POV-Ray : Newsgroups : povray.binaries.images : Saturn Ring - Second wip Server Time
25 Jun 2026 14:28:53 EDT (-0400)
  Saturn Ring - Second wip (Message 11 to 15 of 15)
Subject: Re: Saturn Ring - Second wip / POV version 3.71
Date: 24 Jan 2015 15:02:46
Message: <54c3fa66$1@news.povray.org>
Am 24.01.2015 um 16:40 schrieb Thomas de Groot:
> I wanted to test the non-linear gradients but was unable to make it
> work. From Clipka's note I assumed it should be added to the color or
> pigment map blocks but that gives an error, as also added to the pigment
> block. I need some guidance here.
Usage should be like this (as an example):
       gradient -x translate x*0.75 scale 2
       pigment_map {
         blend_mode MODE
         blend_gamma GAMMA
         [0.333 color srgb <1,0,1>]
         [0.667 color srgb <1,1,1>]
Similar syntax should be used for colour_map.
Date: 25 Jan 2015 03:31:10
Message: <54c4a9ce$1@news.povray.org>
OK Thanks. I shall try that too. Otherwise, no problems up till now.
Changing the backslash to forward slash was pending for my files for a
long time, so the opportunity was timely :-)
Subject: Re: Saturn Ring - Second wip problem
Date: 27 Jan 2015 03:48:35
Message: <54c750e3@news.povray.org>
I have a problem showing up in the close up view of the ring.
-The upper half of the image shows the ring's isosurfaces with the media.
- The lower half shows the same but without the media.
In the upper half the isosurfaces are cut off in the area closest to the
camera.
Any idea?
Download 'complex_.png' (544 KB)
Preview of image 'complex_.png'
Date: 27 Jan 2015 11:01:34
Message: <54c7b65e$1@news.povray.org>
Once you have got these rings worked out to you satisfaction. You could
try modelling this ring system. ;-)
http://www.bbc.co.uk/news/science-environment-31001936
Regards
Date: 28 Jan 2015 03:13:02
Message: <54c89a0e$1@news.povray.org>
Indeed. Could give interesting views.
But first our own neighbourhood :-)
