POV-Ray : Newsgroups : povray.binaries.images : texture baking and meshcam Server Time
27 May 2026 15:47:43 EDT (-0400)
  texture baking and meshcam (Message 1 to 9 of 9)
Subject: texture baking and meshcam
Date: 13 Feb 2014 12:31:52
Message: <52fd0188@news.povray.org>
Copied the meshcam scene files into an alternate location and started
going through the baking demo ....
There were some warnings associated with not setting assumed_gamma
before calling/using rgb vectors, and warnings in light_source
definitions ... suspicious value after rgb. I fixed all those, and
submitted changes to revision control, but that didn't address the
unexpected results I'm seeing!!!
Has anyone else worked through the demo?
Download 'baking_demo.png' (516 KB)
Preview of image 'baking_demo.png'
Subject: Re: texture baking and meshcam
Date: 13 Feb 2014 14:50:01
Message: <web.52fd212c841cc184b23e54380@news.povray.org>
Just tried it on Windows version. It works fine.
Date: 13 Feb 2014 15:08:11
Message: <52fd262b@news.povray.org>
   Hmmm... everything seems to work fine here, both the bakind and the
rendering steps (using final 3.7 compiled from sources a few months
ago). BTW, it renders fine with Uberpov too...
jaime
Date: 13 Feb 2014 17:43:24
Message: <52fd4a8c$1@news.povray.org>
> jaime
Thanks for the nudge ... I've been using uberpov-dev for a bit and that
works fine. Since povray is obviously busted on my system, I did a fresh
build from the perforce repository and that appears to be broken. Can
anyone with perforce access confirm? I did a fresh pull/build from the
povray github and that works fine. The plot thickens!
Date: 14 Feb 2014 12:18:42
Message: <52fe4ff2$1@news.povray.org>
Le 13/02/2014 23:43, James Holsenback nous fit lire :
> Since povray is obviously busted on my system, I did a fresh build from
> the perforce repository and that appears to be broken. Can anyone with
Rebuilding (after getting latest revision of smp at 6194) (only make
clean, ./configure & make, not running prebuild.sh ) : compile & link
fine with:
./configure COMPILED_BY="Jérôme Grimbert <jgr### [at] freefr>"
--disable-io-restrictions LIBS="-lboost_system -lboost_thread"
BUT
--disable-io-restrictions LIBS="-lboost_system"
succeeds with configure, yet the final link fails.
> g++  -pipe -Wno-multichar -Wno-write-strings -fno-enforce-eh-specs -s -O3
-ffast-math -march=native -pthread  -L/usr/lib  -L/usr/lib -o povray disp_sdl.o
disp_text.o ../vfe/libvfe.a ../source/libpovray.a -lSDL -L/usr/lib/x86_64-linux-gnu
-lSDL  -lSM -lICE -lX11  -lIlmImf -pthread -lIlmImf -lz -lImath -lHalf -lIex
-lIlmThread   -lIlmThread -ltiff -ljpeg -lpng -lz -lrt -lm  -lboost_system -pthread
> ../vfe/libvfe.a(vfesession.o): dans la fonction « vfe::vfeSession::Shutdown(bool)
> vfesession.cpp:(.text+0xcd2): référence indéfinie vers «
boost::thread::native_handle() »
> vfesession.cpp:(.text+0xce7): référence indéfinie vers «
boost::thread::join_noexcept() »
> vfesession.cpp:(.text+0xcfb): référence indéfinie vers « boost::thread::detach()
vfe::vfeSession::Initialize(vfe::vfeDestInfo*, vfe::vfeAuthInfo*) »:
> vfesession.cpp:(.text+0x314b): référence indéfinie vers « vtable for
boost::detail::thread_data_base »
> vfesession.cpp:(.text+0x3304): référence indéfinie vers «
boost::thread::start_thread_noexcept() »
> vfesession.cpp:(.text+0x3339): référence indéfinie vers «
> vfesession.cpp:(.text+0x3352): référence indéfinie vers «
> ../vfe/libvfe.a(vfesession.o): dans la fonction « vfe::vfeSession::Resume() »:
and so on (many pages). (sorry, compiler message is in French)
Test done on Ubuntu 13.10, 64 bits (x86_64)
Date: 14 Feb 2014 15:10:11
Message: <52fe7823$1@news.povray.org>
> fine with:
> BUT
boost::thread::detach() »
it's compiles and links just fine on older 32bit system ... I /just/
pass the COMPILED_BY string, but it produces the odd image posted
earlier. I haven't tried running some of my old scenes just to see. I
got rid of the perforce version in favor of github. I'm wondering if it
has anything to do with /all/ the re-factoring work that's been done.
Date: 10 Aug 2014 05:19:47
Message: <53e73933@news.povray.org>
   Hmmm... this exact problem seems to be happening on the latest master
branch from github (works fine on the stable branch). Seems like
something went wrong with the mesh camera...
Jaime
Date: 18 Aug 2014 14:28:13
Message: <53f245bd$1@news.povray.org>
Am 10.08.2014 11:19, schrieb Jaime Vives Piqueres:
As it turns out, James was onto something back then already: The POV-Ray
master branch was still ok then, but he must have built from the
refactor branch, where the bug had been introduced on 2013-12-16 with
commit 5cee76e.
That branch was merged into the POV-Ray master branch on 2014-06-13
(which happens to have been a Friday, yes) with commit 2c4e9f2.
Quite a silly bug actually, and a one-liner to fix.
Date: 18 Aug 2014 17:38:55
Message: <53f2726f$1@news.povray.org>
> commit 5cee76e.
   I didn't use the mesh cam for a while, but some weeks ago someone was
toying with my lightmapping demo, and got very strange results. I tried
it myself, and the result looked familiar... thanks for the fix!
jaime
