POV-Ray : Newsgroups : povray.binaries.images : LanuHum Global Test image Server Time
28 May 2026 01:28:29 EDT (-0400)
  LanuHum Global Test image (Message 77 to 86 of 126)
Subject: Re: LanuHum Global Test image - wip 4
Date: 12 Jan 2014 18:20:01
Message: <web.52d3226ceff00a3991114470@news.povray.org>
Ive <ive### [at] lilysoftorg> wrote:
> Am 12.01.2014 13:13, schrieb Thomas de Groot:
> > Over all, I am well satisfied but before going for the final render I
> > would like your opinions.
> Well, those light beams look always nice but I ask myself: do they
> really add anything to *this* particular scene.
> And where are the caustics on the ceiling, IMO for this scene a more
> interesting effect - and your photon settings look fine to me, no idea
> whats wrong there, I did get them immediately.
> -Ive
Thomas, if this helps, I have the objects setup like this to get the proper
caustics (and "collect off" increased render speed x4):
#include "frame_side_object.inc"
object {
   frame_side_ob
   photons {
      pass_through
      collect off
#include "frame_top_001_object.inc"
object {
   frame_top_001_ob
   photons {
      pass_through
      collect off
#include "frame_top_object.inc"
object {
   frame_top_ob
   photons {
      pass_through
      collect off
#include "water_object.inc"
object {
   water_ob
   photons {
      target
      reflection on
      refraction on
#include "pool_object.inc"
object {
   pool_ob
   photons { collect on }
#include "arc_object.inc"
object {
   arc_ob
#include "walls_object.inc"
object {
   walls_ob
www.McGregorFineArt.com
Date: 13 Jan 2014 03:01:26
Message: <52d39d56$1@news.povray.org>
They don't, I agree. What is more, with the light_source again in the
right place, there is a very distrubing shadow bar across the image
falling from the skylight.
There still are some things I am doing wrong. Robert's code (see his
post) shows me were I went wrong.
Subject: Re: LanuHum Global Test image - wip 3
Date: 13 Jan 2014 03:04:39
Message: <52d39e17$1@news.povray.org>
On 12-1-2014 17:49, Robert McGregor wrote:
> Looking really nice Thomas, I like the subtle media beams! Don't forget to add
> pass_through to the photon blocks for the skylights and the water (to allow
> reflected caustics on arch and ceiling).
Yes, I still have not fully understood the working of photons. Thanks
for the code you posted later, that is going to help.
> I'm having a go at this myself and found that the walls had nearly 10,000 stray
> verts in the mesh that needed merging; and letting PoseRay re-process those
> Blender meshes makes the textures so much easier to manage! WIP currently
> rendering...
Indeed. All vertices had to be merged in the objects. I only did that
for the relevant objects I needed to change however. I left the others
alone.
Looking forward to your version!
Date: 13 Jan 2014 03:07:48
Message: <52d39ed4$1@news.povray.org>
On 12-1-2014 18:53, clipka wrote:
> Am 12.01.2014 17:11, schrieb LanuHum:
>> I don't understand, what is reflected in a mirror in a floor? From
>> what there
>> the washed-away light spot?
>  From what I understand, that's blurred reflections on the floor tiles,
> using an approach dubbed "micronormals": You use standard specular
> reflection on a texture, but also add some normal perturbation (using a
> pattern with some randomness), scaled so small that the structure is
> smaller than the image resolution; last not least you also make sure
> there is sufficient oversampling (often via a bit of focal blur, or
> plenty of anti-aliasing; sometimes it is also done by using an average
> texture comprised of countless duplicates of the base texture with
> random differences in the normal perturbation).
That is right. I used micronormals here. Just a very small granite
normal. In a future version I intend to use UberPOV's blurred
reflections instead.
Date: 13 Jan 2014 03:09:57
Message: <52d39f55$1@news.povray.org>
Thanks a lot Robert! I can see were I go wrong in my code!
I am in the learning process as these are my first time ever photons :-)
Subject: Re: LanuHum Global Test image: wip 4b
Date: 13 Jan 2014 04:05:24
Message: <52d3ac54@news.povray.org>
Got them!
A crude render as test but I got the caustics right now. They show on
the ceiling.
Thanks to Robert showing me the way.
Comments?
Download 'test.png' (408 KB)
Preview of image 'test.png'
Subject: Re: LanuHum Global Test image - wip 4c
Date: 13 Jan 2014 04:19:35
Message: <52d3afa7@news.povray.org>
Adding some environment...
Download 'test.png' (417 KB)
Date: 13 Jan 2014 04:55:01
Message: <web.52d3b786eff00a3967c13c250@news.povray.org>
> object {
>    walls_ob
I thought all objects defaulted to "collect on" anyway? Could this be where I
have gone wrong with photons in the past?
Sean
Date: 13 Jan 2014 06:04:29
Message: <52d3c83d@news.povray.org>
"Thomas de Groot" <tho### [at] degrootorg> wrote in message
news:52cd5186@news.povray.org...
> With only a few necessary corrections (see p.general) this is a first
> brutish render of the test scene provided by LanuHum. Added basic
> radiosity too.
> Thomas
First attempt.
I am replacing some of the objects with ones more suitable for Pov.
 Sphere{}.
 Isosurface for water.
 Copies for Mesh2{}: chair, floor tiles.
Todo: CSG door, shelf, and pool.
Comments welcome:
Stephen S
Download 'New_test_pov_b.png' (361 KB)
Preview of image 'New_test_pov_b.png'
Date: 13 Jan 2014 07:10:44
Message: <52d3d7c4$1@news.povray.org>
>> object {
>>     walls_ob
I thought so too indeed. It looks like they do /not/ default to this. As
far as I know, this is not mentioned in the docs.
