POV-Ray : Newsgroups : povray.binaries.images : povray.newusers: Infinite car garage Server Time
21 Jul 2025 13:20:00 EDT (-0400)
  povray.newusers: Infinite car garage (Message 1 to 5 of 5)
Subject: povray.newusers: Infinite car garage
Date: 25 Oct 2014 07:53:09
Message: <544b8f25@news.povray.org>
Illustrating my solution :-)
Download '01_test.png' (201 KB)
Preview of image '01_test.png'
Subject: Re: povray.newusers: Infinite car garage
Date: 25 Oct 2014 10:05:01
Message: <web.544bada09c4150c45e7df57c0@news.povray.org>
What about the f_helix2 "isosurface by function" in the drop-down POV-Ray Insert
Menu?
I'm constantly amazed by how much good stuff is in there that I overlook or
forget is there!
isosurface { //-------------------------------------------------------------
  function{
     f_helix2(
        x,y,z,
        0,    // not used,
        12,    // period,      turns on the length of 2*pi
        0.38, // minor radius,
        0.50, // major radius,
        0,    // not used,
        0.5,  // cross section type, (0.0 to 1.0 = square ... rounded to circle
              //                 over 2.0 to 3.0 = rounded to diamond and
concave diamond
        0     // cross section rotation angle
 contained_by {box {<-1,-1,-1>,<1,1,1>}}
 max_gradient 8
 texture{ pigment{ color rgb <1,1,1>*1.1}
          finish { specular 0.4 phong 0.7 }
 scale 0.9
 rotate<0,0,0>
 translate< 0,1.2,0>
} // end of isosurface -------------------------------------------------------
Download '55 - isosurface f_helix2.jpg' (6 KB)
Preview of image '55 - isosurface f_helix2.jpg'
Date: 25 Oct 2014 10:19:04
Message: <544bb158$1@news.povray.org>
> Menu?
> forget is there!
I tried that first (obviously) but in the end I found the results less
'reliable' even than with f_helix1.
I finished the construction with some parameters the user can change,
and added the 'infinity':
#include "functions.inc"
#declare Thickness = 0.02;  //thickness of floors & ramps
#declare Height = 0.5;  //distance between floor levels
#declare Level =
union {
   difference {
     cylinder {
       <0,0,0>,<0,Thickness,0>, 1.00
     #local Prism =
     difference {
       prism {
         -0.01, 0.11, 4
         <-0.50, 0.00>, // first point
         < 0.50, 0.00>,
         < 0.00,-1.00>,
         <-0.50, 0.00>  // last point = first point !!!
         scale <1.00, 1.00, 1.00>
         rotate <0,0,0>
         translate <0.00, 0.00, 1.00>
       cylinder {
         <0,-0.2,0>,<0,0.12,0>, 0.50
         scale <1,1,1> rotate<0,0,0> translate<0,0,0>
     } //end of difference
     object {Prism
       rotate (180+27)*y
     object {Prism
       rotate 27*y
   #include "spring.inc"
   // The spring is created with it's base on the origin, oriented on
the +X axis
   // U and V are the rectangular width and height of the spring wire
   // X_Length is the overall length of the spring
   // Radius is the radius of the spring
   // Coils is the number of turns the spring makes (fractional numbers
are OK)
   // Rez is the appoximate number of desired triangles in the mesh.
   #local Ramp =
   object {
     // U, V, length, radius, coils, rez
     Spring (Thickness, 0.5, Height, 1.0, 0.5, 5000)
     rotate 90*z
   object {Ramp
     rotate 90*y
   object {Ramp
     rotate -90*y
     pigment {color rgb <1,1,0.8> }
     normal  {bumps 0.1 scale <0.005,0.005,0.005>}
     finish  { phong 0.5 reflection{ 0.00 metallic 0.00} }
} //end of union
#declare N=1;
union {
   object {Level}
   #for (N,1,100)
     object {Level
       rotate -54*y*N
       translate (Height-Thickness)*y*N
   rotate 160*y
Date: 25 Oct 2014 10:34:00
Message: <544bb4d8@news.povray.org>
With the corresponding image
Download '01_test.png' (623 KB)
Date: 26 Oct 2014 05:26:49
Message: <544cbe59@news.povray.org>
I am sorry. I could not help but do a little bit more work on this ;-)
Download '01_test.png' (653 KB)
