POV-Ray : Newsgroups : povray.binaries.images : NURBS Server Time
27 May 2026 14:16:13 EDT (-0400)
  NURBS (Message 51 to 55 of 55)
Subject: Re: NURBS
Date: 9 Oct 2016 16:10:00
Message: <web.57faa3026d1ce2047a3e03fe0@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
> Le 26/07/2016 à 19:06, Nekar Xenos a écrit :
> > Yay, NURBS!
> And now with normal computation too, in Hgpovray (branch Hgpovray of
> https://github.com/LeForgeron/povray.git ), if someone ever need it
> (what is a smooth_triangle ?)
> That should finish that nurbs part... oh wait, documentation is still
> not done... Winter is coming.
I can not build its own version of Rosa-Linux.
If:
../configure --with-x COMPILED_BY="Lanuhum" LIBS="-lboost_system -lboost_thread
-lboost_date_time"
leonid@lanucomp ~/workspace/build/povray (Hg-povray) $ ./configure --with-x
--prefix=/usr COMPILED_BY="Lanuhum" LIBS="-lboost_system -lboost_thread"
Configure POV-Ray version 3.7.0
This is an unofficial version compiled by:
 Lanuhum
The POV-Ray Team(tm) is not responsible for supporting this version.
Environment
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking whether $C_INCLUDE_PATH contains the "." path... no
checking whether $CPLUS_INCLUDE_PATH contains the "." path... no
Programs
checking for gcc... gcc
checking whether the C compiler works... no
configure: error: in `/home/leonid/workspace/build/povray':
configure: error: C compiler cannot create executables
See `config.log' for more details
If:
make
lots of undefined reference to boost
The official version I built using CMake.
Your version CMake does not want to build:
leonid@lanucomp ~/workspace/programming/povray_animator/povray $ LC_ALL=C make
[  0%] Building CXX object CMakeFiles/povray.dir/source/pov_mem.cpp.o
In file included from
/home/leonid/workspace/programming/povray_animator/hgpovray/source/backend/control/messagefactory.h:39:0,
                 from
/home/leonid/workspace/programming/povray_animator/hgpovray/source/backend/frame.h:59,
                 from
/home/leonid/workspace/programming/povray_animator/hgpovray/source/pov_mem.cpp:36:
/home/leonid/workspace/programming/povray_animator/hgpovray/source/backend/control/renderbackend.h:112:34:
error: template argument 2 is invalid
   map<SceneId, shared_ptr<Scene> > scenes;
error: template argument 4 is invalid
/home/leonid/workspace/programming/povray_animator/hgpovray/source/backend/control/renderbackend.h:113:32:
   map<ViewId, shared_ptr<View> > views;
/home/leonid/workspace/programming/povray_animator/hgpovray/source/pov_mem.cpp:36:0:
/home/leonid/workspace/programming/povray_animator/hgpovray/source/backend/frame.h:1273:3:
error: reference to 'shared_ptr' is ambiguous
   shared_ptr<SubsurfaceInterior> subsurface;
Perhaps I missed something. I do not see. :(
Subject: Re: NURBS
Date: 10 Oct 2016 02:38:45
Message: <57fb3775$1@news.povray.org>
> Programs
First fix the first reported problem:
* why do you need -lboost_date_time" ?
* See config.log and get C compiler to work.
* why do you need --with-x ?
My usual sequence is :
* cd unix
* ./prebuild.sh
* cd ..
* ./configure COMPILED_BY="LanuHum" LIBS="-lboost_system -lboost_thread"
* make -j 4
Have you installed boost for development ? all of it ?
Subject: Re: NURBS
Date: 10 Oct 2016 09:55:00
Message: <web.57fb9d186d1ce2047a3e03fe0@news.povray.org>
Yes. I have successfully built the official Povray.
> * cd unix
> * ./prebuild.sh
> * cd ..
