POV-Ray : Newsgroups : povray.binaries.images : LanuHum Global Test image Server Time
27 May 2026 21:15:53 EDT (-0400)
  LanuHum Global Test image (Message 21 to 30 of 126)
Subject: Re: LanuHum Global Test image
Date: 8 Jan 2014 19:12:40
Message: <52cde978$1@news.povray.org>
> Am 08.01.2014 15:25, schrieb clipka:
>> Here's my first result after getting the worst stuff sorted out (using
>> UberPOV of course).
> Further down the line, UberPOV gives me this.
> Which reminds me that I still have to make blurred reflections work
> properly with photons.
Does UberPov also support blurred transmission through transparent objects?
If not now, it could be on the to do list.
Date: 8 Jan 2014 19:27:24
Message: <52cdecec$1@news.povray.org>
Am 09.01.2014 01:13, schrieb Alain:
It /is/ on the to do list ;-)
Date: 9 Jan 2014 03:05:04
Message: <web.52ce579d20fca3a57a3e03fe0@news.povray.org>
> > UberPOV of course).
What is the time left on a render?
Date: 9 Jan 2014 03:22:31
Message: <52ce5c47@news.povray.org>
On 8-1-2014 21:05, LanuHum wrote:
> clipka <ano### [at] anonymousorg> wrote:
>> Am 08.01.2014 20:08, schrieb LanuHum:
>>> It is a little caustics:
>> Looks to me like you added another light source. Don't - unless you
>> really know what you're doing, every bit of cheating makes the result
>> look less realistic.
> Yes, I added. :(
> But, It is a lot of big windows, unless it shouldn't be lighter in the room?
In Real Life, the eyes adapt themselves to the shadowy parts of a room
and, without you being aware of it, the lighter parts are then overexposed.
In photography as in ray-tracing, you need to find the balance between
the two extremes. Adding a light is possible but a feeble solution imho
and not really convincing. If you really want the shadows cleared more,
increase recursion_limit to 4 or 5.
Date: 9 Jan 2014 03:25:52
Message: <52ce5d10$1@news.povray.org>
On 8-1-2014 21:34, clipka wrote:
> Am 08.01.2014 20:58, schrieb LanuHum:
>>> "srgb"
>> How to write down?
>> example:
>> pigment{ color srgb < 0.5, 1, 0.3, 0.7>}?
> Exactly.
Not exactly: should be srgbf or srgbt as there are *four* parameters in
the vector ;-)
Date: 9 Jan 2014 03:45:00
Message: <web.52ce60c320fca3a57a3e03fe0@news.povray.org>
> Thomas
Thanks!
clipka, I noticed that in your work light on a floor in the room differs from
light on a floor in a mirror. It is correct?
Date: 9 Jan 2014 03:50:01
Message: <web.52ce625a20fca3a57a3e03fe0@news.povray.org>
> the vector ;-)
> Thomas
Therefore I asked. Means, s - isn't adjustable parameter
Date: 9 Jan 2014 03:59:12
Message: <52ce64e0$1@news.povray.org>
no indeed. It is /not/ adjustable.
Date: 9 Jan 2014 04:10:01
Message: <web.52ce66d220fca3a57a3e03fe0@news.povray.org>
> > UberPOV of course).
clipka, may I place your work on i.imgur.com?
I want that the picture was visible on the page our site.
While I placed the link
Date: 9 Jan 2014 05:13:14
Message: <52ce763a@news.povray.org>
Am 09.01.2014 09:41, schrieb LanuHum:
I'm perfectly sure there is no such difference. It does differ from your
results, but that's because I adjusted the light source position to
better match the images produced with other renderers.
