POV-Ray : Newsgroups : povray.binaries.images : Stochastic Global Illumination Server Time
25 Jun 2026 20:13:56 EDT (-0400)
  Stochastic Global Illumination (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Stochastic Global Illumination
Date: 24 Jul 2014 05:42:48
Message: <53d0d518$1@news.povray.org>
On 07/24/2014 05:29 AM, scott wrote:
>>> To disable caching, just add the keyword "no_cache" to the radiosity
>>> block. Make sure to not set the "count" parameter too high - a value as
>>> low as 10 is perfectly ok for this approach.
>> Hmmm ... I'm getting an error
>> File 'Work.pov' line 86: Parse Error: No matching } in 'radiosity',
>> undeclared
>>   identifier 'no_cache' found instead
>> Fatal error in parser: Cannot parse input.
>> Render failed
> Hmmm works OK here - are you sure you're running the latest executable?
relatively sure ... i already had git repo defined so all i had to do
was: git pull develop develop to update. make was showing the same
warnings that I reported in "Perfect Polish" thread, and version shows:
UberPOV 1.37-dev
Date: 24 Jul 2014 05:57:03
Message: <53d0d86f$1@news.povray.org>
> UberPOV 1.37-dev
Oh ok, I just took the windows binary, that might explain it.
Date: 24 Jul 2014 09:50:10
Message: <53d10f12@news.povray.org>
Am 24.07.2014 11:42, schrieb James Holsenback:
>>> undeclared
>>> Render failed
> UberPOV 1.37-dev
"UberPOV 1.37-dev" can be virtually anything; I suggest fetching the
official v1.37.0.0-beta.6 sources.
(Or pull the develop branch again... it so happens that I hadn't pushed
the latest changes to that branch yet, just the master branch. Whoops.)
Date: 24 Jul 2014 11:47:16
Message: <53d12a84$1@news.povray.org>
>>>>> value as
>>>> undeclared
>>>> Render failed
>> UberPOV 1.37-dev
Hmmmm ... when I'm looking at:
https://github.com/UberPOV/UberPOV/tree/develop
I see this hash:
784444e26b841d91118af7ca26a5f1ffefe60dbc
with this description:
Merge branch 'release/v1.37.0.0-beta.6' into develop
time stamped 13hrs ago
so doing 'git pull develop develop' /should/ have done trick.
Date: 24 Jul 2014 12:21:04
Message: <53d13270$1@news.povray.org>
>>>>>> value as
>>>>> undeclared
>>>>> Render failed
>>> UberPOV 1.37-dev
> I see this hash:
my local repo must have gotten out of sync because i nuked it then
reinitialized it and now uberpov --version returns:
UberPOV 1.37.0.0-beta.6
Date: 24 Jul 2014 13:10:23
Message: <53d13dff@news.povray.org>
Am 24.07.2014 17:47, schrieb James Holsenback:
> I see this hash:
Yes - that's indeed when I did the merge...
.. Locally.
if you had pulled right from my local computer, then yes :-P
Date: 24 Jul 2014 13:15:47
Message: <53d13f43@news.povray.org>
>> I see this hash:
> .. Locally.
ruh???
Date: 24 Jul 2014 13:48:41
Message: <53d146f9@news.povray.org>
>> I see this hash:
> .. Locally.
just got your meaning ... ok, so i'm slow today :-P
Date: 24 Jul 2014 13:52:31
Message: <53d147df@news.povray.org>
Am 24.07.2014 19:15, schrieb James Holsenback:
>>> I see this hash:
>> .. Locally.
> ruh???
Okay, I take this as an indication that you're not /too/ familiar with
the distributed nature of the Git revision control system. ;-)
In contrast to Perforce, where you only have one central repository, in
Git you have plenty of them. And none of them is any more authoritative
than the other.
When you do a "git pull", you're actually performing a (unidirectional)
sync of a local repository on your machine with whatever repository you
told git to typically sync with; that means you apply to your local repo
all the commits to the remote ("origin") repo since the previous pull.
(Note that this requires that you haven't made any changes to the
respective branch in your local repo. If that happens, you need to
reconcile the two repos by applying a merge to both.)
(Note that your local working directory is /not/ your local repo. The
local repo instead resides in the ".git" directory therein.)
Likewise, I also have a local repo on my machine (I actually can't avoid
that). When I make changes to the code, I first commit them to the local
repo. I can also merge branches in the local repo. Only when I'm happy
with it all, I will "push" the local changes to the remote repo on
GitHub, i.e. apply all the local commits to the "origin" repo. (Again
this requires that nobody else has made any changes to the respective
branch on the origin repo. If that happens, a reconciliatory merge is
required again.)
It's also possible to propagate commits between repos "sideways", i.e.
without one of the repos being the "origin" of the other, provided that
there is /some/ common history in both repos; any history in between
will automatically be propagated as well.
When changes are propagated from one repo to another, the original
information of that change is propagated as well, including the time and
date of the commit.
Date: 24 Jul 2014 13:55:28
Message: <53d14890$1@news.povray.org>
Am 24.07.2014 19:48, schrieb James Holsenback:
>>> I see this hash:
>> .. Locally.
Well, in this case you were actually faster than I was, at least as far
as the pulling and pushing is concerned ;-)