> * make -j 4
To do so:
leonid@lanucomp ~ $ cd /home/leonid/workspace/build/povray/unix
leonid@lanucomp ~/workspace/build/povray/unix (Hg-povray) $ ./prebuild.sh
Detected autoconf 2.69
Detected automake 1.15
Create ../AUTHORS
Create ../ChangeLog
Create ../configure.ac
Create ../COPYING
Create ../NEWS
Create ../README
Create ../VERSION
Create ../povray.1
Create ../povray.conf
Create ../scripts/
Create ../ini/
Create ../include/
Create ../scenes/
Create ../INSTALL
Create ../icons/file_inc_crystal_32.png
Create ../icons/povray_16.png
Create ../icons/file_pov_classic_16.png
Create ../icons/file_pov_classic_32.png
Create ../icons/file_inc_classic_32.png
Create ../icons/file_inc_slick_32.png
Create ../icons/file_inc_classic_16.png
Create ../icons/file_inc_classic_64.png
Create ../icons/file_inc_slick_48.png
Create ../icons/povray_64.png
Create ../icons/file_pov_crystal_32.png
Create ../icons/file_inc_crystal_64.png
Create ../icons/povray_48.png
Create ../icons/file_pov_slick_32.png
Create ../icons/file_pov_slick_16.png
Create ../icons/file_inc_classic_48.png
Create ../icons/file_inc_crystal_48.png
Create ../icons/file_pov_crystal_48.png
Create ../icons/file_pov_classic_48.png
Create ../icons/file_inc_slick_64.png
Create ../icons/file_pov_crystal_16.png
Create ../icons/file_pov_classic_64.png
Create ../icons/file_pov_crystal_64.png
Create ../icons/file_inc_crystal_16.png
Create ../icons/file_pov_slick_48.png
Create ../icons/file_pov_slick_64.png
Create ../icons/povray_32.png
Create ../icons/file_inc_slick_16.png
Create ../doc/html
Create ./Makefile.am
Create ../kde_install.sh
Create ../povray.ini.in
Create ../Makefile.am
Create ../bootstrap
Create ../source/Makefile.am
Create ../vfe/Makefile.am
Run ../bootstrap
+ rm -f config.log config.status
+ aclocal -I .
configure.ac:302: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call detected in
body
.../../lib/autoconf/lang.m4:193: AC_LANG_CONFTEST is expanded from...
.../../lib/autoconf/general.m4:2590: _AC_COMPILE_IFELSE is expanded from...
.../../lib/autoconf/general.m4:2606: AC_COMPILE_IFELSE is expanded from...
.../../lib/m4sugar/m4sh.m4:639: AS_IF is expanded from...
.../../lib/autoconf/general.m4:2031: AC_CACHE_VAL is expanded from...
.../../lib/autoconf/general.m4:2052: AC_CACHE_CHECK is expanded from...
unix/config/ax_boost_thread.m4:32: AX_BOOST_THREAD is expanded from...
configure.ac:302: the top level
+ autoheader --warnings=all
body
+ automake --add-missing --warnings=all
body
/usr/share/automake-1.15/am/library.am: warning: 'libpovray.a': linking
libraries using a non-POSIX
/usr/share/automake-1.15/am/library.am: archiver requires 'AM_PROG_AR' in
'configure.ac'
source/Makefile.am:32:   while processing library 'libpovray.a'
/usr/share/automake-1.15/am/library.am: warning: 'libvfe.a': linking libraries
using a non-POSIX
'configure.ac'
vfe/Makefile.am:32:   while processing library 'libvfe.a'
+ autoconf --warnings=all
configure.ac:295: warning: The macro `AC_LANG_SAVE' is obsolete.
configure.ac:295: You should run autoupdate.
.../../lib/autoconf/lang.m4:125: AC_LANG_SAVE is expanded from...
unix/config/acx_pthread.m4:78: ACX_PTHREAD is expanded from...
configure.ac:295: the top level
configure.ac:295: warning: The macro `AC_LANG_C' is obsolete.
.../../lib/autoconf/c.m4:72: AC_LANG_C is expanded from...
configure.ac:295: warning: The macro `AC_TRY_LINK' is obsolete.
.../../lib/autoconf/general.m4:2687: AC_TRY_LINK is expanded from...
configure.ac:295: warning: The macro `AC_LANG_RESTORE' is obsolete.
.../../lib/autoconf/lang.m4:134: AC_LANG_RESTORE is expanded from...
body
+ cat ./configure
+ sed -e 's,configure.gnu  --help=recursive,& --srcdir=$ac_srcdir,g' -e 's,\(cd
\)\($ac_\)\(pop\)*\(dir\),\1"\2\3\4",g' -e
's,$am_aux_dir/missing,\\"$am_aux_dir\\"/missing,g'
+ mv -f ./configure.tmp ./configure
+ chmod +x ./configure
+ rm -f -r ./autom4te.cache
leonid@lanucomp ~/workspace/build/povray/unix (Hg-povray) $ cd ..
