POV-Ray : Newsgroups : povray.binaries.images : Experimental tonemapping tests Server Time
25 Jun 2026 11:24:33 EDT (-0400)
  Experimental tonemapping tests (Message 21 to 24 of 24)
Subject: Re: Experimental tonemapping tests
Date: 14 Apr 2016 14:52:12
Message: <570fe6dc$1@news.povray.org>
El 14/04/16 a las 18:43, Stephen escribió:
> I really think you need a frame around the images. Is it a broken
> picture frame or a broken plate negative?
   It's the back of an old photo, scanned and inverted, so that the
cracks act as if the picture was scratched and broken. I've a lot of old
photographs with interesting back sides... some as old as 80 years.
> And what's with the fruit? Brings, Meléndez and Velázquez to mind.
   Yes, Meléndez was really a fruiterer... :)
jaime
Date: 14 Apr 2016 15:12:41
Message: <570feba9$1@news.povray.org>
An interesting technique. It changes the mood quite a bit.
Yes, but it is still, life. </g>
Regards
Date: 14 Apr 2016 17:07:33
Message: <57100695@news.povray.org>
   Well, I forgot to say that apart from the "blending" of the old paper
image, I applied also some random changes to the color curves to
simulate the "vintage" coloring (I was too lazy to investigate proper
curves for the different "vintage" effects, so I resorted to our old
friend "rand"):
    // random vintage effect
    #declare r_v=seed(1709);
    #declare exp_r=rand(r_v)*2;
    #declare exp_g=rand(r_v)*2;
    #declare exp_b=rand(r_v)*2;
    #declare sat=1-.75+rand(r_v)*.25;
    #declare f_old_paper=
    function{
      pigment{
        image_map{
          jpeg "jvp_old_photo_back_1"
          interpolate 2
        scale <1,-1,1>
        #if(image_height>image_width)
          rotate 90*z
    tonemapping{
      parameters{red,green,blue,gray,x,y}
      function(r,g,b,gr,x,y)
{max(pow(r,exp_r),f_old_paper(x,y,0).red)*(1-sat)+gr*sat}
{max(pow(g,exp_g),f_old_paper(x,y,0).green)*(1-sat)+gr*sat}
{max(pow(b,exp_b),f_old_paper(x,y,0).blue)*(1-sat)+gr*sat}
    Just change the random seed until you find a nice coloring...
jaime
Download 'jvp_old_photo_back_1.jpg' (786 KB)
Preview of image 'jvp_old_photo_back_1.jpg'
Date: 18 Apr 2016 04:46:33
Message: <57149ee9$1@news.povray.org>
Jaime Vives Piqueres wrote on 14/04/2016 17.43:
> You know you have been raytracing for too long... when your old renders
> are old and worn.
> Here I'm using screen.inc combined with the tonemapping feature to make
> "vintage" versions of my old renders. It works pretty well on
> photographs too... if your family photos are too well preserved, this is
> a good solution. ;)
> jaime
Hey! Stop posting photos here!
:D
I like them a lot,
Paolo
