POV-Ray : Newsgroups : povray.binaries.images : LanuHum Global Test image Server Time
28 May 2026 09:57:10 EDT (-0400)
  LanuHum Global Test image (Message 17 to 26 of 126)
Subject: Re: LanuHum Global Test image
Date: 8 Jan 2014 15:00:01
Message: <web.52cdaddc20fca3a57a3e03fe0@news.povray.org>
> In the global settings photons block, you'll also need to set
> adc_bailout to a very low value. I'm currently using 1/100000 (1e-5).
Thanks!
> "srgb"
How to write down?
example:
pigment{ color srgb < 0.5, 1, 0.3, 0.7>}?
Date: 8 Jan 2014 15:10:00
Message: <web.52cdaf9e20fca3a57a3e03fe0@news.povray.org>
> Am 08.01.2014 20:08, schrieb LanuHum:
> > It is a little caustics:
> Looks to me like you added another light source. Don't - unless you
> really know what you're doing, every bit of cheating makes the result
> look less realistic.
Yes, I added. :(
But, It is a lot of big windows, unless it shouldn't be lighter in the room?
Date: 8 Jan 2014 15:34:32
Message: <52cdb658@news.povray.org>
Am 08.01.2014 20:58, schrieb LanuHum:
>> "srgb"
> How to write down?
> example:
Exactly.
Date: 8 Jan 2014 16:56:28
Message: <52cdc98c@news.povray.org>
Am 08.01.2014 15:25, schrieb clipka:
> Here's my first result after getting the worst stuff sorted out (using
> UberPOV of course).
Further down the line, UberPOV gives me this.
Which reminds me that I still have to make blurred reflections work
properly with photons.
Download 'test_uber.png' (477 KB)
Preview of image 'test_uber.png'
Date: 8 Jan 2014 19:12:40
Message: <52cde978$1@news.povray.org>
>> UberPOV of course).
Does UberPov also support blurred transmission through transparent objects?
If not now, it could be on the to do list.
Date: 8 Jan 2014 19:27:24
Message: <52cdecec$1@news.povray.org>
Am 09.01.2014 01:13, schrieb Alain:
It /is/ on the to do list ;-)
Date: 9 Jan 2014 03:05:04
Message: <web.52ce579d20fca3a57a3e03fe0@news.povray.org>
> > UberPOV of course).
What is the time left on a render?
Date: 9 Jan 2014 03:22:31
Message: <52ce5c47@news.povray.org>
> Yes, I added. :(
In Real Life, the eyes adapt themselves to the shadowy parts of a room
and, without you being aware of it, the lighter parts are then overexposed.
In photography as in ray-tracing, you need to find the balance between
the two extremes. Adding a light is possible but a feeble solution imho
and not really convincing. If you really want the shadows cleared more,
increase recursion_limit to 4 or 5.
Date: 9 Jan 2014 03:25:52
Message: <52ce5d10$1@news.povray.org>
>>> "srgb"
>> How to write down?
>> example:
> Exactly.
Not exactly: should be srgbf or srgbt as there are *four* parameters in
the vector ;-)
Date: 9 Jan 2014 03:45:00
Message: <web.52ce60c320fca3a57a3e03fe0@news.povray.org>
> Thomas
Thanks!
clipka, I noticed that in your work light on a floor in the room differs from
light on a floor in a mirror. It is correct?
