Subject: Re: Saturn Ring - Second wip / POV version 3.71
Date: 24 Jan 2015 15:02:46
Message: <54c3fa66$1@news.povray.org>
Am 24.01.2015 um 16:40 schrieb Thomas de Groot:
> I wanted to test the non-linear gradients but was unable to make it> work. From Clipka's note I assumed it should be added to the color or> pigment map blocks but that gives an error, as also added to the pigment> block. I need some guidance here.
Usage should be like this (as an example):
gradient -x translate x*0.75 scale 2
pigment_map {
blend_mode MODE
blend_gamma GAMMA
[0.333 color srgb <1,0,1>]
[0.667 color srgb <1,1,1>]
Similar syntax should be used for colour_map.
Date: 25 Jan 2015 03:31:10
Message: <54c4a9ce$1@news.povray.org>
OK Thanks. I shall try that too. Otherwise, no problems up till now.
Changing the backslash to forward slash was pending for my files for a
long time, so the opportunity was timely :-)
Subject: Re: Saturn Ring - Second wip problem
Date: 27 Jan 2015 03:48:35
Message: <54c750e3@news.povray.org>
I have a problem showing up in the close up view of the ring.
-The upper half of the image shows the ring's isosurfaces with the media.
- The lower half shows the same but without the media.
In the upper half the isosurfaces are cut off in the area closest to the
camera.
Any idea?
Date: 27 Jan 2015 11:01:34
Message: <54c7b65e$1@news.povray.org>
Once you have got these rings worked out to you satisfaction. You could
try modelling this ring system. ;-)
http://www.bbc.co.uk/news/science-environment-31001936
Regards
Date: 28 Jan 2015 03:13:02
Message: <54c89a0e$1@news.povray.org>
On 27-1-2015 17:01, Stephen wrote:
> Once you have got these rings worked out to you satisfaction. You could> try modelling this ring system. ;-)
Indeed. Could give interesting views.
But first our own neighbourhood :-)
