POV-Ray : Newsgroups : povray.binaries.images : LanuHum Global Test image Server Time
28 May 2026 05:55:22 EDT (-0400)
  LanuHum Global Test image (Message 47 to 56 of 126)
Subject: Re: LanuHum Global Test image
Date: 9 Jan 2014 19:09:47
Message: <52cf3a4b$1@news.povray.org>
Hi(gh)!
On 09.01.2014 14:18, Thomas de Groot wrote:
> Far from me the desire to reach the perfection of Master Lipka, so as a
> good disciple I humbly show here my unworthy filth to be judged, kindly
> but justly I hope. :-)
> I am far from done, so no caustics or other more serious material
> details, neither is the water or the glass sculpture visited here.
> I changed the light source to a CIE.inc blackbody of 6200 kelvin and
> doubled the luminosity; I added micro-normals to plaster and tiles. Not
> yet UberPOV but that should come soon too.
> Thomas
Still, to me the overall light levels of the shadowed parts seems
somewhat too low (but this might be a question of my system's gamma -
currently 2.0)... and there are still some bright artifact dots along
the upper edges of the walls. What radiosity settings did you use?
See you in Khyberspace!
Yadgar
Now playing: Gustav Mahler: Symphony No. 2, 5th movement, live at
Masada, conductor: Zubin Mehta
No
Date: 10 Jan 2014 03:21:57
Message: <52cfada5$1@news.povray.org>
I agree about the light levels but I don't know how to compensate that
other than by an additional light (I don't like) or by a stronger light
maybe (I shall try). However, I personally like this and my impression
is that this is a /natural/ situation. Comments welcome.
The bright dots are still a problem indeed. They are also present in
Christoph's image. I wonder if this is not light leaking along mesh
edges.... Comments welcome.
presently, radiosity settings are:
   radiosity {
       pretrace_start   0.08
       pretrace_end     0.004
       count            500, 1000
       nearest_count    10, 5
       error_bound      1
       recursion_limit  4
       low_error_factor 0.3
       gray_threshold   0.0
       minimum_reuse    0.015
       maximum_reuse    0.1
       brightness       1
       adc_bailout      1/100000
       normal           on
       media            off
       always_sample    off
       //max_sample     1.0
Date: 10 Jan 2014 04:00:43
Message: <52cfb6bb$1@news.povray.org>
Am 10.01.2014 09:21, schrieb Thomas de Groot:
I think the shadowed parts do look perfectly right.
> edges....
It is light leaking and it gets even worse when using higher quality
(i.e. lower error_bound) settings. I guess the only solution is to
remodel the room and give the walls and the ceiling some real thickness,
thats what I did. As with CSG where it is a good idea to let walls and
ceiling overlap.
>    radiosity {
>        pretrace_start   0.08
>        pretrace_end     0.004
>        count            500, 1000
>        nearest_count    10, 5
>        error_bound      1
>        recursion_limit  4
>        gray_threshold   0.0
>        minimum_reuse    0.015
>        maximum_reuse    0.1
>        brightness       1
>        normal           on
>        media            off
>        always_sample    off
>        //max_sample     1.0
When you add no_radiosity to all window/door glasses you'll get away
with 2 recursions and faster render speed - without any visual impact.
And I'm not sure about this low adc_bailout within the radiosity block,
if such low value is needed shouldn't it go into the global settings
block itself - to keep the photons visible?
Maybe Christoph can shed some light on this.
-Ive
Date: 10 Jan 2014 04:06:27
Message: <52cfb813@news.povray.org>
Just for a quick test I switched off the normals here. I doubled again
the luminosity and now the shadowy parts come out better.
I wonder if the leaking along the edges cannot be remedied by better
meshes. The present ones are of very low resolution (a pillar face is
just two triangles for instance). That might give problems. I am going
to have the walls through Silo and process them a bit.
Download 'test.png' (299 KB)
Preview of image 'test.png'
Date: 10 Jan 2014 04:11:53
Message: <52cfb959$1@news.povray.org>
>> edges....
> ceiling overlap.
You confirm my own guess. I am going to process the walls and pillars
objects in Silo.
>>    radiosity {
>>        pretrace_start   0.08
>>        pretrace_end     0.004
>>        count            500, 1000
>>        nearest_count    10, 5
>>        error_bound      1
>>        recursion_limit  4
>>        gray_threshold   0.0
>>        minimum_reuse    0.015
>>        maximum_reuse    0.1
>>        brightness       1
>>        normal           on
>>        media            off
>>        always_sample    off
>>        //max_sample     1.0
Good idea. I didn't think of that possibility.
I put in that low adc_bailout in preparation to the photons/caustics
generation, as Christoph suggested earlier in this thread. I am a newbie
as far as this is concerned.
Date: 10 Jan 2014 04:20:00
Message: <52cfbb40$1@news.povray.org>
Am 10.01.2014 10:11, schrieb Thomas de Groot:
Yes, thats what I'm saying too, but it seems you missed the "global
settings block itself" - and not the radiosity block within the global
settings.
-Ive
Date: 10 Jan 2014 06:44:12
Message: <52cfdd0c$1@news.povray.org>
The proper approach to compensate would be to increase the walls'
brightness. /If/ you want to compensate at all. Looks natural enough to
me, too.
It's not specifically leaking along mesh edges, but through /any/ edges.
Surprisingly, similar artifacts can be observed with CSG as well. Up to
this day I haven't really figured out what's causing this, but the
number of radiosity bounces (i.e. recursion_limit) does seem to play a
role (I think I've never seen these artifacts with recursion_limit 2 or
lower).
Date: 10 Jan 2014 06:47:28
Message: <52cfddd0$1@news.povray.org>
Am 10.01.2014 10:18, schrieb Ive:
> settings.
Actually I proposed to use such a low value in the global settings
/photons/ block.
The general global settings adc_bailout, as well as radiosity
adc_bailout, should both be ok with more conservative values.
Date: 10 Jan 2014 07:11:22
Message: <52cfe36a$1@news.povray.org>
>> settings.
> /photons/ block.
Right. I missed that, as I am now entering unknown territory ;-)
I have some read-up on the matter to do, and some testing.
Date: 10 Jan 2014 07:17:02
Message: <52cfe4be$1@news.povray.org>
> me, too.
I agree and, as far as I am concerned, I do not want to compensate.
Increasing luminosity helps too while keeping the balance between light
and dark within acceptable limits.
> lower).
Well, from my latest render (not included here) I must say that leaking
also appears with recursion_limit 2.
Iirc, Christoph Hormann treated this problem in Megapov with a radiosity
patch.
