Subject: Cut-off meshes - how to avoid them?
Date: 1 Jan 2015 07:02:08
Message: <54a53740@news.povray.org>
Hi(gh)!
While rendering a new version of my Phobos fly-around movie, I pretty
soon found that the mesh2 of the Martian moon is cut off on one or,
sometimes, even on both sides. I tried many settings of overall scaling
values, even translated the whole Solar System so that Mars and its
moons were placed close to the origin, thus avoiding extreme coordinate
values - but whatever I do, the mesh2 is clipped once again (see
attached image below)!
What can I do to get rid of this?
See you in Khyberspace!
Yadgar
Download 'povsolar-at-sc.png' (253 KB)
Preview of image 'povsolar-at-sc.png'
Am 01.01.2015 um 13:02 schrieb "Jörg \"Yadgar\" Bleimann":
> Hi(gh)!
Make sure that the scene is translated so that the camera is close to
<0,0,0>; the further away you go, the more problematic the bounding
becomes, as it uses low ("single") precision floating point numbers to
minimize the bounding tree memory footprint.
Subject: Re: Cut-off meshes - how to avoid them?
Date: 1 Jan 2015 17:32:09
Message: <54a5cae9@news.povray.org>
Hi(gh)!
Am 01.01.2015 um 18:35 schrieb clipka:
> <0,0,0>;
O.k., I understand - currently the camera is still at about <6000, 0,
6000> (or so), while Mars sits at the origin.
May that change in the future? Will there be POV-Ray versions which use
double or even long double floats for bounding?
A smaller epsilon value also sounds tempting...
Yadgar
[hint] That should be easy to implement by the Team shouldn't it? and
would solve a lot of related problems ;-) After all, a hack in that
sense was made some years ago to accommodate the Ring World.
Thorsten has already addressed this, and it appears (tentatively) to be
a no-go. See Flyspray #297.
Hmmm right. I see. It did help a bit though but seemingly it is not the
ultimate solution. I retract my comment :-)
