POV-Ray : Newsgroups : povray.binaries.images : looks_like Server Time
27 May 2026 08:45:12 EDT (-0400)
  looks_like (Message 1 to 10 of 16)
Subject: looks_like
Date: 8 Sep 2016 00:54:14
Message: <57d0eef6@news.povray.org>
Is this the correct way to set up a light_source and attached object?
// Sun
light_source
	Source_Location
	rgb light_color
	looks_like
		sphere
			Source_Location, Source_Radius
			texture
				pigment {color rgb light_color}
				finish
					emission	1
					ambient		0
					diffuse		0
	parallel
Note that the light source and object are both located at
Source_Location. I'm not sure how to test whether I'm doing it right or
wrong.
Mike
Subject: Re: looks_like
Date: 8 Sep 2016 03:57:15
Message: <57d119db$1@news.povray.org>
Am 08.09.2016 um 06:54 schrieb Mike Horvath:
Nope.
A looks_like object needs to be constructed at <0,0,0>, as POV-Ray
automatically adds a translation to the light source's location.
I do agree that this is poorly documented in the official documentation.
Date: 8 Sep 2016 04:00:51
Message: <57d11ab3$1@news.povray.org>
> Nope.
So this is better?
// Sun
light_source
	Source_Location
	rgb light_color
	looks_like
		sphere
			<0,0,0>, Source_Radius
			texture
				finish
					emission	1
					ambient		0
					diffuse		0
	parallel
Date: 8 Sep 2016 04:09:51
Message: <57d11ccf$1@news.povray.org>
Am 08.09.2016 um 10:00 schrieb Mike Horvath:
> So this is better?
Yup.
Date: 12 Sep 2016 03:10:03
Message: <web.57d65443e29f65168ef8a390@news.povray.org>
> Nope.
Date: 12 Sep 2016 03:25:01
Message: <web.57d6580ae29f65168ef8a390@news.povray.org>
> > Nope.
> So this is better?
> // Sun
> light_source
>  Source_Location
>  rgb light_color
>  looks_like
>   sphere
>    texture
>     finish
>      emission 1
>      ambient  0
>      diffuse  0
>  parallel
A more subtle details is that the light_color usually not the same.
the color of POV-Ray light_source describes the color of the illuminated object.
the color of looks_like object describes the color of (sun) itself. The sun
color often much brighter than the object it illuminates.
Date: 12 Sep 2016 04:00:00
Message: <web.57d65fffe29f65168ef8a390@news.povray.org>
I show you the calculation:
The angular diameter of the Sun is about 1/2 degree, so the solid angle of it is
about 0.00006 steradian viewed from Earth. If the luminance of the Sun is
sun_color, than the illuminace of the sun light is sun_color*0.00006, then the
luminance of the reflect surface will be sun_color*0.00006*surface_albedo/pi, so
you should set the color of the POVRay's light_source sun_color*0.00006/pi.
On the other hand, if you set the light_source color A, than the looks_like
color will be A*pi/0.00006 ~= A*52333.
Date: 12 Sep 2016 08:44:46
Message: <57d6a33e$1@news.povray.org>
Is this even possible? Isn't there a limit on how bright you can make
something?
Mike
Date: 12 Sep 2016 09:04:27
Message: <57d6a7db$1@news.povray.org>
Am 12.09.2016 um 14:44 schrieb Mike Horvath:
>> looks_like
> something?
Yes, absolutely: Brightness values cannot exceed 3.4e+38 ;)
Date: 13 Sep 2016 17:15:15
Message: <57d86c63$1@news.povray.org>
Do I apply this to the pigment or the finish emission?