 LanuHum
Environment
Programs
config.log:
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by POV-Ray configure 3.7.0, which was
generated by GNU Autoconf 2.69.  Invocation command line was
  $ ./configure COMPILED_BY=LanuHum LIBS=-lboost_system -lboost_thread
## Platform. ##
hostname = lanucomp
uname -m = x86_64
uname -r = 4.1.33-nrj-desktop-1rosa-x86_64
uname -s = Linux
uname -v = #1 SMP PREEMPT Sun Sep 18 20:20:09 UTC 2016
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = unknown
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /usr/bin
PATH: /bin
PATH: /usr/local/bin
PATH: /usr/X11R6/bin/
PATH: /usr/games
PATH: /usr/lib/qt4/bin
PATH: /home/leonid/.local/bin
PATH: /home/leonid/bin
## Core tests. ##
configure:3706: result:
 LanuHum
configure:3727: result:
Environment
configure:3736: checking build system type
configure:3750: result: x86_64-unknown-linux-gnu
configure:3770: checking host system type
configure:3783: result: x86_64-unknown-linux-gnu
configure:3820: checking for a BSD-compatible install
configure:3888: result: /usr/bin/install -c
configure:3899: checking whether build environment is sane
configure:3954: result: yes
configure:4105: checking for a thread-safe mkdir -p
configure:4144: result: /bin/mkdir -p
configure:4151: checking for gawk
configure:4167: found /usr/bin/gawk
configure:4178: result: gawk
configure:4189: checking whether make sets $(MAKE)
configure:4211: result: yes
configure:4240: checking whether make supports nested variables
configure:4257: result: yes
configure:4384: checking whether to enable maintainer-specific portions of
Makefiles
configure:4393: result: no
ax_fix_incorrect_path_regexp = [=:]*\.:*
ax_fix_incorrect_path_old =
ax_fix_incorrect_path_new =
configure:4420: checking whether $C_INCLUDE_PATH contains the "." path
configure:4430: result: no
configure:4448: checking whether $CPLUS_INCLUDE_PATH contains the "." path
configure:4458: result: no
configure:4469: result:
Programs
configure:4525: checking for gcc
configure:4541: found /usr/bin/gcc
configure:4552: result: gcc
configure:4781: checking for C compiler version
configure:4790: gcc --version >&5
gcc (Linaro GCC 4.9-2014.08) 4.9.2 20140811 (ROSA)
Copyright (C) 2014 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:4801: $? = 0
configure:4790: gcc -v >&5
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib64/gcc/x86_64-unknown-linux-gnu/4.9.2/lto-wrapper
Target: x86_64-unknown-linux-gnu
Configured with: ../configure --prefix=/usr --libdir=/usr/lib64
--libexecdir=/usr/lib64 --mandir=/usr/share/man --infodir=/usr/share/info
--disable-libjava-multilib
--with-java-home=/usr/lib/jvm/java-1.5.0-gcj-1.5.0.0/jre
--with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-java-awt=gtk
--enable-gtk-cairo --with-cloog --with-ppl --enable-cloog-backend=isl
--disable-cloog-version-check --disable-libssp --disable-libunwind-exceptions
--disable-werror --enable-__cxa_atexit --enable-gold=default
--with-plugin-ld=/usr/bin/ld --enable-bootstrap --enable-checking=release
--enable-gnu-unique-object
--enable-languages=c,ada,c++,fortran,go,java,lto,objc,obj-c++
--enable-linker-build-id --enable-plugin --enable-lto --enable-shared
--enable-threads=posix --with-system-zlib
--with-bugurl=http://bugs.rosalinux.ru/ --with-tune=generic --with-arch_32=i586
--with-multilib-list=m32,m64 --host=x86_64-unknown-linux-gnu
--build=x86_64-unknown-linux-gnu --target=x86_64-unknown-linux-gnu
Thread model: posix
gcc version 4.9.2 20140811 (ROSA) (Linaro GCC 4.9-2014.08)
configure:4790: gcc -V >&5
gcc: error: unrecognized command line option '-V'
gcc: fatal error: no input files
compilation terminated.
