POV-Ray : Newsgroups : povray.binaries.images : Paradise Server Time
31 Mar 2026 02:39:23 EDT (-0400)
  Paradise (Message 1 to 10 of 18)
Subject: Paradise
Date: 11 Feb 2014 23:21:22
Message: <52faf6c2@news.povray.org>
OK ... not what you expected ;-)
Playing around with subsurface
Download 'work.png' (4485 KB)
Preview of image 'work.png'
Subject: Re: Paradise
Date: 12 Feb 2014 01:58:57
Message: <52fb1bb1$1@news.povray.org>
Para-Dice! Nice!
Do not judge my words, judge my actions.
http://www.avast.com
Date: 12 Feb 2014 02:05:01
Message: <web.52fb1d0727e1c16dd19b0ec40@news.povray.org>
Nice.
Now add focal blur and radiosity and report back the render time difference.
Mwahahahaaaaaa!!!
Date: 12 Feb 2014 03:24:27
Message: <52fb2fbb$1@news.povray.org>
Nice stuff and the pun is very appropriate indeed :-)
Date: 12 Feb 2014 06:40:23
Message: <52fb5da7$1@news.povray.org>
> Nice.
> Mwahahahaaaaaa!!!
Already done that ... with radiosity 47+ hrs and I didn't like the
results. I used Radiosity_Fast with pretrace_end 0.004, count 256 and
gray_threshold 1 /without/ sslt to gather the rad data. It looked pretty
decent. The 2nd run with gathered rad data and sslt missed the mark :-(
Is pre-gathered rad data a no-no in this case???
This version /tries/ to try to resolve with a 2nd fill light more
reasonable render time ~15hrs
Obviously I still have some work to do!
Date: 12 Feb 2014 06:58:49
Message: <52fb61f9$1@news.povray.org>
I'm suffering from the recent round of corny-ness in off-topic, and
couldn't resist ;-)
Date: 12 Feb 2014 09:54:05
Message: <52fb8b0d$1@news.povray.org>
> couldn't resist ;-)
I have not been there for some considerable time, so...
Date: 12 Feb 2014 12:05:01
Message: <web.52fba92e27e1c16d6d4f68260@news.povray.org>
Looks very nice indeed! =)
Date: 12 Feb 2014 13:35:01
Message: <web.52fbbeab27e1c16de66d855b0@news.povray.org>
Very nice, your dice.
I only wonder about the table. It seems to be of marble, a classic material for
SSLT. I suspect that there is no SSLT on it. But I fear this will prolong the
rendering time a bit.
Best regards,
Michael
Date: 12 Feb 2014 14:12:51
Message: <52fbc7b3$1@news.povray.org>
well I'm calling it a ground plane ... zero thickness box just big
enough to not see the edges with the camera view. It /does/ look like
marble but it done as follows:
#declare GroundPlaneMat =
material {
   #if (Detail)
     planar
     scale 0.5
     turbulence 1 lambda 3
     color_map {
       [0 srgb <0.9570,0.9570,0.8594>]
       [1 srgb <0.9570,0.9570,0.8594>/2] }
     finish {
       specular 0.15
       roughness 1e-1
     normal{
       planar
       scale 0.5
   #else
     pigment { srgb 1 }
the /main/ reason no sslt on ground plane is the scale factor in globals
used to make dice look good did not suit for the ground plane, and as
far as I know you can't have two different scales ... btw: used 15.
Here's the dice material:
#declare DieMaterial_=
#local Color = <0.5500,0.0900,0.0900>;
#local T_val = Color*2.75;
material {
     #if (Detail)
       pigment { srgb Color }
       finish {
         specular 0.5
         roughness 1/80
         reflection { 0, srgb Color*0.125 }
         #if ( Subsurface )
           subsurface { translucency srgb T_val }
     #else
       pigment { srgb 1 }
   interior {
     ior 2.5
