POV-Ray : Newsgroups : povray.binaries.images : NURBS Server Time
27 May 2026 10:23:00 EDT (-0400)
  NURBS (Message 21 to 30 of 55)
Subject: Re: NURBS
Date: 24 Jul 2016 15:45:01
Message: <web.57951a946d1ce2047a3e03fe0@news.povray.org>
When can I test?
Subject: Re: NURBS
Date: 25 Jul 2016 06:50:08
Message: <5795eee0$1@news.povray.org>
Le 24/07/2016 21:44, LanuHum a écrit :
> When can I test?
Now also available in hg-povray.
Subject: Re: NURBS
Date: 26 Jul 2016 13:06:27
Message: <57979893$1@news.povray.org>
Yay, NURBS!
Yippee!
=D
________________________________________
-Nekar Xenos-
Subject: Re: NURBS
Date: 29 Jul 2016 11:15:01
Message: <web.579b72a26d1ce2047a3e03fe0@news.povray.org>
Does not work. Empty image. :(
#version 3.7;
#include "functions.inc"
global_settings {
    assumed_gamma 1.000000
    max_trace_level 3
    charset utf8
sky_sphere {
    pigment {rgb<0.051, 0.051, 0.051>}
#declare Default_texture = texture{pigment {rgb 0.8}}
#declare data_SurfPatch_ob =
nurbs {7,4 accuracy 0.01
 <-1.5000,-5.4790,0.0000> <-1.5000,-4.3181,2.0249> <-1.5000,-2.8825,0.0000>
<-1.5000,-1.5000,0.0000> <-1.5000,-0.5000,0.0000>
 <-1.5000,0.5000,0.0000> <-1.5000,1.5000,0.0000> <-0.5000,-5.4790,0.0000>
<-0.5000,-4.3181,0.0000>
 <-0.5000,-2.8825,1.7624> <-0.5000,-1.5000,0.0000> <-0.5000,-0.5000,1.0000>
<-0.5000,0.5000,1.0000>
 <-0.5000,1.5000,0.0000> <0.5000,-5.4790,0.0000> <0.5000,-4.3181,0.0000>
<0.5000,-2.8825,0.0000>
 <0.5000,-1.5000,1.1552> <0.5000,-0.5000,1.0000> <0.5000,0.5000,1.0000>
<0.5000,1.5000,0.0000>
 <1.5000,-5.4790,1.9780> <1.5000,-4.3181,0.0000> <1.5000,-2.8825,0.0000>
<1.5000,-1.5000,0.0000>
 <1.5000,-0.5000,0.0000> <1.5000,0.5000,0.0000> <1.5000,1.5000,0.0000>
texture{Default_texture}
object {data_SurfPatch_ob
    matrix <1.000000, 0.000000, 0.000000,  0.000000, -0.000000, -1.000000,
0.000000, 1.000000, -0.000000,  0.000000, -0.000000, -3.620508>
light_source {
    <4.08,5.9,-1.01>
    color rgb<1, 1, 1>
    fade_distance 29.9999828339
    fade_power 1
    perspective
    location  <0,0,0>
    look_at  <0,0,-1>
    right <-1.7777777777777777, 0, 0>
    up <0, 1, 0>
    angle  49.134343
    rotate  <-26.440706, 46.691945, -0.000003>
    translate <7.481132, 5.343666, 6.507640>
Subject: Re: NURBS
Date: 29 Jul 2016 12:05:00
Message: <web.579b7df96d1ce2047a3e03fe0@news.povray.org>
Sorry!I do not put a fourth option 'W'!
It works, but the model is different from the render result.
Download 'nurbs.jpg' (131 KB)
Preview of image 'nurbs.jpg'
Subject: Re: NURBS
Date: 29 Jul 2016 12:15:01
Message: <web.579b801c6d1ce2047a3e03fe0@news.povray.org>
Compare renderings:
Download 'nurbs_diff.jpg' (99 KB)
Preview of image 'nurbs_diff.jpg'
Subject: Re: NURBS
Date: 29 Jul 2016 12:22:22
Message: <579b82be$1@news.povray.org>
> Compare renderings:
Can you provide the set of control points ?
Subject: Re: NURBS
Date: 29 Jul 2016 12:40:00
Message: <web.579b86376d1ce2047a3e03fe0@news.povray.org>
Yes!
