POV-Ray : Newsgroups : povray.binaries.images : Another of Gamma's Smoking Guns Server Time
18 May 2024 14:26:17 EDT (-0400)
  Another of Gamma's Smoking Guns (Message 11 to 13 of 13)
Subject: Re: Another of Gamma's Smoking Guns
Date: 27 Dec 2016 15:30:01
Message: <web.5862ced071b7ed6e883fb31c0@news.povray.org>
> You can think of "srgb C" as (roughly) equivalent to "rgb pow(C,2.2)",
> i.e. very roughly squaring the colour value. As you may be aware, the
> square of a (positive) value below 1 is an even smaller value, while the
> square of a value above 1 is an even larger value.
Ah, of course; that makes perfect sense (now that you've explained it, ha!)
> BTW, there's a caveat when using "srgb" in light sources: To modify the
> brightness without affecting the hue, you need to use
>     colour (srgb <R,G,B>)*Brightness
> rather than
>     colour srgb <R,G,B>*Brightness
> because the latter would be interpreted as
>     colour srgb (<R,G,B>*Brightness)
Wow, that's a subtle difference that I wasn't aware of. Thanks! I'm curious--
would the same logic apply to colors in MEDIA? Or does the above formula apply
*only* to lights?
Date: 27 Dec 2016 17:25:01
Message: <web.5862ea2971b7ed6e82fed3640@news.povray.org>
> Am 27.12.2016 um 09:21 schrieb Kenneth:
> > I decided to run your test scene with assumed_gamma 1.0 instead of 2.2, and
> > noticed something about your use of 'rgb' in the light_source. I changed it to
> > srgb (which I've started doing in all my v3.7xx scenes, to be 'color-consistent'
> rather than
> and in the sRGB world multiplying a colour vector by a constant does
> /not/ correspond to an even scaling of the corresponding linear colour
> components. (That would work for f(x)=pow(x,2.2), but sRGB gamma is more
> complicated than that.)
The moral seems to be get all of your srgb declarations out of the way as early
as possible--including before you do any math on such colors.
Date: 27 Dec 2016 17:26:16
Message: <5862ea88$1@news.povray.org>
Am 27.12.2016 um 21:28 schrieb Kenneth:
I'm just noticing that this syntax actually doesn't work; you'll need to use
    #declare C = srgb <R,G,B>;
    colour C * Brightness
>> rather than
> *only* to lights?
It applies anywhere you want to change the "magnitude" (be it
brightness, density or whatever) of a colour by a factor while retaining
the same hue and saturation.
What /is/ perfectly ok is dividing sRGB colour data for the purpose of
normalizing it to the range [0..1] when the "raw" data is normalized for
another range, e.g.:
    srgb <0,192,255>/255
