POV-Ray : Newsgroups : povray.binaries.images : Holes in isosurface Server Time
28 Apr 2024 17:44:44 EDT (-0400)
  Holes in isosurface (Message 11 to 16 of 16)
Subject: Re: Holes in isosurface
Date: 8 Mar 2017 11:57:48
Message: <58c0380c$1@news.povray.org>
I am having the same problem in a different scene posted in p.t.s-f.
This time I used "evaluate" from the start. Render times are long but
artifacts still appear.
Mike
Date: 8 Mar 2017 11:58:01
Message: <58c03819$1@news.povray.org>
On 3/8/2017 10:02 AM, Bald Eagle wrote:
> I haven't had a chance to look over the isosurface functions, but it looks like
> the final shape is a parallelpiped.
> If so, couldn't you just make a box and shear it in all 3 directions?
> Simpler and lots faster, if that's the case.
> I enjoy these color models you work on.
> They are very pleasing to my eye.
> Keep up the good work!  :)
No, I don't want to do this.
Mike
Date: 8 Mar 2017 12:52:01
Message: <58c044c1$1@news.povray.org>
> Mike
Disregard.
Mike
Date: 8 Mar 2017 13:20:00
Message: <web.58c04a33bd2eb8ad9c5d6c810@news.povray.org>
Yow! I used max_gradient alone to see what POV-Ray was saying it wanted that to
be and its way beyond what the other isosurface evaluate parameters were.
Which BTW I finally ended up using MinFactor=0.7 to prevent any missing portions
of that one.
This current isosurface using max_gradient 10000 (sans evaluate) is rendering 5
minutes at only 160X120 resolution, incomplete of course.
Render message told me it needed max_gradient 7131910.500, so that really puts
the evaluate numbers up there and the render time is obviously going to increase
dramatically.
Sorry I don't have a solution, can only tell you that much. If there's a way to
reduce render times and still get a complete isosurface for this one I sure
don't know the answer. Unless something can be manipulated to do so and someone
else knows how to go about it anyway.
Date: 8 Mar 2017 15:55:25
Message: <58c06fbd$1@news.povray.org>
> of that one.
> dramatically.
> Bob
I think clipka told me to use this:
	#declare cie_fClip1 = function(X,A) {select(X-A,A,X)}
	#declare cie_fClip2 = function(X,A) {select(-(X-A),A,X)}
	#declare cie_fD = function(C)
{abs(cie_fClip2(cie_fClip1(C,-0.1),1.1)-0.5)-0.5}
instead of this:
	#declare cie_fD = function(C) {abs(C-0.5)-0.5}
as a workaround.
Mike
Date: 25 Mar 2017 04:24:35
Message: <58d62943@news.povray.org>
On 3/7/2017 12:21 PM, Mike Horvath wrote:
> I am trying to render the following isosurface.
> isosurface
>     function {fFinal(fInpX(x,y,z),fInpY(x,y,z),fInpZ(x,y,z))}
>     threshold    0
>     accuracy    0.001
>     contained_by
>         box {0,1}
>     max_gradient    50    // was 20000
> However, from certain angles there appear gaps or cuts in the surface,
> and you can see inside. The gaps disappear when viewed from other angles.
> Does anyone have any tips on how to fix this? I already tried scaling by
> 200 but it does not help.
> Mike
I wish I could replace these with meshes. Then I could make an animation
with many frames.
Mike