#version 3.7;
global_settings {
    max_trace_level 3
    charset utf8
sky_sphere {
#declare Material = texture{
    pigment{color srgbft <0.8000,0.0946,0.0441,0.0000,0.0000>}
    finish{
        diffuse 0.8000
        brilliance 1.8000
nurbs {7,7 accuracy 0.01
 <-4.1894,-5.4790,0.0000,1.0000> <-4.1894,-4.3181,2.0249,1.0000>
<-4.1894,-2.8825,0.0000,1.0000> <-4.1894,-1.5000,0.0000,1.0000>
<-4.1894,-0.5000,0.0000,1.0000> <-4.1894,0.5000,0.0000,1.0000>
<-4.1894,1.5000,0.0000,1.0000> <-2.6808,-4.8585,0.6794,1.0000>
 <-2.6808,-4.3181,2.0249,1.0000> <-2.6808,-2.8825,0.0000,1.0000>
<-2.6808,-1.5000,3.2519,1.0000> <-2.6808,-0.5000,0.0000,1.0000>
<-2.6808,0.5000,0.0000,1.0000> <-2.6808,1.5000,3.2103,1.0000>
<-1.5000,-5.4790,0.0000,1.0000>
 <-1.5000,-4.3181,2.0249,1.0000> <-1.5000,-2.8825,0.0000,1.0000>
<-1.5000,-1.5000,0.0000,1.0000> <-1.5000,-0.5000,1.2319,1.0000>
<-1.5000,0.5000,0.0000,1.0000> <-1.5000,1.5000,0.0000,1.0000>
<-0.5000,-5.4790,0.0000,1.0000>
 <-0.5000,-4.3181,0.0000,1.0000> <-0.5000,-2.8825,1.7624,1.0000>
<-0.5000,-1.5000,0.0000,1.0000> <-0.5000,-0.5000,1.0000,1.0000>
<-0.5000,0.5000,1.0000,1.0000> <-0.5000,1.5000,0.0000,1.0000>
<0.5000,-5.4790,0.0000,1.0000>
 <0.5000,-4.3181,0.0000,1.0000> <0.5000,-2.8825,0.0000,1.0000>
<0.5000,-1.5000,1.1552,1.0000> <0.5000,-0.5000,1.0000,1.0000>
<0.5000,0.5000,1.0000,1.0000> <0.5000,1.5000,0.0000,1.0000>
<1.5000,-5.4790,1.9780,1.0000>
 <1.5000,-4.3181,0.0000,1.0000> <1.5000,-2.8825,1.7335,1.0000>
<1.5000,-1.5000,0.0000,1.0000> <1.5000,-0.5000,0.0000,1.0000>
<1.5000,0.5000,0.0000,1.0000> <1.5000,1.5000,1.5217,1.0000>
<2.9668,-5.4790,-0.2469,1.0000>
 <2.9668,-4.3181,0.0000,1.0000> <2.9668,-2.8825,0.0000,1.0000>
<2.9668,-1.5000,0.0000,1.0000> <2.9668,-0.5000,-2.9599,1.0000>
<2.9668,0.5000,0.0000,1.0000> <2.9668,1.5000,0.0000,1.0000>
texture{Material}
light_source {
    <4.08,5.9,-1.01>
    color rgb<1, 1, 1>
    fade_power 1
    perspective
    location  <0,0,0>
    look_at  <0,0,-1>
    up <0, 1, 0>
    angle  49.134343
But, I have found the cause elsewhere.
Blender has a nurbs option warrant.
Increasing the value closer look, but the maximum value of 6 does not give an
exact match. 7 or 8 is required, but the maximum value of 6. :(
Download 'nurbs_order.jpg' (36 KB)
Preview of image 'nurbs_order.jpg'
Subject: Re: NURBS
Date: 29 Jul 2016 12:53:40
Message: <579b8a14$1@news.povray.org>
Ok, so all is fine, and no need to investigate, right ?
Subject: Re: NURBS
Date: 29 Jul 2016 14:05:00
Message: <web.579b99fd6d1ce2047a3e03fe0@news.povray.org>
Your wish. But your nurbs difficult terrain models. Blender nurbs - good terrain
model. Your model also need a order_u and order_v. :)
I added nurbs export code to Povray-HG. Mr can move it to the official version
of the exporter, if it becomes available in the Povray-3.7.1.
