POV-Ray : Newsgroups : povray.binaries.images : Egg Server Time
28 Sep 2024 09:16:55 EDT (-0400)
  Egg (Message 35 to 44 of 44)
Subject: Re: Egg
Date: 2 May 2017 15:04:19
Message: <5908d833$1@news.povray.org>
Am 02.05.2017 um 08:51 schrieb Thomas de Groot:
> On 2-5-2017 5:57, Alain wrote:
> [snip]
>> You should set it according to the overall scale of your scene.
>> The default of 10 mean 1 POV unit = 1 cm. Set it to 1000 if your scale
>> is 1 POV unit = 1 m, and 25.4 for 1 inch = 1 POV unit.
>> In my suggestion, it would make a scene scalled in cm work in mm. So,
>> you can change mm_per_unit from it's default of 10 to 1 to reflect the
>> change in overall scale.
> As I wrote in my answer to Stephen, I am shamefully negligent about
> overall scales and just throw together elements to be brewed in the same
> pot. I need to be a bit more careful if I want to include SSLT. :-)
Technically, you only need to be careful if you intend to re-use (or
have others re-use) your SSLT stuff in any other scene.
For instance, if you've concocted a convincing ivory material, that
ivory material will only look convincing in other scenes if both your
original scene and the new scene have proper mm_per_unit settings (or if
both have the mm_per_unit setting screwed up by the same factor).
Subject: Re: Egg
Date: 2 May 2017 15:05:55
Message: <5908d893$1@news.povray.org>
On 5/2/2017 7:52 PM, clipka wrote:
> Am 01.05.2017 um 14:06 schrieb Stephen:
>> My understanding is that the mm_per_unit is the world/scene scale
> Indeed.
> Also, I might take the opportunity to re-iterate that it is not an SSLT
> setting /per se/. It only just so happens that SSLT is currently the
> only feature that makes use of it.
Yet? :-)
Regards
Subject: Re: Egg
Date: 2 May 2017 15:44:06
Message: <5908e186@news.povray.org>
Am 02.05.2017 um 10:03 schrieb Stephen:
>> Ah! The Clipka! He seems to have gone on holiday? Shame. He /knows/ he
>> cannot go without our permission. ;-)
> As long as he hasn't taken a marching band with him. It is okay. ;-)
Nah, no marching band for me yet.
But eight bells for someone dear.
Subject: Re: Egg
Date: 2 May 2017 15:49:00
Message: <5908e2ac$1@news.povray.org>
Sorry to hear that. :-(
Regards
Subject: Re: Egg
Date: 3 May 2017 02:50:39
Message: <59097dbf$1@news.povray.org>
Well, I am very sorry to hear that, Christoph. You have my sincere support.
Subject: Re: Egg
Date: 3 May 2017 02:54:55
Message: <59097ebf$1@news.povray.org>
On 2-5-2017 20:47, clipka wrote:
> Am 30.04.2017 um 13:05 schrieb Thomas de Groot:
>> Question: In the wiki about SSLT it is said: "The effect doesn't scale
>> with the object". Does this mean that SSLT works in the same way as a
>> scattering media where the amount of scattering has to be compensated
>> for the amount of media object's scale? It appears so to me at least
>> although this is not mentioned in the wiki.
> That depends on what you want to achieve.
> If you want the object to look like a larger item made of the same
> material, scale the object and use the same SSLT parameters.
> If you want the object to look exactly the same, but take up a larger
> portion on the screen, scale the object and adjust the SSLT parameters.
> (Or zoom in on the object ;))
Hmmm... yes, that is well put. I guess I have to ponder this a bit and
add it to my own little reminders.
Thanks a lot!
Subject: Re: Egg
Date: 3 May 2017 02:57:06
Message: <59097f42$1@news.povray.org>
>> [snip]
Yes, that was what I thought indeed.
Subject: Re: Egg
Date: 6 May 2017 06:51:46
Message: <590daac2@news.povray.org>
As far as I am concerned, the final version. I streamlined the code for
better reproducibility, made an area_light of the spotlight, and
increased the translucency of the cube. Using: +am3 +a0.01 +ac0.95 +r4
Download 'sslt_test_uber_final.png' (673 KB)
Preview of image 'sslt_test_uber_final.png'
Subject: Re: Egg
Date: 6 May 2017 07:03:24
Message: <590dad7c$1@news.povray.org>
Excellent job.
Regards
Subject: Re: Egg
Date: 7 May 2017 03:02:36
Message: <590ec68c@news.povray.org>
> Excellent job.
Thanks indeed. For the curious, I am going to put the material macros
used in p.t.scene-files.
