image showing my problem mentioned in p.general ... top one /with/
uv_mapping bottom one /without/
Download 'work.png' (610 KB)
Preview of image 'work.png'
So, you're taking my suggestion of texture baking the marble floor of your dice.
Should look good once it's done.
Le 16/02/2014 00:31, James Holsenback nous fit lire :
The image seems good to me.
The not-uv-mapped is using pattern with a size of 19 (9.5*2),
whereas the uv-mapped is using the same pattern (at z=0) with a size of
1, (range of your uv-vectors).
If you want the same "aspect", you need a scale 1/19 on the texture (of
top mesh).
> top mesh).
yep ... that's the obvious answer ;-)
tried all kinds of various transformations ... this image has non uv
mapped scale at 1 and uv mapped scale at 0.05 (~ 1/19 )
Download 'work.png' (488 KB)
Le 16/02/2014 12:33, James Holsenback nous fit lire :
Ok, time to post the whole scene. I'm out of idea.
don't think it's the scene but rather how i've got the object setup in
blender. when i get a chance i'm gong to move the object so that's it
ends up with lower left corner is at 0,0 ... then the object will be
totally in the +x,+z quadrant (povray handiness). i've been playing
around with scale of 1 in texture and fiddle with scaling uv_vectors ...
i've at least got the pattern to appear mapped to the center of the
object. yikes this is turning out to be more involved than anticipated
Le 16/02/2014 16:29, James Holsenback nous fit lire :
I just meant the scene with the two squares. It should be short enough.
If blender is in the equation, maybe someone else can help... but
finding first what would have been the correct pov-scene might help too.
me too (out of ideas) ... posted scene file over in p.b.scene-files
good luck!
Le 16/02/2014 20:08, James Holsenback nous fit lire :
> good luck!
Found. see the answer there.