configure:4801: $? = 1
configure:4790: gcc -qversion >&5
gcc: error: unrecognized command line option '-qversion'
configure:4821: checking whether the C compiler works
configure:4843: gcc    conftest.c -lboost_system -lboost_thread >&5
/usr/lib64/gcc/x86_64-unknown-linux-gnu/4.9.2/../../../../lib64/libboost_system.so:
undefined reference to `operator delete(void*)'
/usr/lib64/gcc/x86_64-unknown-linux-gnu/4.9.2/../../../../lib64/libboost_thread.so:
undefined reference to `std::_Rb_tree_decrement(std::_Rb_tree_node_base*)'
undefined reference to `typeinfo for std::bad_alloc'
undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base*)'
undefined reference to `__cxa_end_catch'
undefined reference to `__cxa_allocate_exception'
undefined reference to `std::basic_ostringstream<char, std::char_traits<char>,
std::allocator<char> >::~basic_ostringstream()'
undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base const*)'
undefined reference to `std::basic_string<char, std::char_traits<char>,
std::allocator<char> >::basic_string(std::string const&)'
undefined reference to `__cxa_guard_release'
undefined reference to `std::string::append(char const*, unsigned long)'
std::allocator<char> >::basic_ostringstream(std::_Ios_Openmode)'
undefined reference to `std::string::_M_mutate(unsigned long, unsigned long,
unsigned long)'
undefined reference to `std::string::append(std::string const&)'
undefined reference to `typeinfo for std::runtime_error'
undefined reference to `__cxa_pure_virtual'
undefined reference to `std::bad_alloc::~bad_alloc()'
std::allocator<char> >::~basic_string()'
undefined reference to `std::string::assign(char const*, unsigned long)'
undefined reference to `std::bad_exception::~bad_exception()'
undefined reference to `std::runtime_error::runtime_error(std::string const&)'
undefined reference to `std::runtime_error::what() const'
undefined reference to `__gxx_personality_v0'
undefined reference to `std::bad_exception::what() const'
`std::_Rb_tree_rebalance_for_erase(std::_Rb_tree_node_base*,
std::_Rb_tree_node_base&)'
undefined reference to `__cxa_begin_catch'
std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)'
undefined reference to `__cxa_rethrow'
undefined reference to `__cxa_throw'
undefined reference to `std::basic_stringbuf<char, std::char_traits<char>,
std::allocator<char> >::str() const'
undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
undefined reference to `std::exception::~exception()'
undefined reference to `std::string::_Rep::_M_destroy(std::allocator<char>
const&)'
undefined reference to `operator new(unsigned long)'
undefined reference to `std::string::swap(std::string&)'
undefined reference to `typeinfo for std::bad_exception'
undefined reference to `std::string::_Rep::_S_empty_rep_storage'
undefined reference to `__cxa_guard_abort'
undefined reference to `vtable for std::runtime_error'
undefined reference to `vtable for __cxxabiv1::__class_type_info'
undefined reference to `std::_Rb_tree_insert_and_rebalance(bool,
std::_Rb_tree_node_base*, std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)'
undefined reference to `__cxa_call_unexpected'
undefined reference to `std::runtime_error::~runtime_error()'
undefined reference to `std::basic_ostream<char, std::char_traits<char> >&
std::__ostream_insert<char, std::char_traits<char> >(std::basic_ostream<char,
std::char_traits<char> >&, char const*, long)'
undefined reference to `vtable for __cxxabiv1::__vmi_class_type_info'
undefined reference to `__cxa_free_exception'
undefined reference to `__cxa_guard_acquire'
undefined reference to `std::bad_alloc::what() const'
collect2: error: ld returned 1 exit status
configure:4847: $? = 1
configure:4885: result: no
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "POV-Ray"
| #define PACKAGE_TARNAME "povray"
| #define PACKAGE_VERSION "3.7.0"
| #define PACKAGE_STRING "POV-Ray 3.7.0"
| #define PACKAGE_BUGREPORT "uni### [at] povrayorg"
| #define PACKAGE_URL ""
| #define VERSION_BASE "3.7"
