POV-Ray : Newsgroups : povray.binaries.images : Growing crystals test Server Time
25 Jun 2026 14:29:09 EDT (-0400)
  Growing crystals test (Message 6 to 15 of 35)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Growing crystals test
Date: 17 Feb 2016 17:57:12
Message: <56c4fac8$1@news.povray.org>
Am 17.02.2016 um 13:18 schrieb Jaime Vives Piqueres:
> The world of POV-Ray crystallography is on fire this week... after the
> discovery of Thomasite, now it's the turn of Vivesite. ;)
Great stuff!
> As the test seems to have given acceptable results, I'm going to use now
> an isosurface as the base, and try to use hexagonal crystals... if I can
> work it out: working out the maths for a cube basal I already fried one
> or two neurons...
I guess it's worth frying a few more ;)
Date: 17 Feb 2016 17:57:35
Message: <56c4fadf@news.povray.org>
First test using an isosurface as base... nice, except for some ugly
artifacts on focal blur, due to a too strong light source.
jaime
Download 'crystals-07.jpg' (88 KB)
Preview of image 'crystals-07.jpg'
Date: 17 Feb 2016 19:05:01
Message: <web.56c509afe0041337fd6b6fe10@news.povray.org>
> jaime
Fantastic.  I've been wanting to know how to do this for years, but good crystal
geometry has been elusive.
How high do you have to set the max_trace_level?
A.D.B.
Date: 17 Feb 2016 19:15:00
Message: <web.56c50c05e004133723c5c5130@news.povray.org>
> jaime
Phantastic!
Good to see something new from you, Jaime.
First I thought, it's hdr lighting, but with this artifacts...
Norbert
Date: 17 Feb 2016 21:57:07
Message: <56c53303$1@news.povray.org>
double wow with a cherry on top.
dik
Date: 18 Feb 2016 03:02:00
Message: <56c57a78$1@news.povray.org>
That's it! One thing maybe to watch out for is the irregular normal
pattern on the sides. I think one should distinguish between the 'growth
pattern' of the crystals and the 'inclusions' within the crystals like
residual liquids. Of course Vivesite is a totally different matter ;-)
Date: 18 Feb 2016 03:43:53
Message: <56c58449$1@news.povray.org>
   Thanks... my solution was in fact very easy. The crystal geometry is
very simple, just 14 triangles for each crystal. The growth orientation
is controlled by the surface normals, and the widths and heights of each
one are just random.
   Only 9... I found increasing it was an overkill.
jaime
Date: 18 Feb 2016 03:47:57
Message: <56c5853d$1@news.povray.org>
> Phantastic!
> Good to see something new from you, Jaime. First I thought, it's hdr
   Thanks... yes, it has an hdr image as background, but it doesn't
contributes to lighting as I'm not using radiosity at the moment. The
lighting is just a single point light at the top, which matches the
lighting on the cave probe from openfootage.net. The problem with the
artifacts is that I used a looks_like object way too bright.
jaime
Date: 18 Feb 2016 03:49:37
Message: <56c585a1@news.povray.org>
   Yes, the normal is tricky... I used a simple "crackle solid" with
turbulence for now.
jaime
Date: 18 Feb 2016 10:03:24
Message: <56c5dd3c@news.povray.org>
This is amazing stuff. I love those mineral pictures!!!
