POV-Ray : Newsgroups : povray.binaries.images : unexplained Server Time
27 May 2026 22:05:05 EDT (-0400)
  unexplained (Message 9 to 18 of 58)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: unexplained
Date: 12 Aug 2014 13:48:26
Message: <53ea536a$1@news.povray.org>
Am 12.08.2014 19:34, schrieb James Holsenback:
> I stayed out of my local git repos as I've made some changes ... Instead
> downloaded the zip package made available from povray github with the
> master filter selected, it has this hash
> ad6d545729bbd92800fc2d65fe74dcac86408c27 and has the problem.
That's 3.7.1-alpha.7681813, so same version as I used.
> With 3.7-stable filter set, this hash
> 39ce8a24e50651904010dda15872d63be15d7c37 tis ok fine
That's the genuine 3.7.0 release proper, aka "3.7.0 stable".
Date: 12 Aug 2014 13:53:37
Message: <53ea54a1$1@news.povray.org>
On 08/12/2014 01:41 PM, clipka wrote:
> Am 12.08.2014 19:08, schrieb James Holsenback:
>> found OTOTest.pov file laying around in some obscure corner ... here's
>> results
> Well, what can I say, other than "I can't reproduce it"?
> Unless you can trim down the thing to an extremely minimalistic scene
> (say, one or two primitives with one or two textures) that is rendered
> differently by the builds you're using, or can nail down exactly what
> GitHub commit broke it, I might be able to do some guessing; but until
> then, unfortunately it looks like I need you to do more experimenting.
well it's after 3.7-stable for sure ... OTOc.inc sources math.inc dunno
if that could be a clue.
Date: 12 Aug 2014 14:42:39
Message: <53ea601f$1@news.povray.org>
Am 12.08.2014 19:53, schrieb James Holsenback:
>>> results
Thanks for the help, you just narrowed it down to a meagre 120-130
commits :-)
I hadn't thought of include files, and it would seem a tempting
explanation, as I'm not regularly updating my installed set of those;
but a quick check reveals that I'm already using the newest; which is
not too surprising, giving that only three changes have been made within
the include directory since 3.7-stable so far, and none of them seems
anywhere close to being a plausible candidate. (And no, math.inc hasn't
been changed at all.)
Date: 12 Aug 2014 14:55:50
Message: <53ea6336$1@news.povray.org>
>>>> results
> commits :-)
narrowed a bit further ... this hash works fine:
9a278c7f02003b7e6d6d0665c37695351cb23a27 so something after that!!!!
Date: 12 Aug 2014 15:53:08
Message: <53ea70a4@news.povray.org>
>>>>> results
>> commits :-)
ok so at hash 54b283a0d39c637ce9d4ab16512a364e993c58c5 its busted so I
think that's considerable less territory to cover.
Date: 13 Aug 2014 03:16:22
Message: <53eb10c6$1@news.povray.org>
Yet another compiler issue ?
Is there a full-scene available for download and test ?
Just because nobody complains does not mean all parachutes are perfect.
Date: 13 Aug 2014 04:26:57
Message: <53eb2151$1@news.povray.org>
I'm having my suspicions that is what's going on ...
Yep ... the OTOTest.pov file that comes with the OTOc.inc package (over
in p.b.scene-files
Date: 13 Aug 2014 06:11:38
Message: <53eb39da$1@news.povray.org>
>>>>>> here's
>>>>>> results
>>> commits :-)
this hash ac564f7231f2b05b461a3a03fe6b9ed21b845c5a is the last working
commit (compiles and runs OTOTest.pov properly)
broken @ cf1c3fbedb33802bd431acac43ce41db55fa87b8 ... doesn't even
compile ./base/safemath.h is belching errors all over the place
In file included from base/image/image.cpp:57:0:
scope
./base/safemath.h:51:2: note: suggested alternative:
./base/safemath.h:61:33: note: candidates are:
/usr/include/c++/4.6/bits/stl_algobase.h:254:5: note: template<class
_Tp, class _Compare> const _Tp& std::max(const _Tp&, const _Tp&, _Compare)
/usr/include/c++/4.6/bits/stl_algobase.h:210:5: note: template<class
_Tp> const _Tp& std::max(const _Tp&, const _Tp&)
make[2]: *** [base/image/image.o] Error 1
Date: 13 Aug 2014 07:28:26
Message: <53eb4bda$1@news.povray.org>
Am 13.08.2014 12:11, schrieb James Holsenback:
Ah, yes, that one... that's part of GitHub issue #29. It'll need
replacing of "numeric_limits" with "std::numeric_limits" (and then
probably some more fixes).
Date: 13 Aug 2014 16:07:10
Message: <53ebc56e@news.povray.org>
>>>> Instead
Identify your compiler ?
mine is gcc 4.8.2 (ubuntu) and testing with
ad6d545729bbd92800fc2d65fe74dcac86408c27 (head of master), it works ok here.
(from OTOC... )
(I did not reinstall the include files, so changes in such files might
not be reflected)
> in p.b.scene-files
Thanks.
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