| #define DISTRIBUTION_MESSAGE_2 " LanuHum"
| #define PACKAGE "povray"
| #define VERSION "3.7.0"
| /* end confdefs.h.  */
| int
| main ()
|   return 0;
configure:4890: error: in `/home/leonid/workspace/build/povray':
configure:4892: error: C compiler cannot create executables
## Cache variables. ##
ac_cv_build=x86_64-unknown-linux-gnu
ac_cv_env_C99_COMPATIBLE_RADIOSITY_set=
ac_cv_env_C99_COMPATIBLE_RADIOSITY_value=
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_COMPILED_BY_set=set
ac_cv_env_COMPILED_BY_value=LanuHum
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=set
ac_cv_env_LIBS_value='-lboost_system -lboost_thread'
ac_cv_env_NON_REDISTRIBUTABLE_BUILD_set=
ac_cv_env_NON_REDISTRIBUTABLE_BUILD_value=
ac_cv_env_XMKMF_set=
ac_cv_env_XMKMF_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_host=x86_64-unknown-linux-gnu
ac_cv_path_install='/usr/bin/install -c'
ac_cv_path_mkdir=/bin/mkdir
ac_cv_prog_AWK=gawk
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_make_make_set=yes
am_cv_make_support_nested_variables=yes
## Output variables. ##
ACLOCAL='${SHELL} "/home/leonid/workspace/build/povray/unix/config"/missing
aclocal-1.15'
AMDEPBACKSLASH=''
AMDEP_FALSE=''
AMDEP_TRUE=''
AMTAR='$${TAR-tar}'
AM_BACKSLASH='\'
AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)'
AM_DEFAULT_VERBOSITY='1'
AM_V='$(V)'
AUTOCONF='${SHELL} "/home/leonid/workspace/build/povray/unix/config"/missing
autoconf'
AUTOHEADER='${SHELL} "/home/leonid/workspace/build/povray/unix/config"/missing
autoheader'
AUTOMAKE='${SHELL} "/home/leonid/workspace/build/povray/unix/config"/missing
automake-1.15'
AWK='gawk'
BOOST_CPPFLAGS=''
BOOST_LDFLAGS=''
BOOST_THREAD_LIB=''
C99_COMPATIBLE_RADIOSITY=''
CC='gcc'
CCDEPMODE=''
CFLAGS=''
COMPILED_BY='LanuHum'
CPLUS_INCLUDE_PATH=''
CPP=''
CPPFLAGS=''
CXX=''
CXXCPP=''
CXXDEPMODE=''
CXXFLAGS=''
CYGPATH_W='echo'
C_INCLUDE_PATH=''
DEFS=''
DEPDIR=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
EXEEXT=''
GREP=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
LDFLAGS=''
LIBOBJS=''
LIBS='-lboost_system -lboost_thread'
LTLIBOBJS=''
MAINT='#'
MAINTAINER_MODE_FALSE=''
MAINTAINER_MODE_TRUE='#'
MAKEINFO='${SHELL} "/home/leonid/workspace/build/povray/unix/config"/missing
makeinfo'
MKDIR_P='/bin/mkdir -p'
NON_REDISTRIBUTABLE_BUILD=''
OBJEXT=''
PACKAGE='povray'
PACKAGE_BUGREPORT='uni### [at] povrayorg'
PACKAGE_NAME='POV-Ray'
PACKAGE_STRING='POV-Ray 3.7.0'
PACKAGE_TARNAME='povray'
PACKAGE_URL=''
PACKAGE_VERSION='3.7.0'
PATH_SEPARATOR=':'
PKGCONFIG=''
PTHREAD_CC=''
PTHREAD_CFLAGS=''
PTHREAD_LIBS=''
RANLIB=''
SDLCONFIG=''
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
VERSION='3.7.0'
VERSION_BASE='3.7'
XMKMF=''
X_CFLAGS=''
X_EXTRA_LIBS=''
X_LIBS=''
X_PRE_LIBS=''
ac_ct_CC='gcc'
ac_ct_CXX=''
acx_pthread_config=''
am__EXEEXT_FALSE=''
am__EXEEXT_TRUE=''
am__fastdepCC_FALSE=''
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE=''
am__fastdepCXX_TRUE=''
am__include=''
am__isrc=''
am__leading_dot='.'
am__nodep=''
am__quote=''
am__tar='$${TAR-tar} chof - "$$tardir"'
am__untar='$${TAR-tar} xf -'
bindir='${exec_prefix}/bin'
build='x86_64-unknown-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='unknown'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
exec_prefix='NONE'
host='x86_64-unknown-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='unknown'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='${SHELL} /home/leonid/workspace/build/povray/unix/config/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
mkdir_p='$(MKDIR_P)'
oldincludedir='/usr/include'
pdfdir='${docdir}'
povgroup=''
povowner=''
prefix='NONE'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
/* confdefs.h */
configure: exit 77
Subject: Re: NURBS
Date: 10 Oct 2016 11:05:01
Message: <web.57fbad716d1ce2047a3e03fe0@news.povray.org>
No problem:
../configure COMPILED_BY="LanuHum" --with-boost-libdir=/usr/lib64
Subject: Re: NURBS
Date: 10 Oct 2016 12:59:22
Message: <57fbc8ea$1@news.povray.org>
Le 10/10/2016 à 17:02, LanuHum a écrit :
> No problem:
Nice :-)
