![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Following my question in p.a-u, I searched the web for some free
software. I came across this site:
http://www.techsupportalert.com/best-free-high-dynamic-range-hdr-software.htm
and used the first one proposed (Fusion 1) to try out on a POV scene.
As render set, I used 4 renders of my Urbex scene with varying light
intensities and processed them through Fusion 1, using the Summator as
advised on the site. This is the/a result.
I think this looks quite promising while needing further experimentations.
Download 'urbex_hh_sum.jpg' (177 KB)
Preview of image 'urbex_hh_sum.jpg'
![urbex_hh_sum.jpg](/povray.binaries.images/attachment/%3C538328d5%40news.povray.org%3E/urbex_hh_sum.jpg?ttop=443824&toff=1350&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This would be a result using the HDR operator instead of Summation.
Download 'urbex_hh_hdr_mode_1.jpg' (140 KB)
Preview of image 'urbex_hh_hdr_mode_1.jpg'
![urbex_hh_hdr_mode_1.jpg](/povray.binaries.images/attachment/%3C53832b69%40news.povray.org%3E/urbex_hh_hdr_mode_1.jpg?ttop=443824&toff=1350&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Le 26/05/2014 13:54, Thomas de Groot nous fit lire :
> Thomas
I knew something was not right.... the old age painter might have done a
dual-tone paint: one below 1m or so, one above... maybe with a
contrasting line between the two. (dark below, lighter above)
And probably a different color for the ceiling... traditional white ? or
egg-like ?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Thomas
> egg-like ?
I am following closely the original photograph where the whole space is
painted in the same way, walls and ceiling. There is however a wainscot
along the wall and the stairs. I have not yet provided that. Also, in a
later stage, I may diverge from the original of course ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I think I like this one better. It is a bit less extreme and I just left
some of the settings alone. Summation used.
![urbex_hh_sum.jpg](/povray.binaries.images/attachment/%3C53844813%40news.povray.org%3E/urbex_hh_sum.jpg?ttop=443824&toff=1350&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Forgot to add: based on four renders with different illumination
intensities.
About Fusion F1:
- the help does not work. However, a htm document is provided with the
program.
- The program also can read png files although this is not mentioned.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Thomas
It looks like the list has changed a bit because it no longer have HDR software
called Fusion 1. And it starts with Luminance. And there also a good tool
https://aurorahdr.com for creating HDR effect.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 01.07.2017 um 23:22 schrieb Diane:
>> Thomas
Look at the site again - the first entry is still "Fusion" (not "Fusion
1" though).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> Thomas
> 1" though).
IIRC, Fusion 1 became Fusion at some point. I have used it recently for
my own photography; /not/ POV-Ray ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
