POV-Ray : Newsgroups : povray.binaries.images : Is there a limit to sky_sphere layers? Server Time
27 May 2026 08:33:09 EDT (-0400)
  Is there a limit to sky_sphere layers? (Message 1 to 5 of 5)
Subject: Is there a limit to sky_sphere layers?
Date: 9 Jan 2016 15:08:59
Message: <569168db@news.povray.org>
The documentation reads, "The sky sphere can contain several pigment
layers..." But if I use more than one transparent pigment on a
sky_sphere, the transparent areas show black instead of the first
pigment layer.
In all three images, a blue gradient is used as the first pigment layer.
  In cases 1 and 2, one partially transparent pigment is layered over
the blue gradient, and the result is as I expect.  In the third case, 2
partially transparent pigments are layered over the blue gradient, and
the blue does not show at all.
The render stats indicate that only one trace level is used.
As a sanity check, I applied the same pigments to a sphere at the lower
left.  In all cases, the sphere renders as I expect.
Am I missing something, or is this a bug?
----------[BEGIN CODE]----------
// +KFF3
#version 3.6;
#include "skies.inc"
global_settings { assumed_gamma 1 max_trace_level 5 }
camera
{ ultra_wide_angle
   location <0, 0.2, 0>
   look_at <0, 5.2, 5>
   angle 135
plane { y, 0 pigment { rgb 1 } }
#declare P1 = pigment
{ gradient y color_map
   { [0 rgb <0.5, 0.75, 1.0>]
     [1 rgb <0.1, 0.15, 0.2>]
#declare P2 = pigment
{ wood color_map
   { [0.0 rgb <1, 0.8, 0.6> transmit 0]
     [0.7 rgb <1, 0.8, 0.6> transmit 1]
   ramp_wave
sky_sphere
{ pigment { P1 }
   #switch (frame_number)
     #case (1)
       pigment { P2 }
       #break
     #case (2)
       pigment { P_Cloud1 scale 0.1 }
       #break
     #case (3)
       pigment { P2 }
       #break
#default { finish { ambient 1 diffuse 0 } }
sphere
{ 0, 1
   texture { pigment { P1 } }
     #case (1)
       texture { pigment { P2 } }
       #break
     #case (2)
       texture { pigment { P_Cloud1 scale 0.1 } }
       #break
     #case (3)
       #break
   translate 2.5 * z
   rotate -35 * y
-----------[END CODE]-----------
The results are the same in POV-Ray versions 3.6.1, 3.7, and
3.7.1-alpha.8150025.
Download 'sky_layers1.jpg' (9 KB) Download 'sky_layers2.jpg' (20 KB) Download 'sky_layers3.jpg' (25 KB)
Preview of image 'sky_layers1.jpg'
Preview of image 'sky_layers2.jpg'
Preview of image 'sky_layers3.jpg'
Subject: Re: Is there a limit to sky_sphere layers?
Date: 9 Jan 2016 16:10:01
Message: <web.569175eedf71a07db221960d0@news.povray.org>
> pigment layer.
I can confirm this for 3.6.2, but not for 3.7.0msvc10.win64.
Here it renders correct down to max_trace_level 1.
Norbert
Download 'limit to sky_sphere layers3.jpg' (97 KB)
Preview of image 'limit to sky_sphere layers3.jpg'
Date: 9 Jan 2016 16:40:07
Message: <web.56917d8cdf71a07db221960d0@news.povray.org>
I've to add the additional point, that it only renders correct with 3.7, when
the version statement is changed to "#version 3.7;", otherwise it's like you
described...
Norbert
Date: 9 Jan 2016 17:05:03
Message: <web.56918329df71a07dac6323910@news.povray.org>
> described...
Ah, so it appears to have been a bug in 3.6, which was corrected in 3.7, but
retained in compatibility mode.
Date: 9 Jan 2016 17:31:44
Message: <56918a50$1@news.povray.org>
Am 09.01.2016 um 23:01 schrieb Cousin Ricky:
>> described...
Exactly.
I wasn't aware of this effect in particular, but POV-Ray 3.6 did have
some peculiar quirks when it came to sky spheres. This was changed in
POV-Ray 3.7, with the aim that
- sky sphere behaviour is consistent with that of a textured sphere with
an emission-only finish, and
- background behaviour is consistent with that of a sky sphere with
uniform pigment.
