POV-Ray : Newsgroups : povray.binaries.images : uv_mapping Server Time
27 May 2026 15:46:59 EDT (-0400)
  uv_mapping (Message 1 to 9 of 9)
Subject: uv_mapping
Date: 15 Feb 2014 18:31:58
Message: <52fff8ee@news.povray.org>
image showing my problem mentioned in p.general ... top one /with/
uv_mapping bottom one /without/
Download 'work.png' (610 KB)
Preview of image 'work.png'
Subject: Re: uv_mapping
Date: 15 Feb 2014 19:00:01
Message: <web.52fffefdb7d5a815d19b0ec40@news.povray.org>
So, you're taking my suggestion of texture baking the marble floor of your dice.
Should look good once it's done.
Date: 16 Feb 2014 03:26:27
Message: <53007633@news.povray.org>
Le 16/02/2014 00:31, James Holsenback nous fit lire :
The image seems good to me.
The not-uv-mapped is using pattern with a size of 19 (9.5*2),
whereas the uv-mapped is using the same pattern (at z=0) with a size of
1, (range of your uv-vectors).
If you want the same "aspect", you need a scale 1/19 on the texture (of
top mesh).
Date: 16 Feb 2014 06:34:27
Message: <5300a243@news.povray.org>
> top mesh).
yep ... that's the obvious answer ;-)
tried all kinds of various transformations ... this image has non uv
mapped scale at 1 and uv mapped scale at 0.05 (~ 1/19 )
Download 'work.png' (488 KB)
Date: 16 Feb 2014 09:24:23
Message: <5300ca17@news.povray.org>
Le 16/02/2014 12:33, James Holsenback nous fit lire :
Ok, time to post the whole scene. I'm out of idea.
Date: 16 Feb 2014 10:29:36
Message: <5300d960$1@news.povray.org>
don't think it's the scene but rather how i've got the object setup in
blender. when i get a chance i'm gong to move the object so that's it
ends up with lower left corner is at 0,0 ... then the object will be
totally in the +x,+z quadrant (povray handiness). i've been playing
around with scale of 1 in texture and fiddle with scaling uv_vectors ...
i've at least got the pattern to appear mapped to the center of the
object. yikes this is turning out to be more involved than anticipated
Date: 16 Feb 2014 11:23:35
Message: <5300e607@news.povray.org>
Le 16/02/2014 16:29, James Holsenback nous fit lire :
I just meant the scene with the two squares. It should be short enough.
If blender is in the equation, maybe someone else can help... but
finding first what would have been the correct pov-scene might help too.
Date: 16 Feb 2014 14:08:20
Message: <53010ca4$1@news.povray.org>
me too (out of ideas) ... posted scene file over in p.b.scene-files
good luck!
Date: 16 Feb 2014 14:15:16
Message: <53010e44$1@news.povray.org>
Le 16/02/2014 20:08, James Holsenback nous fit lire :
> good luck!
Found. see the answer there.
