POV-Ray : Newsgroups : povray.binaries.images : Scattering media problem Server Time
25 Jun 2026 14:28:54 EDT (-0400)
  Scattering media problem (Message 21 to 24 of 24)
Subject: Re: Scattering media problem
Date: 11 Oct 2015 13:17:15
Message: <561a999b$1@news.povray.org>
> Hi(gh)!
> On 11.10.2015 05:00, clipka wrote:
>> Too low max_trace_level maybe?
> Meanwhile, I increased it to 10 - but still the plastic parts below the
> glass are black!
>> Also, behaviour may differ depending on whether you make the glass and
>> plastic planes overlap, merely touch, or have a tiny gap.
> Yes, I provided for a tiny gap... but it did not help!
<shrugs>
We'll probably need more information then.
Maybe you simply got the colour wrong?
Date: 11 Oct 2015 14:50:36
Message: <561aaf7c$1@news.povray.org>
Hi(gh)!
 > <shrugs>
O.k., here is the code:
// begin code
#version 3.7;
#include "glass.inc"
global_settings
   max_trace_level 10
// TEXTURES
#declare T_Grey_Matted_Plastic=
texture
   pigment { color rgb 0.7 }
   finish
     ambient 0.1
     diffuse 1
     brilliance 0.4
     phong 0.8
     phong_size 60
   normal
     granite
     turbulence 100
// MATERIALS
#declare M_PaneGlass=
material
   texture
     pigment
       color rgbft <0.99, 1, 0.99, 0.49, 0.49>
     finish { F_Glass5 }
   interior
     ior 1.52
     fade_color <0, 0.6, 0.35>
     fade_power 1001
     fade_distance 0.1
light_source
   <0, 2.4, -0.5>
   color rgb 1
sky_sphere
   pigment
     gradient y
     color_map
       [0 rgb 1]
       [1 rgb 0]
/* plane
   y, 0
   texture
     pigment { color rgb 1 }
     finish { ambient 0.15 diffuse 1 brilliance 0.2 }
#declare Glass_Pane_Bevel_Cutoff =
box
   <-0.155, -0.001*sqrt(2)/2, -0.025>, <0.155, 0.001*sqrt(2)/2, 0.025>
#declare Glass_Pane =
difference
   box
     0, <0.28, 0.013, 0.3>
   object // upper front bevel
     rotate <315, 0, 0>
     translate <0.14, 0.013, 0>
   object // lower front bevel
     rotate <45, 0, 0>
     translate <0.14, 0, 0>
   object // upper right bevel
     rotate <45, 90, 0>
     translate <0.28, 0.013, 0.15>
   object // lower right bevel
     rotate <315, 90, 0>
     translate <0.28, 0, 0.15>
   object // upper left bevel
     rotate <45, -90, 0>
     translate <0, 0.013, 0.15>
   object // lower left bevel
     rotate <315, -90, 0>
     translate <0, 0, 0.15>
   object // upper back bevel
     rotate <45, 0, 0>
     translate <0.14, 0.013, 0.3>
   object // lower back bevel
     rotate <315, 0, 0>
     translate <0.14, 0, 0.3>
   hollow
#declare Frame_Corner_Base_Raw=
union
   box { 0, <0.00788, 0.02214, 0.06224> }
   difference
     cylinder { <0.00788, 0, 0.03112>, <0.00788, 0.02214, 0.03112>,
0.03112 }
     box { <-0.05, -0.01, -0.01>, <0.00788, 0.03, 0.07> }
#declare Plastic_Frame_Side_Part=
difference
   cylinder
     0, <0, 0, 0.302>, 1
     scale <0.02, 0.03056, 1>
   box
     <-0.05, -0.05, -0.01>, <0.05, 0, 0.31>
   box
     <0, -0.05, -0.01>, <0.05, 0.1, 0.31>
#declare Central_Unit_Block=
union
   cylinder { 0, <0, 0.02214, 0>, 0.03112 }
   box { <0, 0, -0.03112>, <0.07566, 0.02214, 0.03112> }
   cylinder { <0.07566, 0, 0>, <0.07566, 0.02214, 0>, 0.03112 }
#declare Fillet=
box
   0, <0.036, 0.009, 0.011>
#declare Plastic_Frame=
union
   object { Plastic_Frame_Side_Part }
   object { Frame_Corner_Base_Raw }
   object { Frame_Corner_Base_Raw  translate <0, 0, 0.23976>}
   object { Plastic_Frame_Side_Part rotate <0, 180, 0> translate <0.28,
0, 0.302>}
   object { Frame_Corner_Base_Raw rotate <0, 180, 0> translate <0.28, 0,
0.06224>}
0.302>}
   object { Central_Unit_Block translate <0.10217, 0, 0.27088> }
   object { Fillet translate <0.03718, 0.01314, 0.26538> }
   object { Fillet translate <0.20713, 0.01314, 0.26538> }
// 0.03236 x
// 0.009 y
// 0.011 z
object
   Glass_Pane
   material { M_PaneGlass }
   translate <0, 0.022141, 0>
object
   Plastic_Frame
   texture { T_Grey_Matted_Plastic }
#declare view=4;
camera
   #switch(view)
     #case (0)
       location <0.01, 0.015, -0.2>
       look_at <0.01, 0.015, 0.30>
     #break
     #case (1)
       location <0.14, 0.65, -0.7>
       look_at <0.14, 0.0125, 0.001>
     #break
     #case (2)
       location <0.95, 0.65, 0.15>
       look_at <0.14, 0.0065, 0.15>
     #break
     #case (3)
     #break
     #case (4)
       location <0.14, 1, 0.15>
       look_at <0.14, 0, 0.15>
     #break
   angle 40
// end code
See you in Khyberspace!
Yadgar
Date: 13 Oct 2015 03:05:50
Message: <561cad4e@news.povray.org>
Looks like the gap between the frame and glass pane is too small. You
may want to use a different scale to increase your absolute scene size.
Date: 13 Oct 2015 18:01:28
Message: <561d7f38@news.povray.org>
Hi(gh)!
Yes, originally the gap was only 0.000001 POV units wide... I increased
this to 0.00016 POV units, and now it looks as it was meant to look (see
attachment)!
Yadgar
Download '2015-10-13 korona scales, take 36.jpg' (30 KB)
Preview of image '2015-10-13 korona scales, take 36.jpg'
