POV-Ray : Newsgroups : povray.binaries.images : RSoCP by UberPOV Server Time
28 Mar 2026 09:51:52 EDT (-0400)
  RSoCP by UberPOV (Message 20 to 29 of 59)
Subject: Re: RSoCP by UberPOV
Date: 28 Jun 2015 13:35:30
Message: <55903062@news.povray.org>
On 06/28/2015 06:22 AM, Stephen wrote:
> Blinking text?
No, no, NO!  I will quit POV-Ray forever if Christoph does that!
Date: 28 Jun 2015 14:03:44
Message: <55903700$1@news.povray.org>
>> Blinking text?
Thank you, thank you. :-)
I could only dream of that response. ;-)
Regards
Date: 28 Jun 2015 17:53:02
Message: <55906cbe$1@news.povray.org>
>> Blinking text?
OK then. Make it blink for 5 seconds, then use a markee. ;P
Date: 29 Jun 2015 07:35:59
Message: <55912d9f@news.povray.org>
Right. This should be it I guess:
sphere {
   <0,0,0>, 1.00
     pigment {srgb <0.8, 0.7, 0.7>*0.5 }
     finish {
       diffuse albedo 0.5  //note: should be 0.0 when metallic on
       specular albedo 0.4
       roughness 0.001
       brilliance 3, 3
       reflection {
         0.0, 0.4
         roughness 0.001
         fresnel on
         metallic off
       fresnel on
       metallic off
       conserve_energy
   interior {ior 1.5}
   scale <1,1,1>  rotate <0,0,0>  translate <-1.35, 1.35, 0>
sphere {
   <0,0,0>, 1.00
     finish {
       diffuse albedo 0.0  //note: should be 0.0 when metallic on
       specular albedo 0.4
       roughness 0.001
       //brilliance 3, 3
       reflection {
         0.0, 0.4
         roughness 0.001
         fresnel off
         metallic on
       fresnel off
       metallic on
       conserve_energy
   interior {ior 1.5}
   scale <1,1,1>  rotate <0,0,0>  translate <1.35, 1.35, 0>
As I am still unsure about the looks_like object, in the case of a
/sun-like/ object, this is the code I used although, to tell the truth,
it could be left out in the present scene.
#declare SunPosition = <-3000, 3000, -3000>;
//apparent size of the Sun (courtesy Cousin Ricky)
#declare SunDis      = vlength(SunPosition)*2/215;
light_source {
     SunPosition
     color rgb <1, 1, 1>*10
     area_light
     SunDis*x, SunDis*z,
     5, 5
     adaptive 2
     jitter
     circular
     orient
     parallel
     point_at <0, 0, 0>
     looks_like {
       sphere {
         0, SunDis
         pigment {color rgb <1,1,1>*10000}
         //finish {emission 1}
         no_radiosity
         no_reflection
     //fade_power 2
     //fade_distance SunDis/2
     //area_illumination
Download 'rsocp_uber.png' (231 KB)
Preview of image 'rsocp_uber.png'
Date: 29 Jun 2015 09:07:20
Message: <55914308$1@news.povray.org>
Am 28.06.2015 um 23:53 schrieb Alain:
>>> Blinking text?
I'll use animated GIFs then. A *lot* of them. Mwahahahaha! }:>
Date: 29 Jun 2015 09:12:58
Message: <5591445a$1@news.povray.org>
Am 29.06.2015 um 13:35 schrieb Thomas de Groot:
Now look at that! I /love/ the material shown on the left!
Now you need to do something about the plane, because it /really/ breaks
the scene.
>      looks_like {
>        sphere {
>          0, SunDis
>          no_radiosity
>          no_reflection
With no_radiosity and no_reflection, it's pretty simple: If the sun is
directly visible in the image, use it. If it's only visible in
reflections, you're perfetly fine without the looks_like.
Date: 30 Jun 2015 02:59:20
Message: <55923e48$1@news.povray.org>
> the scene.
It does. Maybe I shall do that...
[snip]
You confirm my conclusion :-)
Date: 30 Jun 2015 08:06:57
Message: <55928661@news.povray.org>
>> the scene.
For instance this.
Download 'rsocp_uber.png' (378 KB)
Date: 30 Jun 2015 08:15:44
Message: <55928870$1@news.povray.org>
Am 30.06.2015 um 14:06 schrieb Thomas de Groot:
>>> the scene.
> For instance this.
Well, it's a bit of an improvement.
A bit.
Date: 30 Jun 2015 11:29:51
Message: <5592b5ef$1@news.povray.org>
On 6/30/2015 1:06 PM, Thomas de Groot wrote:
> For instance this.
Nice! Now replace the plane with a large torus. :-)
Regards
