POV-Ray : Newsgroups : povray.binaries.images : LanuHum Global Test image Server Time
28 May 2026 00:14:24 EDT (-0400)
  LanuHum Global Test image (Message 41 to 50 of 126)
Subject: Re: LanuHum Global Test image
Date: 9 Jan 2014 10:28:29
Message: <52cec01d$1@news.povray.org>
Am 09.01.2014 14:18, schrieb Thomas de Groot:
> Far from me the desire to reach the perfection of Master Lipka, so as a
> good disciple I humbly show here my unworthy filth to be judged, kindly
> but justly I hope. :-)
"Master Lipka"? Oh my gosh, what have you imbibed? ;-)
Date: 9 Jan 2014 10:43:36
Message: <52cec3a8$1@news.povray.org>
I am sorry Master! I of course meant High Master!
[abases himself in the mud]
Date: 9 Jan 2014 13:00:01
Message: <web.52cee2bd20fca3a57a3e03fe0@news.povray.org>
> Certainly.
> #declare brown_shapes_tex =
> texture {pigment {color srgbf <0.3959,0.1713,0.1713,1.0>}
> finish{brown_shapes_finish}}
But, this glass. It not glossy!
Date: 9 Jan 2014 13:15:00
Message: <web.52cee5ff20fca3a57a3e03fe0@news.povray.org>
> Yes indeed. I cannot work as fast as Christoph, especially caustics are
> unfamiliar to me, but I shall try my best. You are free to use the
> images of course.
> Thomas
Thanks!
Date: 9 Jan 2014 13:15:03
Message: <52cee727@news.povray.org>
Am 09.01.2014 18:56, schrieb LanuHum:
> clipka <ano### [at] anonymousorg> wrote:
>> Certainly.
The glossyness depends on the finish, in this case brown_shapes_finish.
I'm not sure what you're trying to say. Are you saying that the glass is
too glossy, or that the glass isn't glossy enough?
Note that I didn't attempt to reproduce the Lux render; the render
results are so different between all the various renderers anyway that I
didn't bother.
Date: 9 Jan 2014 13:50:01
Message: <web.52ceeed620fca3a57a3e03fe0@news.povray.org>
> didn't bother.
I don't speak about Luxrender
I say that I saw your vase glossy, but opaque as dark porcelain
I adjusted the vase with the rgb parameter, not rgbf
Other result turned out absolutely, and, I didn't find the reason
Date: 9 Jan 2014 19:09:47
Message: <52cf3a4b$1@news.povray.org>
Hi(gh)!
> I am far from done, so no caustics or other more serious material
> details, neither is the water or the glass sculpture visited here.
> I changed the light source to a CIE.inc blackbody of 6200 kelvin and
> doubled the luminosity; I added micro-normals to plaster and tiles. Not
> yet UberPOV but that should come soon too.
> Thomas
Still, to me the overall light levels of the shadowed parts seems
somewhat too low (but this might be a question of my system's gamma -
currently 2.0)... and there are still some bright artifact dots along
the upper edges of the walls. What radiosity settings did you use?
See you in Khyberspace!
Yadgar
Now playing: Gustav Mahler: Symphony No. 2, 5th movement, live at
Masada, conductor: Zubin Mehta
No
Date: 10 Jan 2014 03:21:57
Message: <52cfada5$1@news.povray.org>
I agree about the light levels but I don't know how to compensate that
other than by an additional light (I don't like) or by a stronger light
maybe (I shall try). However, I personally like this and my impression
is that this is a /natural/ situation. Comments welcome.
The bright dots are still a problem indeed. They are also present in
Christoph's image. I wonder if this is not light leaking along mesh
edges.... Comments welcome.
presently, radiosity settings are:
   radiosity {
       pretrace_start   0.08
       pretrace_end     0.004
       count            500, 1000
       nearest_count    10, 5
       error_bound      1
       recursion_limit  4
       low_error_factor 0.3
       gray_threshold   0.0
       minimum_reuse    0.015
       maximum_reuse    0.1
       brightness       1
       adc_bailout      1/100000
       normal           on
       media            off
       always_sample    off
       //max_sample     1.0
Date: 10 Jan 2014 04:00:43
Message: <52cfb6bb$1@news.povray.org>
Am 10.01.2014 09:21, schrieb Thomas de Groot:
I think the shadowed parts do look perfectly right.
> edges....
It is light leaking and it gets even worse when using higher quality
(i.e. lower error_bound) settings. I guess the only solution is to
remodel the room and give the walls and the ceiling some real thickness,
thats what I did. As with CSG where it is a good idea to let walls and
ceiling overlap.
>    radiosity {
>        pretrace_start   0.08
>        pretrace_end     0.004
>        count            500, 1000
>        nearest_count    10, 5
>        error_bound      1
>        recursion_limit  4
>        gray_threshold   0.0
>        minimum_reuse    0.015
>        maximum_reuse    0.1
>        brightness       1
>        normal           on
>        media            off
>        always_sample    off
>        //max_sample     1.0
When you add no_radiosity to all window/door glasses you'll get away
with 2 recursions and faster render speed - without any visual impact.
And I'm not sure about this low adc_bailout within the radiosity block,
if such low value is needed shouldn't it go into the global settings
block itself - to keep the photons visible?
Maybe Christoph can shed some light on this.
-Ive
Date: 10 Jan 2014 04:06:27
Message: <52cfb813@news.povray.org>
Just for a quick test I switched off the normals here. I doubled again
the luminosity and now the shadowy parts come out better.
I wonder if the leaking along the edges cannot be remedied by better
meshes. The present ones are of very low resolution (a pillar face is
just two triangles for instance). That might give problems. I am going
to have the walls through Silo and process them a bit.
Download 'test.png' (299 KB)
Preview of image 'test.png'
