POV-Ray : Newsgroups : povray.binaries.images : Strange behaviour of #fopen Server Time
30 Sep 2024 03:16:42 EDT (-0400)
  Strange behaviour of #fopen (Message 1 to 3 of 3)
Subject: Strange behaviour of #fopen
Date: 5 Feb 2014 11:18:33
Message: <52f26459$1@news.povray.org>
Hi(gh)!
I want to read in a POV-Ray script from an external file to create a
text object out of it - but whenever I try to start the main script, I
get the error message related to the script to be read in:
"Parse Error: Expected 'float, vector, or string literal' light_source
found instead"
Why that?
Here is the relevant section of the main script:
#declare fullscript = array[483];
#declare i=0;
#declare line="";
#fopen script "../../texturesinc_demo.pov" read
#while (defined(script))
   #read (script, line)
   #declare fullscript[i] = line;
   #declare i=i+1;
#fclose script
See you in Khyberspace!
Yadgar
Subject: Re: Strange behaviour of #fopen
Date: 5 Feb 2014 18:44:25
Message: <52f2ccd9@news.povray.org>
> found instead"
> Why that?
 From the documentation of "#read":
The format of the data to be read must be a series of valid string
literals, float literals, or vector literals separated by commas.
Basically this means you cannot read arbitrary text files,
only "csv-like" data files. Also, AFAIK, the implementation of
#read to some extent reuses the POV-Ray expression parser, so
you might get strange messages reading source files.
Date: 5 Feb 2014 19:41:41
Message: <52f2da45$1@news.povray.org>
Hi(gh)!
Ah yes, I remember... so I have started to enclose each line with "",
followed by a comma - and, indeed, now the error message points at the
first line not treated this way!
Thank you for the hint!
Yadgar
