Alain wrote:
>> [snip]
>>> You should set it according to the overall scale of your scene.
>>> The default of 10 mean 1 POV unit = 1 cm. Set it to 1000 if your scale
>>> is 1 POV unit = 1 m, and 25.4 for 1 inch = 1 POV unit.
>>> In my suggestion, it would make a scene scalled in cm work in mm. So,
>>> you can change mm_per_unit from it's default of 10 to 1 to reflect the
>>> change in overall scale.
>> As I wrote in my answer to Stephen, I am shamefully negligent about
>> overall scales and just throw together elements to be brewed in the same
>> pot. I need to be a bit more careful if I want to include SSLT. :-)
> Technically, you only need to be careful if you intend to re-use (or
> have others re-use) your SSLT stuff in any other scene.
> For instance, if you've concocted a convincing ivory material, that
> ivory material will only look convincing in other scenes if both your
> original scene and the new scene have proper mm_per_unit settings (or if
> both have the mm_per_unit setting screwed up by the same factor).
Yes, that was what I thought indeed.
Subject: Re: Egg
Date: 6 May 2017 06:51:46
Message: <590daac2@news.povray.org>
As far as I am concerned, the final version. I streamlined the code for
better reproducibility, made an area_light of the spotlight, and
increased the translucency of the cube. Using: +am3 +a0.01 +ac0.95 +r4
Download 'sslt_test_uber_final.png' (673 KB)
Preview of image 'sslt_test_uber_final.png'
Subject: Re: Egg
Date: 6 May 2017 07:03:24
Message: <590dad7c$1@news.povray.org>
Excellent job.
Regards
Subject: Re: Egg
Date: 7 May 2017 03:02:36
Message: <590ec68c@news.povray.org>
> Excellent job.
Thanks indeed. For the curious, I am going to put the material macros
used in p.t.scene-files.
