POV-Ray : Newsgroups : povray.binaries.images : LanuHum Global Test image Server Time
28 May 2026 11:17:14 EDT (-0400)
  LanuHum Global Test image (Message 7 to 16 of 126)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: LanuHum Global Test image
Date: 8 Jan 2014 10:19:54
Message: <52cd6c9a$1@news.povray.org>
On 8-1-2014 15:38, clipka wrote:
> Am 08.01.2014 15:25, schrieb clipka:
>> Obviously there's something wrong with the water, the door has too much
>> reflection, and the aspect ratio doesn't match, so I'll need a bit more
>> work.
> The door, too, has the textures wrong; probably the same for the folding
> chairs, but I haven't yet figured out the proper assignment of materials
> for those.
Same as for the windows: textures have been switched, making the door
panels chrome and the handles/pivots glass ;-)
Date: 8 Jan 2014 10:23:31
Message: <52cd6d73$1@news.povray.org>
On 8-1-2014 16:00, LanuHum wrote:
> clipka <ano### [at] anonymousorg> wrote:
>> Increasing the radiosity recursion_limit will do the scene good.
> recursion_limit  - 20
No, no! recursion_limit should not be too high. In the present case a
value of 3 works well.
Date: 8 Jan 2014 10:26:44
Message: <52cd6e34@news.povray.org>
Am 08.01.2014 16:19, schrieb Thomas de Groot:
>>> work.
>> for those.
Actually that was the problem with the mirror, too.
Date: 8 Jan 2014 10:31:37
Message: <52cd6f59@news.povray.org>
Am 08.01.2014 16:00, schrieb LanuHum:
Ah, well - that's a bit extreme :-)
For most indoor scenes, recursion_limit 3 should be enough, maybe 4 if
you think the scene renders too fast :-P
Date: 8 Jan 2014 10:55:27
Message: <52cd74ef$1@news.povray.org>
>>>> work.
>>> for those.
Well, I am not sure about that one (although that is a solution). I
loaded the mirror into Poseray and had the impression that the geometry
was mirrored, but I might be wrong there.
Date: 8 Jan 2014 11:01:41
Message: <52cd7665@news.povray.org>
Last test for today.
I brought all the reflections down to similar levels (have to be tweaked
later on of course) and switched the textures in a number of objects.
More tomorrow.
Download 'test.png' (263 KB)
Preview of image 'test.png'
Date: 8 Jan 2014 11:05:00
Message: <web.52cd762520fca3a57a3e03fe0@news.povray.org>
Correct mirror.
There are no caustics reflection and refraction.
Photons and radiosity are compatible?
How to improve contrast?
Download 'povwip.png' (291 KB)
Preview of image 'povwip.png'
Date: 8 Jan 2014 14:10:01
Message: <web.52cda21d20fca3a57a3e03fe0@news.povray.org>
It is a little caustics:
Download 'povwip.png' (287 KB)
Date: 8 Jan 2014 14:20:58
Message: <52cda51a@news.povray.org>
Am 08.01.2014 17:00, schrieb LanuHum:
Use photons.
Yes.
Make sure though that all the windows are using "photons{pass_through}",
and that all surfaces you want to generate caustics are using
"photons{target on reflection on refraction on}".
In the global settings photons block, you'll also need to set
adc_bailout to a very low value. I'm currently using 1/100000 (1e-5).
The original colors were probably intended to be in sRGB space, so try
replacing all "rgb" with "srgb" (and also all "rgbf" with "srgbf",
"rgbt" with "srgbt", and "rgbft" with "srgbft").
This will reduce the brightness of many materials, thereby reducing the
effect of radiosity. As a consequence, areas in shadow will experience
not only an absolute reduction in brightness, but more importantly also
a reduction in brightness relative to areas in bright light. (As areas
in bright light will also get a bit darker, you may want to increase the
light source's brightness to compensate.)
Date: 8 Jan 2014 14:23:40
Message: <52cda5bc$1@news.povray.org>
Am 08.01.2014 20:08, schrieb LanuHum:
Looks to me like you added another light source. Don't - unless you
really know what you're doing, every bit of cheating makes the result
look less realistic.
