POV-Ray : Newsgroups : povray.binaries.images : concentric blobs clouds Server Time
27 May 2026 15:17:23 EDT (-0400)
  concentric blobs clouds (Message 51 to 60 of 66)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: concentric blobs clouds
Date: 1 May 2016 13:00:28
Message: <5726362c@news.povray.org>
Le 16-05-01 02:52, Thomas de Groot a écrit :
> On 30-4-2016 18:26, Jaime Vives Piqueres wrote:
>>    That's strange... I'm getting good results with just 16 samples.
> This is basically what I do; most other details are Gilles' original
> settings (more or less):
>    #declare P_cloud2_1 =
>    pigment {density_file df3 "cloud2_1.df3"
>      lambda 3
>      omega 0.6
>      interpolate 1
>      translate -0.5
>      scale <1, -1, 1>
>    #declare Cloud1 =
>    box {-0.5,0.5
>      texture {pigment {Clear} finish {ambient 0 diffuse 0}}
>      hollow
>      interior {
>        media {
>          scattering {1, C_Sun*0.006 extinction 0.25}
>          intervals 1
>          samples 100, 1000
>          density {
>            gradient y
>            density_map {
>              [0 pigment_pattern {P_cloud2_1}
>                 turbulence Turbulence*0.1
>              [1 pigment_pattern {P_cloud2_1}
>                 turbulence Turbulence*2
>      scale <4/3,1,1>
samples 100, 1000 is specific to method 1 and 2. As it is now, the 1000
is ignored.
Also, it's preferable to not set intervals at all and just use the
default of 1.
Date: 2 May 2016 03:40:49
Message: <57270481$1@news.povray.org>
> is ignored.
> default of 1.
Yes, thanks. I know this and - as it happens - just overlooked the
second samples value.
Date: 2 May 2016 06:39:24
Message: <57272e5c$1@news.povray.org>
Jaime Vives Piqueres wrote on 28/04/2016 14.44:
>> Hope one or more things here enough to get this cloud method working
>> generally.
>   Thanks for the detailed explanation, but in this case the best
> solution was the one the other Bill P. suggested. A merge of spheres
> with same radius and placement did work pretty well, and in this case it
> doesn't matter as it is an invisible container. It still does the job of
> being a close container, and the speed up provided is even a little
> better too.
> jaime
:-o
Date: 3 May 2016 06:38:27
Message: <57287fa3@news.povray.org>
Latest development:
+ new and improved cumulus shapes using trace() over a rough base shape.
There are 10 different clouds using 500 blob components each one.
+ added cirrus layer using a panoramic photograph of real clouds as
pattern for the media density (had to "cheat" because I could not find
any convincing pattern).
jaime
Download 'ocean-22.jpg' (149 KB)
Preview of image 'ocean-22.jpg'
Date: 3 May 2016 06:57:15
Message: <5728840b$1@news.povray.org>
On 3-5-2016 12:38, Jaime Vives Piqueres wrote:
> Latest development:
Looking very good indeed... I am not entirely convinced by the cirrus
layer though.
Date: 3 May 2016 06:59:37
Message: <57288499$1@news.povray.org>
On 03/05/16 11:38, Jaime Vives Piqueres wrote:
> Latest development:
> jaime
Very convincing cumulus; however, I'm less sure about the cirrus. I
think that a clockwise rotation might fix that.
Having said that, excellent work
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 4 May 2016 01:53:24
Message: <57298e54@news.povray.org>
Thanks, Thomas, John... see if these cirrus look better.
jaime
Download 'ocean-22c.jpg' (142 KB)
Preview of image 'ocean-22c.jpg'
Date: 4 May 2016 02:57:01
Message: <57299d3d$1@news.povray.org>
The wizard did it again! :-)
Yes, that is much, much better.
Date: 4 May 2016 05:47:44
Message: <5729c540@news.povray.org>
> jaime
You're not supposed to use a camera ;-)
Much better. Good work.
John
Protect the Earth
Date: 4 May 2016 08:07:23
Message: <5729e5fb@news.povray.org>
Am 04.05.2016 um 07:53 schrieb Jaime Vives Piqueres:
Something's still odd about this. Can't put my finger on it though.
Maybe thick low-hanging cumulus together with cirrus is a weather
situation we don't normally see?
Maybe there's a 3D-component to your cirrus clouds, whereas in reality
they seem to be quite flat?
